Old June 23rd, 2011, 21:03   #1
giw
TDI(s): 99 jetta
Fuel Economy: 53 hwy 43 combined
Default how to replace rear springs
hello tdi group
i am a current gm muscle car gasser who now drives a 264k 99 jetta a4..
i am in love with the performance and fuel economy.. and the forum
i purchsed the car out of state and to get through pa inspection i need to replace the rear springs as 1 is broken, i also plan to replace the rear shocks and it needs rear brakes..
i reviewed the awesome write up on the rear brake job but could not find any "how too's "on rear coil spring replacement..
also any suggestions for parts over oem replacement..
this is a daily driver in combined city and highway use..
thanks for your help
giw is offline   Reply With Quote
Old June 23rd, 2011, 22:14   #2
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
All you need is a pair of lift jacks and a spring compressor-that easy really. I am going with heavier springs in my car from a jetta wagon. idparts.com among others sells springs.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old June 24th, 2011, 03:55   #3
Alchemist
TDI(s): '04 Golf
To replace rear springs, disconnect the ABS sensor wire and see that it has slack, then remove the lower shock bolt. The axle beam will move down enough for the spring to fall out. Make sure you have some support under the axle beam or it will pull on the brake lines and cause some damage. When the new shocks are in place, you may need to jack the axle beam up a bit to connect the lower shock mount.
Paul
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old June 24th, 2011, 15:35   #4
PDJetta
PDJetta's Avatar
I broke one and just replaced the single spring. I bought the replacement at 1stvwparts.com (a VW dealer with online sales) and saved about $45 over what my local dealer charged. I disconnected the rear shock on its upper mounting. You are supposed to replace the two shock mount bolts if you remove them, but I did not have new ones, so I reused the old ones. No issues so far.
You don't need a spring compressor. Note to disconnect the ABS sensor wire from its retainer and watch the brake lines.
--Nate
Old June 24th, 2011, 20:01   #5
coalminer16
TDI(s): Golf 2004
I stated the spring compressor way as there isn't any need to disconnect anything that way and no need for bolts. But you can do it taking more things apart as well. You can rent the spring compressor from most auto stores.
Old June 24th, 2011, 20:32   #6
lglamb
for alternative springs, do a site search on 'moog springs'.
Here's a sample thread I have saved for reference...
http://forums.tdiclub.com/showthread...=287469&page=2
lglamb is offline   Reply With Quote
Old June 25th, 2011, 06:12   #7
giw
TDI(s): 99 jetta
all thank you i would have certaily ripped the abs out if you guys didnt respond
Old June 25th, 2011, 06:49   #8
davebugs
Check your axle beam bushings. If they haven't been done they are way overdue. And you're probbaly getting some noise from them and possibly even handling issues.
davebugs is offline   Reply With Quote
Old June 26th, 2011, 09:49   #9
PDJetta
PDJetta's Avatar
True if you have one that fits. I did try my spring compressor first, but it would not fit up on the spring with it in the car.
--Nate
Time to replace all coil springs - 2000 tdi mag2 VW MKIV-A4 TDIs (VE and PD) 12 May 10th, 2011 21:59
WTB: VR6 Front Springs, Jetta Wagon Rear Springs OlyTDI Private TDI Items for Sale/Wanted 15 May 8th, 2010 08:35
rear coil springs replace or use rubber spacers vwluca VW MKIV-A4 TDIs (VE and PD) 4 September 24th, 2008 19:03
Special tool to replace front shocks/springs? PseudoFinn TDI 101 23 January 1st, 2007 14:16
Should I replace my springs? DareDiesel Upgrades (non TDI Engine related) 0 November 30th, 2004 21:29
Page generated in 0.12179 seconds with 10 queries
[Output: 92.12 Kb. compressed to 78.91 Kb. by saving 13.21 Kb. (14.34%)]
