Old June 17th, 2011, 12:48   #1
dobeonguard
dobeonguard's Avatar
TDI(s): 98 Jetta TDi
Default Water leaking on to passenger floor
Hello,
I tried searching for this but so many different topics came up. I have a MkIII Jetta and when I use the A/C for an extended period of time I get water that drains on to the passenger floor. It comes from from the very back close to the center divider. I can feel a pipe behind the carpet, I haven't torn into anything beyond that. I am sure this is the condenser draining, but I didn't know this drain was there. What usually needs replaced? And how much is it?
dobeonguard is offline   Reply With Quote
Old June 17th, 2011, 13:24   #2
john.jackson9213
TDI(s): 1996 B4V
First thing I would do is go under the car and look for the hole that the drain hose should be comming out of. Perhaps the drain hose has moved into the cabin?
Next I would check the other end of the drain hose. Is it still properly connected to the evaporator housing?
Then I would pull up the carpet and see if the hose was still OK. If not, replace the hose. Should not cost an arm and a leg
john.jackson9213 is offline   Reply With Quote
Old June 17th, 2011, 13:53   #3
dobeonguard
Thanks John. I went out and took a look. The leak seems to be a little bit further up because the water is dripping down on the foam/rubber covering that is under the glovebox. I am not the smallest guy in the world and don't feel like hanging upside down at the moment to take that off. I will dig into it next week.
Old June 18th, 2011, 02:27   #4
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
While there are several possibilities, my guess is the A/C drain is clogged.
A little compressed air or some string trimmer line can clear the drain. Be careful however you don't want to damage the drain line.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old June 18th, 2011, 17:59   #5
Redlabel6
Redlabel6's Avatar
Fuel Economy: A3 51mpg, B5.5 38mpg
Drain is clogged, Here are some good pics form Dan Reeds site
http://forums.vwvortex.com/showthrea...-Drain-picture
98 Jetta TDI, Classic Green-Sold and Missed
05 Passat GLX TDI Stonehenge Gray
07 Passat 2.0 Wagon Gasser
05 Jetta 2.5 Gasser
73 Karmann Ghia Autostick
Redlabel6 is offline   Reply With Quote
Old June 19th, 2011, 07:07   #6
57ringo
57ringo's Avatar
I just checked mine yesterday. It was leaking inside since I put a new heater core in. The problem was it has a plastic drain tube that is part of the A/c-heater housing that barely protrudes through the firewall. There is a rubber grommet that seals the firewall and the plastic tube. When I put the plastic tube through the firewall, I didn't get it in the hole of the grommet and thus blocking the drain tube and running back in the car. I put it on the lift, worked the grommet in place in the firewall and around the drain tube. There is a little flap on the firewall insulation you can fold up to see this rubber grommet...the rubber grommet also has a flap on it. I had to take the big plastic shield off that's under the engine to get to all of this.....hope that helps
2006 Jetta TDI
2005 Dodge Quad cab 4x4 CTD
1992 KW T800
several John Deere's and more
http://www.youtube.com/watch?v=PnlxN0aT_ys
57ringo is offline   Reply With Quote
Old June 20th, 2011, 14:32   #7
visionlogic
visionlogic's Avatar
Fuel Economy: 47 avg
I once was given an old Camry due to a clogged condensate drain. The car kept dying on the folks that owned it, wouldn't restart unless it sat for a couple of days. Their mechanic couldn't figure out the problem and the owners didn't want to spend any more money on the old car so they ask me if I wanted it. I took it, drove it without any problem until the weather warmed and I started using the A/C.
One day I took a right hand turn and spit-sputter, the engine died and couldn't be restarted. For some reason I looked down at the footwell and noticed dampness around the go pedal. Ran my hand around the center hump under the dash and everything was soaked. And what do you think was installed in that area? The ECU! I pulled it out, took the case apart, and it was full of water. The centrifugal force of the right turn caused the full condensate pan to dump its water out through a seam on the left, right onto, and into, to ECU. I dried out and cleaned up the ECU and she started up and ran fine. Unclogged the drain hose and put some sealant along the condensate pan seam and never had that problem again.
Living outside the statist quo... "All the disasters that have wrecked your world came from your leaders' attempts to evade the fact that 'A' is 'A' ." -- John Galt | On Google+
visionlogic is offline   Reply With Quote
Water on rear passenger floor + broken door handle. azimuth VW MKIII-A3/B4 TDIs 8 January 4th, 2008 10:10
Water leaking on driver floor Chepito TDI 101 13 November 9th, 2007 05:02
water on passenger side floor lecjec General VW Discussion 2 October 12th, 2007 05:21
Water on passenger side floor JohnnyCanal VW MKIV-A4 TDIs (VE and PD) 6 January 11th, 2007 17:18
I found a lake of water on the passenger side floor! almeizy VW MKIV-A4 TDIs (VE and PD) 25 November 7th, 2002 19:54
Page generated in 0.12563 seconds with 10 queries
[Output: 82.35 Kb. compressed to 71.47 Kb. by saving 10.88 Kb. (13.21%)]
