Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old August 16th, 2011, 18:34   #46
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
Originally Posted by darrelld View Post
Successful Regenerations: 128
How were you able to find out the number of successful regens? Did you use VAGCOM?
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old August 16th, 2011, 18:38   #47
darrelld
darrelld's Avatar
Fuel Economy: Fuelly
Yes, measuring block 101.
http://pics.tdiclub.com/showphoto.ph...e=vcds&cat=500
darrelld is offline   Reply With Quote
Old August 16th, 2011, 18:46   #48
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
I couldn't squeeze out any info from my local dealer in regards to the amount or anticipated amount of oil ash the DPF can hold. I'm sure they don't want to be caught "quoting" a figure. Can't blame them.
From the limited data collected thus far, it looks like for every 10K miles, we accumulate about 10 ml of oil ash. I emailed a member who has 90K miles, but they don't have a VAGCOM. I'm curious what he has. My gut feeling tells me the driving style has an impact on oil ash accumulation as well as the type of oil used. Doesn't our oil trap or absorb ash? If so, wouldn't changing the oil more often be advantageous?
BTW, at 62K miles, my oil ash is still 60 ml. I'm curious when it will increase again.
I appreciate the posts and for all the commentary. Look forward to seeing where this leads us.
Old August 16th, 2011, 18:50   #49
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Nice!
How did I miss that??? Going to add that to the spreadsheet.
Old August 17th, 2011, 12:15   #50
FraggyTDI
TDI(s): 04 Jetta
Hello everyone, I thought I would contribute my knowledge on this matter. I currently work for a diesel engine company that uses DPF in their trucks. From what I have learned you can burn off soot (which is unburned diesel)>this creates ash which is carbon.
Most vehicals do passive regen when you are driving but this is not hot enough to burn the soot completly so eventually you have to do a "parked regen."
Here is Regeneration as laid out by our company.
Regeneration
Periodically, the soot and ash particulates in the DPF must be burned off. This process is called regeneration and it can occur passively, actively, or by a driver-initiated procedure.
Passive regeneration of the DPF simply means that, at normal highway operating temperatures, the exhaust system gets hot enough to ignite these particulates in the DPF. This automatically cleans, or regenerates, the filtration material in the DPF, extending its usable life.
Active regeneration is initiated automatically by the aftertreatment system when passive regeneration is not effective enough by itself. This can be necessary in cold climates or during light duty cycles in which normal operating temperatures are not always reached. During the Active Regeneration process, fuel is injected into the exhaust stream and ignited at the DOC, raising the temperature of the DPF enough to burn the particulates.
The third is Driver Initiated or Parked Regeneration. This is where the truck is parked and the throttle valve is closed to and the rpm's are increased. This goes on for about 20 minutes to allow the DPF to get hot enough to burn off all of the soot.
Eventually the DPF gets to full of ash from regens and operation. Our DPF's are rated for 150,000 miles before they need to be cleaned out. But this can depend on what kind of driving is being done.
So I'm assuming that the VW's work similer to the trucks. Whether they have a doser or not I don't know but I'm sure their DPF's are rated for similar milage before they need to be cleaned out. BUT.....knowning stealerships they will probably just replace the whole DPF with a new one instead of just cleaning out the DPF.
The drive of our truck is signaled when to do a regen by the ECU which uses a delta pressure sensor that connects to both the front and rear of the DPF. This measures the amount of back pressure caused by containment build up.
FraggyTDI is offline   Reply With Quote
Old August 17th, 2011, 12:21   #51
darrelld
darrelld's Avatar
On the trucks that we make there is a DOC(diesel oxidation catalyst) before the DPF. Also there is an exhaust throttle valve and a doser valve to assist in parked regen. When the parked regen is needed the truck gets parked the engine rpms increase and the exhaust throttle valve closes to increase temperatures. Once it is hot enough the exhaust is released threw the DOC and into the DPF, as this is happening a dose of diesel is shot in with the exhaust to light the DPF on fire this allows for it to reach the needed temperature to burn of any soot. all the soot becomes ash and collects at the bottom of the DPF.
What type of driving causes the DPF to need removal and servicing quicker?
Old August 17th, 2011, 13:01   #52
FraggyTDI
TDI(s): 04 Jetta
Stop go traffic, because you aren't constantly flowing hot exhaust through the DPF, plus you're creating more soot when you are always taking off. I bet if you compare avg fuel economy to the mileage between Regens you will see a correlation between low fuel economy and low miles between DPF regens. This would most likely mean you are driving city and not as much highway.
Old August 17th, 2011, 13:21   #53
FraggyTDI
TDI(s): 04 Jetta
Here's a couple links to the EPA just some more DPF information
http://www.epa.gov/cleandiesel/documents/420f10029.pdf
http://www.epa.gov/cleandiesel/techn.../retrofits.htm
Old August 18th, 2011, 12:20   #54
Scenic Driver
Scenic Driver's Avatar
Nice!
On my car this reads 0. Also at 50981 miles by ash volume is still 48ml.
_____________________________________________
2010 Golf TDI - 2 Door, 3 Pedal
2002 Audi TT Quattro
Scenic Driver is offline   Reply With Quote
Old August 23rd, 2011, 16:52   #55
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
I just double-checked and this figure is "zero" all the time.
Darrelld- how did you get "successful regens" to give you a number other than "0" ? What version of VAGCOM are you using?
Old August 23rd, 2011, 17:25   #56
darrelld
darrelld's Avatar
Using the latest release 10.6.4.
Old August 23rd, 2011, 18:49   #57
dataiv
dataiv's Avatar
I also am using the latest version (10.6.4) and get 0.0 for the successful regens number.
I am at 10600km (not miles) and my VCDS is still showing 0 ml for ash volume.
2011 Golf Wagon TDI 6MT (164997km bought back by VW)
2015 Golf Wagon TDI 6MT (118000km)
dataiv is offline   Reply With Quote
Old August 23rd, 2011, 18:54   #58
darrelld
darrelld's Avatar
You can see the measuring blocks here;
They could haves changed the memory registers for the 2011 ECM and the values are stored elsewhere.
Old August 23rd, 2011, 20:07   #59
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
I wonder if it has to do with the model year car. I'll bet the 2009 ECM's don't capture/register this information, therefor the measuring block is zero, but 2010+ models will? But that doesn't explain Dataiv's car registering zero also. Let me email Ross-Tech and ask them.
Old August 23rd, 2011, 20:12   #60
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Darrelld- if VAGCOM is correct, your car is having a regen every 90 miles or so. 128 regens per 11K miles?
Long-term DPF data project DoctorDawg VW MKV-A5 Golf/Jettas 55 January 30th, 2013 17:42
Off-topic posts from Cam Failure Data Collection thread donDavide Fuels & Lubricants 63 June 15th, 2011 00:18
PD cam failure - Data collection thread SBAtdijetta Fuels & Lubricants 116 February 25th, 2011 22:21
Biodiesel in DPF/Clean diesel vehicles Drivbiwire Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 6 August 25th, 2010 09:55
2009 Jetta Clean Diesel w DPF = Regen? Rod Bearing TDI (Diesel) Emissions 5 October 15th, 2008 19:58
Page generated in 0.20817 seconds with 10 queries
[Output: 139.77 Kb. compressed to 117.27 Kb. by saving 22.50 Kb. (16.10%)]
