Old June 16th, 2011, 11:33   #1
anjuautos
Default 1998 volkswagen passat 1.9 tdi
please help me for this problem ,1998 volkswagen passat 1.9 tdi AT have a problem .while running the car it get off after 25 to 30 kilometers and only it start after 20 to 30 min ,the scanned report is given below please anybody can help me
DTC
code (1) 00765 modulating piston movement sender G149
code (2) 1268 metering control N146
The fuel pump is allready overhauled by Bosch authorised service centre and they changed sensors and control unit inside the pump,i checked the wiring and i thinks its ok
anjuautos is offline   Reply With Quote
Old June 16th, 2011, 11:45   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Did you clear the codes after you re-installed the injection pump?
Has the little rubber tube inside the ECU been replaced?
Welcome aboard, Anju!
dieseldorf is online now   Reply With Quote
Old June 16th, 2011, 11:51   #3
JFettig
JFettig's Avatar
TDI(s): B5 Passat
Fuel Economy: 42 MPG
What engine code?
It should have your standard MAP that is in a charge air pipe(see the link in my sig for pics of my 98 B5)
Try the ross-tech site for those codes.
Jon
Malone Tuning Dealer Tuning 1996 to present, including Common Rail and DSG!
1998 B5 Passat TDI
Porsche 944 Turbo PD130
ALH parts for sale ECU Socketing
2 sets of upgraded PD valve springs available
JFettig is offline   Reply With Quote
Old June 16th, 2011, 12:03   #4
anjuautos
Engine code is AFN
and VIN is WVWZZZ3BZXE058676
Model description is Passat sed,Basic1481 TDI 4at
Old June 16th, 2011, 12:06   #5
anjuautos
yes i cleared the codes and i didn't see the rubber tube in side the ecu ,thanks
Old June 16th, 2011, 12:08   #6
dieseldorf
top post dawg
dieseldorf's Avatar
Well, this issue you are having is either a bad rebuilt pump (very common in America since there is only one shop in the entire country that can successfully repair them) or you've got a wiring problem.
I think you've got to check that multi point connector on the pump and must verify the condition of the earth connections under the bonnet.
Old June 17th, 2011, 09:35   #7
anjuautos
Originally Posted by JFettig View Post
What engine code?
Jon
yes engine is same in your ,picture ,map is in the charge air pipe
1998 Volkswagen Jetta TDI – Richmond, VA- For Sale JanettMZ TDI Cars for Sale/Wanted 4 March 4th, 2010 13:25
FS: 1998 Volkswagen VW Jetta TDI - $4200 (Chicago, IL) patinum TDI Cars for Sale/Wanted 2 March 27th, 2009 09:34
1998 Volkswagen Jetta TDI Diesel 5 speed makemesmile TDI Cars for Sale/Wanted 2 June 9th, 2008 18:25
1998 volkswagen jetta TDI superman2010 Jetta/Bora/Vento TDI Picture Gallery 3 March 28th, 2008 15:01
FS: 1998 Volkswagen Jetta TDI $7750 downcycle TDI Cars for Sale/Wanted 0 August 3rd, 2006 18:41
Page generated in 0.13342 seconds with 10 queries
[Output: 77.28 Kb. compressed to 66.97 Kb. by saving 10.31 Kb. (13.34%)]
