Old June 17th, 2011, 09:44   #1
Rudy 'D'
Fuel Economy: 41
Default Intercooler upgrade
I have an '04 Golf TDI (BEW) that is currently stock. I am planning on a turbo upgrade to a VNT 17/22.
Do I need a larger/better intercooler? If so, Which one?
Thanks.
Rudy 'D' is offline   Reply With Quote
Old June 17th, 2011, 12:15   #2
LNXGUY
LNXGUY's Avatar
Do you need one? No.. You've got a few more things to upgrade until you get to the IC..
Bill
LNXGUY is offline   Reply With Quote
Old June 17th, 2011, 14:24   #3
Jump.Wire
TDI(s): 2001 GL
IC upgrade should be one of the last things on your mind. Upgrade to a turbo back exhaust first.
Jump.Wire is offline   Reply With Quote
Old June 17th, 2011, 19:04   #4
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
Basically it goes like this...
Add more fuel until you smoke (Nozzles)
Add more air to clear it up (Turbo)
Replace your clutch because it's now smoked.
Add more fuel as needed.
Upgrade DP, exhaust, IC & piping.
Start obsessing about a GTBxxxx
Let me amend this a bit...
for your BEW it's more like
Tune
Turbo
Clutch
Exhaust/IC
More fuel (Bigger injectors)
Re-Tune
Now obsess about huge turbo, rods, LSD, ported head, even bigger injectors...
'01 Jetta GLS, 5 sp, Black on Black, Leather, Sun Roof, MFSW, Monsoon, Cold Weather Pkg., Full LED interior, always a work in progress
FlyTDI Guy is offline   Reply With Quote
Old June 19th, 2011, 16:40   #5
Richard55
Richard55's Avatar
TDI(s): 2000 NB
Fuel Economy: 52 MPG
I love this progression chart lol
Tune
Turbo
Clutch
Exhaust/IC
Re-Tune
"Speed cost money, how fast do you want to go."
RC6, 11 mm IP, 17/22, egr delete, 3 inch exhaust, 2.5" custom lower IC pipe, lift pump, "LurkerMike" custom DP, PP764, MAF deleted, 3 bar MAP, stage 2-14 lbs flywheel and clutch assy. Autometer Colbalt 2 Oil Pressure, Boost and EGT guages. K&N air filter. 18" Motegi wheels. vent and snowectomies. 55 watt HIDs
Richard55 is offline   Reply With Quote
Old June 19th, 2011, 18:04   #6
dieseleux
Théoricien -TDIClub Contributor
dieseleux's Avatar
TDI(s): Jetta TDI 02
Fuel Economy: 4.2L/100km
Me too!
+1
Dieseleux
Si votre seul outil est un marteau, toute les solution ressemble à des clou.
If your only tool is a hammer, all the solution looks like nail.
dieseleux is offline   Reply With Quote
Old June 19th, 2011, 18:30   #7
Rudy 'D'
Fuel Economy: 41
Tune
Turbo
Clutch
Exhaust/IC
Re-Tune
Thanks for the advice.
Seems like everyone thinks the stock BEW (PD) injectors are big enough for mild mods.
You guys rock. Thanks again.
Old June 21st, 2011, 19:27   #8
darkhorse
darkhorse's Avatar
Fuel Economy: mid 40's
They can easily get you to 150hp & a bit beyond.
'06 Golf GLS 5 speed, Evo skid plate, Koni FSD's with Shine RSS, SBC stage 3, SMF, KERMA custom tune, R 32 snorkel,PD 150 airbox,MAF,TIP & manifold, K3B,R 783's, Colt stage 2, EJ SMIC, piping by ID Parts, Whitbread 2.5" DP, Aero muffler, 3"KERMA SS pipes, Sigma 5 short shifter, .681 5th gear & Peloquin, Nicktane 1 um fuel filter & DG/Amsoil bypass filter.
darkhorse is offline   Reply With Quote
Old June 23rd, 2011, 05:02   #9
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
You are a ways from needing injectors yes. But I am still interested in the whole intercooler question as there isn't many options for the PD engine that is bolt on. I am interested due to the trailer towing and seeing the intake temps from the scan gauge rise a lot.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car-4 door, 1.9 TD aaz, 5 spd
1981 Caddy VW truck-Topper with it
2004 Golf-2 inch lift, Q-loader stage 1 tune
Vag-Com owner
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old June 23rd, 2011, 05:58   #10
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Towing a trailer will kill your intake temps. I have a Eurojet SMIC and it does a great job until I put a heavy load on it with the trailer.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old June 23rd, 2011, 06:56   #11
coalminer16
TDI(s): Golf 2004
I bought this spring the vented fender liner as my OEM one was cracked up some anyways. It helped a little but still would like a better intercooler for the PD.
Vag-Com owner
Old June 24th, 2011, 13:15   #12
VWBeamer
Fuel Economy: 42.79 mpg Woot!
If it fits a MKIV ALH, it will fit a PD with little trouble, in fact it's almost the same if you run a 17/22.
Only real difference is where it joins the intake.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old June 24th, 2011, 13:26   #13
diesel-dave
diesel-dave's Avatar
Plug in a scan guage, drive around and monitor your air intake temps
This will tell you if your intercooler is good enough
Again you live in the south
2003 Bora Wagon TDI Bosio R520's,colt cam, VNT 17
q loader. no smoke and so on
2001 Beetle TDI GLS Bosio 764 7 hole's, qloader, VNT 15 and so on
2010 JSW wagon DSG loaded
2003 golf auto PP520's
diesel-dave is offline   Reply With Quote
Intercooler Upgrade catching45 TDI Power Enhancements 6 August 4th, 2010 21:39
intercooler upgrade tdi_sport TDI Power Enhancements 35 June 26th, 2006 05:13
How necessary is an intercooler upgrade?? disel_freak TDI Power Enhancements 11 July 15th, 2005 20:19
Intercooler upgrade Rui Augusto TDI Power Enhancements 1 October 23rd, 2000 07:19
Intercooler Upgrade Using 00' S4 Intercooler Peter Cheuk TDI Power Enhancements 13 March 9th, 2000 11:39
Page generated in 0.16674 seconds with 10 queries
[Output: 118.12 Kb. compressed to 99.00 Kb. by saving 19.11 Kb. (16.18%)]
