Old June 20th, 2011, 06:02   #1
hrjack99
Default 2001 TDI Beetle lift pump
I have a 2001 Beetle that is not getting fuel to the fuel filter. The manual I have says the fuel pump fuse is 2-28 at 15amps. I do not have a fuse or fuse holder hardware at 2-28. Does anyone know where the correct fuse is?
Thanks,
2011 Jetta TDI
hrjack99 is offline   Reply With Quote
Old June 20th, 2011, 06:15   #2
d2305
TDI(s): 2012 Jetta
A 2001 Beetle doesn't have a lift pump.
d2305 is offline   Reply With Quote
Old June 20th, 2011, 06:17   #3
hrjack99
So the IP creates a vacuum to lift the diesel? The hose to the fuel filter seems dry.
2011 Jetta TDI
Old June 20th, 2011, 06:25   #4
DanG144
There is no lift pump on your 2001 car.
If you have an air leak, the pump under the hood (timing belt driven) will not be able to pull fuel from the tank.
If you changed the filter or disturbed the fuel system in anyway, that will cause it to drain back to the tank.
The best option is to use a vacuum pump (mityvac hand pump is commonly used) to pull fuel from the tank.
It is common for cars the age of yours to have a plugged fuel pickup assembly in it.
SC GTG June 8
Old June 20th, 2011, 06:26   #5
DanG144
SC GTG June 8
Old June 20th, 2011, 06:27   #6
DanG144
Car won't start troubleshooting, by Whitedog.
SC GTG June 8
Old June 20th, 2011, 06:33   #7
jettawreck
jettawreck's Avatar
Yep, the manual tries to cover all the gasser and diesel models, but doesn't distinguish very well between the many versions.
Air leak in the fuel delivery lines/fittings or a clogged/broken fuel pickup assembly.
2004 Cadillac SLS (wife's)
Old June 20th, 2011, 06:55   #8
hrjack99
Thanks guys, I wil bleed the system and try again.
2011 Jetta TDI
Old July 11th, 2011, 17:35   #9
slam
Fuel Economy: 40 at best, ***?
Hrjack is this the car you are trying to find the pump pressure on?
slam is offline   Reply With Quote
Old July 11th, 2011, 19:23   #10
AndyBees
AndyBees's Avatar
Fuel Economy: life time average above 50 MPG
This may not work for a modern TDI ALH MKIV ................but, in desperation, I have placed a "rag" around a compressed air hose and put it in the fuel filler hole .........yes, blowed fuel up to the filter and out on the old MK1s! ......worked!
2000 Jetta TDI, 50+ overall average (no tune)
300k mile mark on 12/28/11
427 fill-ups, in Excel spreadsheet, 323k miles...
'84 Vanagon ALH TDI engine (32 mpg), Polaris Diesel ATV, Allegro Bay RV 5.9 cummins
VWs 40 years, VW diesels 33 years, ALH TDIs 11 years
Old July 12th, 2011, 03:16   #11
DanG144
It will work, if you don't split the fuel tank.
SC GTG June 8
PD lift pump in New Beetle???? sullyTDI TDI 101 3 February 14th, 2010 19:27
Does a 99 Beetle TDI have a lift pump 4bostons TDI 101 1 September 22nd, 2008 18:24
lift pump on new beetle?? green_bugger TDI 101 3 January 17th, 2008 15:21
lift pump on new beetle green_bugger Private TDI Items for Sale/Wanted 1 January 17th, 2008 06:23
Is there a "lift Pump" on my 2001 NB?? leroy_in_fresno VW MKIV-A4 TDIs (VE and PD) 5 September 29th, 2005 19:48
Page generated in 0.14578 seconds with 10 queries
[Output: 98.17 Kb. compressed to 82.46 Kb. by saving 15.72 Kb. (16.01%)]
