Old June 9th, 2011, 05:40   #1
jettajim
Fuel Economy: 5spd=56 lifetime, '12 Passat gasser-terrible
Default How do I know if alternator pulley is bad
Hi,
On my wife's '00 Jetta TDI with 174,000miles, I get the 'noise' everyone is talking about when the ac is on. Many people said it's the alt pulley.
Someone said to check the alt pulley, stick a screw driver in the vanes to prevent it from rotating in one direction. I did this and the pulley only rotates in one direction--as it should. Now, does this mean that the 'noise' I hear only when the ac is on and only sometimes, is caused by a bad ac clutch? When I turn off the ac, the noise goes away.
I changed the alternator about 40K miles ago with a reblt Bosch. The ac compressor was changed about 60k miles ago.
Thanks for your help!
Jim
jettajim is offline   Reply With Quote
Old June 9th, 2011, 08:03   #2
paramedick
paramedick's Avatar
1) remove serpentine belt from alternator pulley
2) stick small screwdriver in the fan blades of alternator thru case holes
3) attempt to spin the pulley in both directions. Should freewheel in CCW rotation, lock up in CW rotation.
An all TDI Family!!
Old June 9th, 2011, 09:33   #3
benIV
benIV's Avatar
Can you check it without pinning the alternator fan blades? eg. just spinning the pulley by hand both ways?
OCD TDICLUB MEMBER #6
2003 TDI Mafia Member
1981 Mercedes 300D 350K RIP
1974 VW Super Beetle convertible 200K+
benIV is offline   Reply With Quote
Old June 9th, 2011, 09:40   #4
jettajim
Thanks for the reply. I did that and it locks in one direction so does that mean the alt pulley is not the pulley making the noise?
Thanks again for your help.
Jim
Old June 9th, 2011, 09:44   #5
benIV
benIV's Avatar
if it locks in only one direction (CW) and spins free in the other (CCW) then the clutch pulley is working properly.
did you check the alt. pulley or the ac pulley?
Old June 9th, 2011, 11:15   #6
jettajim
Thanks Ben.
The alt pulley locked in one direction when I inserted a screw driver into the blades of the alternator. It spun freely in the other direction. This is all with the belt off, of course.
I didn't check the ac pulley. How is this done? I read about people having the clutch come completely off.
Thanks again for the help!
Jim
Old June 9th, 2011, 15:05   #7
benIV
benIV's Avatar
to check the ac clutch pulley, i found these:
http://forums.tdiclub.com/showthread...ight=ac+clutch
second link mentions a clicking noise and a possible loose pulley central nut.
just for starters, use the search tab right below your name near the top of the page.
Old June 10th, 2011, 05:06   #8
jettajim
Thanks Ben, I'll check them out.
Jim
Replace alternator pulley when replacing idler pulley?/Examining Belt Tensioner meccaA4 TDI 101 3 August 16th, 2010 11:53
Runtime w/ Bad alternator (pulley?) cleaver TDI 101 2 April 9th, 2010 05:15
Bad alternator pulley? bendiesel TDI 101 17 March 18th, 2010 17:42
Alternator Pulley bad, now Alternator? danielalves VW MKIV-A4 TDIs (VE and PD) 6 July 28th, 2009 04:32
Alternator Pulley repair tool w/b5.5 alternator pulley 06JettaTDIdsg Private TDI Items for Sale/Wanted 1 October 21st, 2008 13:27
Page generated in 0.13766 seconds with 10 queries
[Output: 84.27 Kb. compressed to 72.17 Kb. by saving 12.10 Kb. (14.36%)]
