Old June 18th, 2011, 22:03   #1
ruavol2
Location: Bristol, Tennessee Birthplace of Country Music
Fuel Economy: 38.2
Default Can you collapse the caliper piston on a Passat without the special tool?
I need to change the brake pads on my Passat 2004 TDI. I saw a few videos on how to do this. I have changed many on my FORD truck. All you need is a larger C clamp to do this. Can this be done with simple tools rather than having to find and buy one specifically for that...........now......the reason I ask this is because I have not seen the rear caliper piston closeup as two of my lug nuts one on each rear side have become stripped. Which will be my next post to the forum. Tips on how to correct that. Man the metal on that lug nut is soft.
Any thoughts on if a C clamp or other simple device can be used..? Any support is greatly appreciated. Thank you.
ruavol2 is offline   Reply With Quote
Old June 18th, 2011, 22:05   #2
compu_85
Gadget Guy
compu_85's Avatar
You can get a caliper rewind tool for a free rental at most auto parts stores. You have to screw it back in, you can't just press.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old June 18th, 2011, 22:10   #3
Vince Waldon
Vince Waldon's Avatar
I gather you're talking about the rear disc brakes.
If so, unlike the front disc calipers which *can* simply be compressed with a c-clamp etc, the rear brake calipers need to be rotated as they are compressed, due to the emergency brake mechanism only found on the rear brakes.
There's a special tool your can buy/rent... you can also turn 'em with waterpump pliers if you're slow and careful. If you don't rotate 'em while compressing you'll ruin the caliper unfortunately.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old June 18th, 2011, 22:11   #4
AndyBees
AndyBees's Avatar
I use a C-clamp on the front.........presses in with no issues. About two weeks ago, I did the front pads on my brother's '02 in about half hour! No reported problems. I have done my '00 Jetta the same way twice on the front and three times on the rear with no issues!
On the rear, I've used a combo of C-clamp and pliers to crank/screw it back in. It's a slow procedure but can be done!
'84 Vanagon '02 ALH TDI engine(32 to 35+ MPGs consistently) Malone Stage 1 tune. Road trip to Nova Scotia 2013. Road trip to Alaska summer 2014 & 2016, 11k & 12k miles. 80k miles on install, Jetta Cluster odometer currently at 209k miles.
Old June 19th, 2011, 05:28   #5
MonsterTDI09
MonsterTDI09's Avatar
Use a tougue wrench on the lug bolts.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old June 19th, 2011, 08:14   #6
Franko6
Truthfully, the tool is inexpensive. buy it. But pump pliers will work.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old June 19th, 2011, 09:28   #7
VWBeamer
Fuel Economy: 42.79 mpg Woot!
Got mine for 20 bucks at harbor freight.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old June 19th, 2011, 09:30   #8
newtdidave
I used to do it with pliers and waterpumps....but the tool saved me a lot of hassle, and three times as fast.
newtdidave is offline   Reply With Quote
Old June 19th, 2011, 11:34   #9
Vince Waldon
Originally Posted by newtdidave View Post
three times as fast
Agreed... plus with pliers you can only retract it so far... and you constantly risk nicking the dust boot.
Pliers are great if you're in a pinch, but IMHO this is one of those wonderful times when you can turn a pain-in-the-butt job into a piece-of-cake job by obtaining the right tool.
Does Brake Caliper Reset Tool not working = caliper piston problem? oly VW MKIV-A4 TDIs (VE and PD) 11 November 13th, 2016 11:16
Caliper piston supplier 4x4toy VW MKIII-A3/B4 TDIs 7 April 3rd, 2010 22:11
Caliper reset tool trapped in caliper! dqa VW MKIV-A4 TDIs (VE and PD) 2 May 19th, 2009 06:36
rear caliper piston just spins? VFchicago88 TDI 101 5 February 17th, 2008 18:33
Great deal on brake caliper tool (piston wind back tool) larsbc West Coast Canada/USA 0 September 17th, 2006 00:05
Page generated in 0.14778 seconds with 10 queries
[Output: 93.84 Kb. compressed to 80.43 Kb. by saving 13.41 Kb. (14.29%)]
