Old June 18th, 2011, 06:33   #1
swartzzz
TDI(s): None, yet
Default Please help... Code 05522
Okay guys. Got Emissions Workshop code spit out on the 06 TDi. The issue came back as Code 05522 Height sensor / charge pressure sensor implausauble relation value or resistance too great.
Any thoughts? Should I just order and replace the charge pressure sensor? Cleared codes, and everything seems okay for now, but we are getting some wierd issues. At time after initial startup, the car simply has no power and no boost. Car goes, but simply doesn't have any power. You simply can shut car off, and restart and we are back to normal! Thoughts?
Greg
swartzzz is offline   Reply With Quote
Old June 18th, 2011, 09:22   #2
dzcad90
Rolex & gin
dzcad90's Avatar
Classic signs of Limp Mode, where the ECU regulates engine output to safe levels in the case where the engine cannot properly control charge (turbo) pressure.
Sometimes it's as simple as one of the intake pipes having a loose clamp, but as always it can be a deeper issue than that. Do some searches on "Limp Mode" and you will find plenty of information to help you get started on a diagnosis.
- Don
'97 Jetta TDI - 135K - R.I.P. 10/22/03
'03 Jetta TDI - Silver / Black Leather, 161K miles - Sold.
'09 Jetta TDI Sedan - Sold!
'14 Passat TDI SEL - Blue / Black Leather
VCDS Available in Chicagoland - trbodsl@gmail.com
dzcad90 is offline   Reply With Quote
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent Fuels & Lubricants 4 February 21st, 2011 04:21
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent VW MKIV-A4 TDIs (VE and PD) 5 February 18th, 2011 14:39
P0226 Throttle Pedal code went away and was replaced with a glow plug code. Fixed. thordehr VW MKIV-A4 TDIs (VE and PD) 0 June 6th, 2010 21:11
Airbag fault code together with low voltage code msa6 TDI 101 5 April 24th, 2008 13:38
Vag com code 00527 - code reader P1161 tdidieselbobny TDI 101 4 December 11th, 2006 13:07
Page generated in 0.12395 seconds with 10 queries
[Output: 53.00 Kb. compressed to 48.95 Kb. by saving 4.06 Kb. (7.66%)]
