Old June 26th, 2011, 08:52   #1
Shelby789
Fuel Economy: 48 mpg avg right out of the box!
Default Disconnected battery, now can't stop alarm
I just got my new 109 relay the other day, when I went to install it, I opted to disconnect the negative terminal of the battery.....swapped the relay, buttoned up the fuse panel, went to connect the battery, and the alarm starts going off....I didn't know the car had an alarm!
I have no key fob, how do I re-connect the battery without setting off the alarm? I did a search, and on another forum they suggested holding the hood switch down while you connect the negative battery terminal....I did this and had no luck, as soon as I tightened the cable, honk honk honk!
Any help would be appreciated!
Shelby789 is offline   Reply With Quote
Old June 26th, 2011, 08:54   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Maybe if you just put the battey lead on then get in the car and put the key in the ignition and start it, I'm not sure but don't know what else to suggest.
Seatman is offline   Reply With Quote
Old June 26th, 2011, 10:50   #3
smilesyota
smilesyota's Avatar
When its going off put the key in the trunk and unlock.
smilesyota is offline   Reply With Quote
Old June 26th, 2011, 11:43   #4
1chrisapple
put key in drivers door unlock and dhold in unlock position for 10 seconds then c what happens might work might not
1chrisapple is offline   Reply With Quote
Old June 26th, 2011, 12:25   #5
surfbus
surfbus's Avatar
Second on this, I used to do that too on our 99 Passat. Stopped the endless honking.
Door handles 139$, headliner 500$. No camshaft, balance shaft or high pressure fuel pump issues to repair... priceless!
surfbus is offline   Reply With Quote
Old June 26th, 2011, 17:21   #6
Shelby789
Wow, I don't think I would have guess that.....I didn't even have to unlock the trunk, I put the key in the trunk in preparation, and when I connected the battery the horn beeped once and that was it!
Thanks guys!
Old June 27th, 2011, 11:34   #7
smilesyota
smilesyota's Avatar
just happened on mine, thats the only reason i knew about it!
Old June 27th, 2011, 14:02   #8
teeth
TDI(s): 1997 Passat
Fuel Economy: 50-54 MPG
Pretty sure if you put the key in the door handle and unlock the doors it'll disarm.
If not, putting the key in the ignition and starting the car I believe also shuts it off.
teeth is offline   Reply With Quote
Alarm sounds unless battery is disconnected, and wont start... Proudfoot VW MKIV-A4 TDIs (VE and PD) 8 May 14th, 2010 21:28
HELP!!! someone disconnected the battery! 02jettatdi shedhorninc TDI 101 5 August 29th, 2008 09:04
No start after battery disconnected Arthur VW MKV-A5 Golf/Jettas 3 May 4th, 2006 10:49
Disconnected battery - Now my radio says SAFE Praise_The_Lard VW MKIII-A3/B4 TDIs 2 August 16th, 2005 07:12
Battery was disconnected.. ECU affected? SilverTDIGolf TDI 101 3 February 7th, 2005 07:08
Page generated in 0.15307 seconds with 10 queries
[Output: 82.44 Kb. compressed to 70.86 Kb. by saving 11.58 Kb. (14.05%)]
