Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old July 24th, 2011, 21:25   #16
El Dobro
El Dobro's Avatar
Fuel Economy: 115 MPGe
This may help to extend the life of the DPF.
http://cgi.ebay.co.uk/skoda-audi-sea...-/110667943228
"Drink the Kool-Aid" -Jim Jones
"Baa-baa-baa" -Sheep
"He's opening our minds to new ideas, KILL HIM!!!" -Futurama
Now, I drive more, worry less.
Penguin -The other white meat.
El Dobro is offline   Reply With Quote
Old July 24th, 2011, 22:57   #17
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
VW Skoda Audi Seat
DPF Additive
Satacen 25
used to remove soot from the diesel particulate filter
part number
g052143a2
or
g 052 143 a2
used in the 2.0 diesel
the system takes 4 litre to fill
and will require filling at 80.000 to 120.000 miles
you will get a warning light come on telling you are low
this is normally the engine management light
this action is for 1 litre
This looks like the Adblue that the new US made Passat will use.
I ran across a DPF "cleaner" available in Europe. The link:
http://www.jlmlubricants.com/Diesel.html
1) JLM DPF Cleaner
The first version is the JLM Diesel Particulate Filter (DPF) Cleaner Fluid, which comes in a 100ml can and is added to the fuel tank every service interval or 10.000km for maximum cleaning power of the Diesel Particulate Filter (DPF). It cleans blocked diesel filters (1st stage warning) and enables full diesel filter regeneration in difficult drive cycles (ie. city driving) .
To read about the first test results read this convincing PDF file (click link below)
JLM DPF Cleaner test results (JLM Diesel Particuatel Filter Cleaner Test Results)
Bob
bobt2382 is offline   Reply With Quote
Old July 24th, 2011, 23:44   #18
JSWTDI09
JSWTDI09's Avatar
Originally Posted by bobt2382 View Post
1) JLM DPF Cleaner
Bob
This might help with regens when doing only city driving, but it will do nothing for ash accumulation which is primarily what this thread is about. Ash is the result of burning off soot and this chemical is supposed to help with the burning off of soot. Once that soot is burnt off, the resulting ash is what will limit the life of the DPF in the long run. When the ash accumulation is enough to block the flow of exhaust gases it must either be emptied out or the DPF replaced. We can all hope that someone figures out a cost effective way to empty it out. It might even be as simple as a shop-vac with a properly curved attachment. Only time will tell.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old July 25th, 2011, 06:42   #19
El Dobro
El Dobro's Avatar
VW Skoda Audi Seat
DPF Additive
Satacen 25
part number
g052143a2
or
g 052 143 a2
1) JLM DPF Cleaner
Bob
This isn't Adblue, it's called Eolys fluid and is used in European diesels in a tank that dispenses a measured amount at each fill-up into the fuel. Adblue is injected into the exhaust after the DPF. The fluid lowers the temperature that the soot will burn at, so the amount of post injections are lessened, which also means less fuel is used for the burning. The only manufacturer that mentions the use of this fluid is Peugeot, but they're all using it.
http://www.peugeot.com/en/innovation...-it-work-.aspx
Old July 25th, 2011, 18:53   #20
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
Who wants to be the first one to run a bottle of JLM DPF cleaner in their 2009 + TDI?
I should be getting some maintenance info from the dealer tomorrow on the DPF system. They are going to fax it to me. I'll scan and post it as soon as I can.
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old July 25th, 2011, 20:07   #21
Plus 3 Golfer
Plus 3 Golfer's Avatar
Unfortuately, these two products do not clean the ash from the DFP.
They appear to simply lower the balance point temperature oxidizing more soot all else being the same. Thus, the frequency of active regens and the likelihood of needing a service generation are reduced. My guess is that the reduction in ash buildup using these products will not extend the DPF life significantly. The products might prevent DPF replacement due to soot buildup for those that operate their cars in severe conditions like TDI taxis in NYC.
One last point, there are studies that show using, IIRC, B5 lowers the balance point temperature by 50*C.
I won't spend $ on these products.
Plus 3 Golfer is offline   Reply With Quote
Old July 25th, 2011, 20:55   #22
El Dobro
El Dobro's Avatar
So, you're saying Peugeot is incorrect when they say the Eolys fluid more than doubled the service period of their DPF?
Old July 25th, 2011, 21:24   #23
Plus 3 Golfer
What I'm saying is ash is ash and soot is soot. There is no evidence that eolys can somehow magically reduce ash buildup. It does nothing more than what biodiesel does and that is lowers the balance point temperature. Also, it's the combination of post injection and the additive that has extended the service period which appears to relate to soot oxidation not ash accumulation. Perhaps, Peugeot was having problems with soot accumulation clogging the DPF prior to ash clogging it.
If you can find that eloys reduces ash buildup, I'll buy it.
Old July 25th, 2011, 22:06   #24
El Dobro
El Dobro's Avatar
VW, Audi, Seat, Skoda, Volvo, Ford, Fiat and Citroen all use Eolys fluid along with Peugeot. They have tanks built into the cars for dispensing the fluid into the fuel tank.
Old July 26th, 2011, 11:39   #25
EJS
TDI(s): 2009 Jetta
Put me in the "extend it to what" camp - 39ml @ 40,000 = 390,000 if the limit is 380ml. Doesn't appear to be worth the trouble.
Not this cowboy, I ain't putting anything through the HPFP except diesel fuel............I ain't giving VW any wiggle room
It's just my opinion & worth exactly what you paid for it.
EJS is offline   Reply With Quote
Old July 27th, 2011, 05:46   #26
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Default VW DPF Regen info
I attached the link to a pdf file. This came from VW and is part of the Engine Management System dealing with Regenerations / DPF issues.
No where does it talk about Oil Ash Volume, only Soot Load. I've asked my dealer contact to try and dig a little deeper to see if there is any literature that specifically mentions "oil ash". Perhaps these terms are used interchangeably??? No one really knows. There are 4 pages... interesting read.
http://pics.tdiclub.com/data/4323/VW...ystem_Info.pdf
Four Types of Regens
Passive Regen
Active Regen
Distance Regen
Customer Initiated Regen
Service Regen
I have a longer drive to work now, so I hope the soot loads and oil ash volume increase at a much slower rate (or none at all). More "Passive Regens" for me please! One could only hope.
Old July 27th, 2011, 07:41   #27
Absolute Diesel
Absolute Diesel's Avatar
MacBuckEye thanks for posting all this great info.
If your calcs are correct, and we can truly get 250k - 500k+ out of this DPF, then I'd be quite happy. I wish some CR's with 100K would provide their data. I'll be adding my data as soon as I get my VAG-COM.
Absolute Diesel is offline   Reply With Quote
Old July 27th, 2011, 14:38   #28
Plus 3 Golfer
Passive Regen
Active Regen
Distance Regen
Service Regen
Those pages (and my quote above on 45 grams) are from the Self Study Program 826803 2.0 Liter TDI Common Rail BIN5 ULEV Engine which has been referenced many times over the past few years. I believe this link works for the full document: http://www.filemount.com/2010/10/self-study-program-826803-2-0-liter-tdi-common-rail-bin5-ulev-engine/
Old August 3rd, 2011, 22:09   #29
theedudenator
MemberName: Theedudenator
Model Year: 2009
Model: JettaWagon
Tranny: 6spd manual
Miles: 74867
Oil Ash Volume: 78ml
Oil Type: Not Sure - buy online
Avrg. MPG:
Comments: My light came on solid today
Fuel consumption since last regen = 67.2l
Mileage Since Last Regen 1200km
theedudenator is offline   Reply With Quote
Old August 9th, 2011, 18:02   #30
darrelld
darrelld's Avatar
Fuel Economy: Fuelly
MemberName: darrelld
Model Year: 2010
Model: Jetta
Tranny: DSG
Miles: 11,587
Oil Ash Volume: 9ml
Oil Type: Castrol LL03
Avg. MPG: 36
Mileage Since Last Regen: 360km
Soot Load Calculated: 15.3
Successful Regenerations: 128
As a reference most of my driving is 13 miles urban to work.
Stumbled across a DPF ash study by MIT;
http://www1.eere.energy.gov/vehicles...r10_sappok.pdf
darrelld is offline   Reply With Quote
Long-term DPF data project DoctorDawg VW MKV-A5 Golf/Jettas 55 January 30th, 2013 17:42
Off-topic posts from Cam Failure Data Collection thread donDavide Fuels & Lubricants 63 June 15th, 2011 00:18
PD cam failure - Data collection thread SBAtdijetta Fuels & Lubricants 116 February 25th, 2011 22:21
Biodiesel in DPF/Clean diesel vehicles Drivbiwire Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 6 August 25th, 2010 09:55
2009 Jetta Clean Diesel w DPF = Regen? Rod Bearing TDI (Diesel) Emissions 5 October 15th, 2008 19:58
Page generated in 0.17023 seconds with 10 queries
[Output: 143.18 Kb. compressed to 121.23 Kb. by saving 21.95 Kb. (15.33%)]
