| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
June 24th, 2011, 06:46
#1
Fuel Economy: 4.92 ltr/100
Wet Floor, driver's side
My guess is the floor is getting wet because I have water getting into the cabin air box/filter area. I park under a tree and get a lot of vegetation falling into the wiper area.
I expect there is a water drain in the filter area that has been blocked. Does this sound right?
2003 JETTA 5 spd
no mods.
June 24th, 2011, 09:29
#2
Fuel Economy: Average low 40's
Maybe this is too obvious - but, do you have a sunroof?
June 24th, 2011, 09:46
#3
LOL!
I needed that this morning....
Nope and the windows aren't left down either.
2003 JETTA 5 spd
no mods.
June 24th, 2011, 09:47
#4
Fuel Economy: About as good as it gets!
Check for blocked sunroof drains. There is a TSB or recall on some models.
Originally Posted by Big Mike
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
Malone tune, GTI Wheel with paddle shifters, Premium 8 Sound, Good camshaft & DMF, 118K miles, Black on Black.
June 24th, 2011, 14:11
#5
Given you have no sun roof, yup.
The PO of my beetle use to park under a pine tree. My passenger side floor was always wet and I kept trying to clean the sunroof drains with no results. It took me hours to get in and vacuum out the plenum. There are drains in there too that need to me cleaned.
Good luck
June 25th, 2011, 03:45
#6
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Look at the area under the grill right in front of the windscreen. Likely you will find leaves etc there blocking the drain. It is also possible (depends on car) that the A/C drain is blocked. That drain usually comes out on the passenger side of the car just about where the passenger would put their feet. It may be under a little flap on the side of the engine compartment.
Good Luck
Joe Meehan
2002 NB Silver Ohio BAA HUM
June 25th, 2011, 08:09
#7
My TDI has the same problem. water leaks in from somewhere and travels down through the handle to pop the hood. I can see a few drops if I open the fuse panel door also. I checked the drains under the hood and they are flowing fine. I also have no sunroof. I am just waiting for some free time to really investigate. I think mine has something to do with the windshield...
2000 Jetta TDI 184k, Panzer Plate, Frost heater.
2002 Jeep Liberty 172k.
1974 Beetle 1600 88k
June 25th, 2011, 22:31
#8
It's the hood release cable grommet.
Water in driver footwell ?????
2003 Golf GL TDI 5-speed 128,000 miles
June 26th, 2011, 07:35
#9
TY! I will do this next weekend!!
June 26th, 2011, 09:36
#10
I would also have this problem when on a grade when the front end of the car is facing "down the hill". If I park with the front end "up the hill"... no leaks
July 3rd, 2011, 09:57
#11
I spent the last hour with the shopvac cleaning the plenum by the cabin air filter. Pine needles, leaves and a mouse hotel. With the limited viz in there, I have no idea if there is a blocked drain hole or not.
What I do know, is after a rain, the driver side floor is wet. Much more than I would expect to be ldripping in along the hood release cable.
2003 JETTA 5 spd
no mods.
July 3rd, 2011, 11:08
#12
You might check to see if the comfort control module is under the carpet in the drivers side foot well. You do NOT want that module to get wet, don't ask how I know.
July 3rd, 2011, 21:13
#13
There are no drain holes in the wiper tray except for the large oval-ish irregular holes, one on each side, that open into the space behind the fender liner.
Did you remove the plastic wiper tray valance or were you working through the cabin filter access cover?
The driver's floor mat was soaked in my car after it rained. Problem was fixed after I resealed the hood release cable grommet.
It's not that complicated. There are four penetrations of the wiper tray into the cabin. Starting at the driver side:
1. Hood release cable grommet.
2. Relay box cover.
3. Cabin filter housing.
4. Hood release cable grommet hole (for right hand drive cars) sealed with a solid rubber plug.
Only 1 and 2 are on the driver side. Your water leak is at one of these locations.
