Old July 21st, 2011, 11:39   #1
vw dubtdi
TDI(s): golf m3
Default mk3 golf tdi won,t start no fuel at the pump
hi just got an n reg mk3 golf tdi the car turns over but won,t fire theres no fuel coming to the injectors i suspect the injector pump may be no good is there a lift pump in the tank or is there any other ways of checking before changing the pump? any help would be much appreciated
vw dubtdi is offline   Reply With Quote
Old July 22nd, 2011, 09:14   #2
Did you verify if the fuel shut-off solenoid on the IP is working? Could be as simple as a bad wire or failed relay.
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Old July 22nd, 2011, 12:59   #3
Mike_Van's Avatar
Fuel Economy: ~39.0
As mech644 said, check the relay.
Also, verify that the starter is spinning quickly enough to turn the engine to a sufficient RPM to even begin injecting fuel (the crank position sensor does this). I've seen a weak battery result in a too-slow starter speed.
Do read up on the 'no-start troubleshooting thread' for a more comprehensive discussion of no-start symptoms.
Mike_Van is offline   Reply With Quote
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 06:48
MK3 TDI, Won't Start but cranks and smokes D_Bat TDI 101 19 February 12th, 2009 15:07
Changed fuel pump - now car won't start scanchattanooga VW MKIV-A4 TDIs (VE and PD) 5 August 19th, 2007 06:31
2002 golf, changed fuel filter, now won't start silvergolf2002 TDI 101 20 November 6th, 2006 11:21
Replaced Fuel Pump - Now Won't Start linden510 TDI 101 6 October 6th, 2006 19:14
Page generated in 0.08129 seconds with 10 queries
[Output: 56.87 Kb. compressed to 51.54 Kb. by saving 5.33 Kb. (9.38%)]
