Old August 21st, 2011, 16:57   #31
swacapt
Wow! There is a second relay panel behind the primary relay panel. There are three more radiator fan relays there. Two are labeled 373 and one is 370. There is also a very large (1+ inch across) blade type 40a fuse (below and left of the 370 relay). After finding and testing the three relays, I found the fuse. Well, that was it. Apparently when the fan died, it overheated and took out this big fuse. The #25 fuse on the main cabin panel however did not blow. Looks like I might have this fixed.
swacapt is offline   Reply With Quote
Old August 22nd, 2011, 02:00   #32
thundershorts
glad I was able to point you in the right direction...
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old September 21st, 2011, 11:48   #33
Quest4TDI
Originally Posted by Quest4TDI View Post
I'm having similar symptoms as the original poster.
AC seemed to suddenly quit working from one day to the next, based upon what my wife has described to me (I rarely drive the Passat).
1) I pulled the 384 relay, and a quick visual didn't show any obvious signs of problems. May need to pull it again and check with a magnifying glass (middle-age eyesight sucks).
2) Check for operation of the passenger-side electric fan, and it comes on with the AC on.
3) Checked the AC fuse (fuse #25 if I recall correctly) and that fuse is fine.
4) Inside temperature display is operational
Any other diagnostics I should perform before I either decide to buy a replacement relay and easter-egg it to see if it does the trick, or before I go to an AC specialist to have the whole system checked? I don't believe we've ever had the freon recharged, but the sudden change would lead me to believe that it's not the freon unless there was a catastrophic failure.
If the compressor turns out bad, it looks like I should have the following replaced:
- the compressor (Sanden or Denso) (is a Sanden-Behr compressor the same brand?)
- the drier
- is there an orifice tube to replace?
- is there an expansion valve to replace?
thanks,
Herb
384 relay bought from 1stVWparts solved the problem. AC is cold again.
Plan on inspecting my old relay with a magnifying glass to look for bad solder joints.
Herb
'05 Passat TDI wagon
Candy White / Grey Leather
Leather package with wood
17" Factory Alloys
Phatbox
Quest4TDI is offline   Reply With Quote
WTB: 03-05 passat sedan/wagon or jetta wagon reynolcj TDI Cars for Sale/Wanted 4 February 27th, 2010 11:32
Considering trade: Passat Wagon 4Motion for my '05 Passat GLS TDI Wagon wsalopek TDI Cars for Sale/Wanted 22 January 23rd, 2007 08:51
WTB TDI wagon: 04-05 Passat or 03-05 Jetta dirty dan TDI Cars for Sale/Wanted 3 July 16th, 2006 20:05
05 Passat cruise stops working discodog VW B5 Passat TDIs 5 February 23rd, 2005 06:36
Passat wagon backup lights not working DJGeorge VW MKIII-A3/B4 TDIs 8 December 11th, 2004 16:54
Page generated in 0.13494 seconds with 10 queries
[Output: 59.39 Kb. compressed to 54.03 Kb. by saving 5.37 Kb. (9.03%)]
