| Vendor & GroupBuy items for sale VW TDI/Diesel related items for sale by vendors and Groupbuys. The only commercial posts to these forums are that of Vendors with TDI related equipment. To start a post, you must be a Registered Vendor. You may periodically post a note about products you may have for sale/services so long you indicate clearly you are from the company selling these products/services. The right to discontinue this practice & remove excessive posts remains with the operators of TDIClub. Please note there is also a webpage of TDI Vendors"
Group-buys are permited if sponsored by a registered vendor. |
June 12th, 2011, 13:36
#1
TD Tuning Chip Sale!
I figured it was time for another special of some sort, so from now until the end of the month order a set of chips for your 96-99.5 TDI and receive a 10% discount using discount code "A3B410" at checkout.
You can find various options for MK3 and B4 cars here:
http://tdtuning.com/store/index.php?...A3B4Chiptuning
(Check out stage 1 if you have a '96 Passat with the original BK ECU)
And for '98-99.5 MK4 cars:
http://tdtuning.com/store/index.php?...ow&ref=9800ALH
Your ECU part number is required to make the correct chips so please look into that.
June 19th, 2011, 11:12
#2
I'm extending this deal to cover the rest of the tuning for a bit. Use code OBD+10 when you order tuning and tuning with loaders for 2000+ model year vehicles and save 10%!
June 26th, 2011, 19:31
#3
The response has been great. Lets keep this going through Thursday
June 26th, 2011, 20:25
#4
Mike THANK YOU for doing this!
I am so happy with the tune you hooked me up with and am looking forward to having you update it here in another few months!
Great deal and a AWESOME vendor thanks again!
Jeff
June 28th, 2011, 15:10
#5
Jeff
Thanks Jeff! What's next on your upgrade agenda?
June 29th, 2011, 05:57
#6
Question, does the stage 3 upgrade give good part throttle fuel economy, essentially the same as the others? I am looking at this and want to keep good fuel economy for when I am not using the power  .
June 29th, 2011, 08:43
#7
I have yet to hear of fuel economy going down (most people report an improvement). Torque is much improved at low RPM with that tune so I think that in some ways the economy could be better since you don't have to rev the engine as high to make the same power.
June 30th, 2011, 13:50
#8
Just about 10 hours to go.
June 30th, 2011, 19:44
#9
Anything for 1Z with GT1749VB and DLC1019 nozzles ? Updated metal PCM
Mike
1996 Passat TDi Stage 3+ TDT VNT 26psi
2008 GTi 4D DSG moded wifey mobile
2002 BMW K1200RS Ohlins suspended
June 30th, 2011, 22:54
#10
That sounds doable. Maybe send me a pm and we can talk about it.
