Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Atlantic Canada
Atlantic Canada Atlantic Canada Section. This section is for people in Atlantic Canada to discuss items more local to them.
Old June 30th, 2011, 08:33   #1
valtdiesel
Default Diesel Additive
Does anyone know what the best diesel additive around here is?
I've read the Opti-Lube xpd is good. Just don't know if its available around??
valtdiesel is offline   Reply With Quote
Old June 30th, 2011, 08:51   #2
JSWTDI09
JSWTDI09's Avatar
They have a few dealers, but most people have to order it direct form the company. I have no idea how much shipping would be to Canada, but the shipping is cheaper when you buy larger quantities. I would go to their website and then call or email them and see if they have any Canadian dealers. It might save you some money on shipping.
http://opti-lube.com/
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old June 30th, 2011, 09:11   #3
HOOPER65
HOOPER65's Avatar
Fuel Economy: Pretty Darn Good :)
http://www.powerservice.com/dk/
This one is what I use and seems to be well used by others on here.
Hillcrest VW even sold it before Canadian Tire picked it up.
Look for it there at CT - it even goes on sale now & then
HOOPER65 is offline   Reply With Quote
Old June 30th, 2011, 17:50   #4
thanatos
Fuel Economy: 45 mpg - 5.2L/100kms avg
Have Fun!
Don
x2. I bought two gallons a year ago, cost me $130 or $150, I don't remember. Great stuff though!
thanatos is offline   Reply With Quote
Old June 30th, 2011, 19:07   #5
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
What function is needed above and beyond the standard package that comes from your local fuel supply?
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old July 1st, 2011, 03:08   #6
Fyrman
Fyrman's Avatar
I, for the most part, agree. I used to run Power Service religiously and I did feel the car ran smoother. Granted, washing the car makes it feel faster too. PS is supposed to keep the deposits to a minimum but as long as you're running good fuel like Irving's Clean Diesel, I have yet to see an unacceptable amount on anything I've worked on anyway. I stopped using it years ago.
Some people are like Slinkies...... They're really good for nothing but still bring a smile to your face when you push them down a flight of stairs!
Fyrman is offline   Reply With Quote
Old July 1st, 2011, 07:01   #7
HOOPER65
HOOPER65's Avatar
... cant really argue with that, - I put PS in if " ... I remember " .
Old July 1st, 2011, 13:58   #8
Slowrvr
Slowrvr's Avatar
For those of you who use an additive, how do you add it? I'm sure I pour in far more than necessary each time.
2006 Jetta TDI - Malone Stage 2
Slowrvr is offline   Reply With Quote
Old July 1st, 2011, 14:13   #9
JSWTDI09
JSWTDI09's Avatar
I put it into pre-measured small bottles. Then when I fill my tank, I pour in the additive first. This ensures that the additive is thoroughly mixed with the fuel. The biggest issue for most is finding the small bottles. There are several threads here about that.
Have Fun!
Don
Old July 1st, 2011, 16:16   #10
thanatos
Especially in the new CR diesels, lubricity is a big concern due to common rail direct injection, with the HPFP being lubricated by the fuel itself. Failures in the US market are actually quite common, and can cost 15-18K (that number, the high one.. that came from an NS dealer) as the whole fuel system is thrashed as the HPFP (high pressure fuel pump) basically disintegrates and floods the system with metal filings.
http://www.dieselplace.com/forum/sho...d.php?t=177728
That's why I use XPD.
@Fyrman... you have PD TDi so it's not really a concern for you but for those of us with newer diesels it's something we need to be more careful with.
Old July 1st, 2011, 18:47   #11
cleaver
cleaver's Avatar
From what I have read, there has been only 3 or 4 CDN vehicles with the HPFP failure. Our fuel in Canada is lightyears better than the US fuel.
That being said, a little extra additive won't hurt, and will most likely keep you that much safer (from HPFP failure).
Diagnosing Limp Mode
IMO, best place to buy VW parts in Canada: contact Brian @ www.roselandtech.ca
cleaver is offline   Reply With Quote
Old July 1st, 2011, 20:15   #12
Fyrman
Fyrman's Avatar
What CLever said...
If it truly was an issue, there'd be more of an issue about it.
...and I don't have a PD.
Old July 3rd, 2011, 11:36   #13
thanatos
What CLever said...
My apologies on the PD.
With the "issue about it"... it's a more prominent problem in the US, granted. That doesn't mean it can't / won't happen here if you get some bad fuel. My luck is the poops, so I'm being safer than sorry.
In any case, aside from increased lubricity, I notice better cold-weather fuel economy, as well as fewer regen cycles using the Optilube XPD. Warm weather fuel economy may be better but there' hasn't been enough where I've paid attention to notice though I averaged 58 mpg on the way home from work the other day, which was nice
Old July 4th, 2011, 12:25   #14
valtdiesel
thanks for the insight from everyone!
Old July 6th, 2011, 08:45   #15
RECCE-17
RECCE-17's Avatar
I use PS. I use a measuring funnel. Its got a twist valve on the bottom. Just measure, stick hose where it belongs and twist....could make a good beer bong!
Any way, ya can find it at wal-mart.
Through the mud and the blood to the green fields beyond. RCAC.
RC2, VNT 17, 11mm IP, Koni Red's, EGR cooler delete, TT bushings, Hidden hitch, 5 light mod, Evolution skid plate (with oil drain).
RECCE-17 is offline   Reply With Quote
What do u keep your Diesel additive in? GotEuroCorrado Fuels & Lubricants 22 February 14th, 2005 19:45
Will any Diesel additive do? robere Fuels & Lubricants 1 April 5th, 2004 11:29
What is the best diesel additive? jrbtdi Fuels & Lubricants 5 April 2nd, 2004 10:50
Diesel Additive ? Dieselman Fuels & Lubricants 2 September 29th, 2000 18:12
Diesel additive use ? Norman Fuels & Lubricants 10 September 7th, 1999 02:28
Page generated in 0.20541 seconds with 10 queries
[Output: 133.19 Kb. compressed to 111.65 Kb. by saving 21.54 Kb. (16.17%)]
