Old June 7th, 2011, 08:32   #1
pretzook
pretzook's Avatar
Fuel Economy: A solid 35 mpg
Default Dayco vs idparts Timing Belt Kit???
My local diesel shop uses the Dayco kits, and I have normally bought parts from idparts.com There is a $154 difference in the cost... I'm sure it has to do with the parts included... any direction would be helpful. Thank you.
pretzook is offline   Reply With Quote
Old June 7th, 2011, 08:50   #2
benIV
benIV's Avatar
the standard tb kit from idparts comes with a dayco belt and is 309.95.
it doesn't list the manf for the other parts, but i assume you could call and ask, or use google chat.
OCD TDICLUB MEMBER #6
2003 TDI Mafia Member
1981 Mercedes 300D 350K RIP
1974 VW Super Beetle convertible 200K+
benIV is offline   Reply With Quote
Old June 7th, 2011, 09:12   #3
CopaMundial
Fuel Economy: 42mpg, grinning the whole time
If there's $154 difference in price then I'd be willing to be that it's not a matter of mark-ups or brand of belt... the local guy's 'kit' simply doesn't include as much stuff in it.
The kits from TDIClub vendors include a lot of stuff that experience (largely from this forum) has shown to be critical. Someone less familiar with these cars specifically may not plan some of that stuff into their parts list.
IDParts offers two different TB kits for ALH cars. One is the regular kit $309 and the other is the 'high mileage kit' (intended for the 3rd or 4th TB change on cars exceeding 200k miles) at $450.
How much is the kit from the local guy, and does it include the same stuff?
Keep in mind that failure of the 'other stuff' (water pump, rollers, tensioner) is more likely than failure of the belt itself.
CopaMundial is offline   Reply With Quote
Old June 7th, 2011, 09:41   #4
Corsair
Fuel Economy: 52/48/??
ditto the above, and...
You might want to read through some of the timing belt related posts here (there are so many !). Now is the time to make sure you choose a shop that has experience with these TDIs, before doing the TB job. There is a listing of known good TDI mechanics on this site- they know these engines and can offer references.
There are several critical aspects to getting a timing belt job done correctly, and they're not all obvious. For instance- you'll need to replace the engine mount bolts that are removed to do the job. (not re-use). They are one-time-use bolts, and are prone to failure if re-used.
Note if the timing belt job is done incorrectly and something gums up, it's not merely an issue of doing it over again, as in going around for another try. Rather, what happens is expensive parts in the engine collide with each other, and major engine work has to be done, then replace all the timing belt stuff again. That's why it's so important to find a mechanic with specific experience going in.
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 300K mi....... 2004 Jetta GL wagon 2.0L (gas) 5-spd
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old June 7th, 2011, 09:42   #5
cevans
Customer Service Ninja and IDParts AssociateVendor
cevans's Avatar
A Dayco timing belt is included by default in our kit. The other items, rollers and such, are INA Germany and the Tensioner is made by Litens in Canada.
Often the "Timing Belt Kits" from belt manufacturers (Continental/CRP or Dayco) only include a belt and tensioner, so often don't address the rollers or serpentine belt. They never include one-time-use hardware either.
Stick with our kit (or a kit from any other TDI Vendor) to do the belt job right, and be sure that the shop understands what each component is to be sure all the necessary items are replaced. The Trusted TDI Mechanics list may be a good place to search for a TDI guru in your area.
IDParts.com / TDIBlog.com
cevans is offline   Reply With Quote
Old June 7th, 2011, 11:22   #6
Alchemist
The Dayco kit has belt, tensioner, idler and rollers. No bolts or water pump as per this link http://www.accessdayco.com/Auto.aspx
Get a complete kit from one of the vendors on this site and look for another shop to do the work. Those guys may be good at what they do, but TDI is out of their comfort zone, or they wouldn't use a partial kit.
Paul
04 Golf, Evo skidplate, South Bend SMF and Stage 3 clutch, ventectomy, 156K miles, RocketChip tune
94 Jetta AHU Conversion, My winter car 99 Ranger about to be TDI
VCDS, Heated shop with hoist
Alchemist is offline   Reply With Quote
Old June 7th, 2011, 14:03   #7
pretzook
pretzook's Avatar
Thank you very much. I have a quote from the local shop in the neighborhood of $800, and that is the belt, tensioner, two rollers, water pump... there is something else, he mentioned the quote included the replacement of 6 essential parts. I'll have to check with him on the engine mount bolts. I have another quote from a vw place - not a dealer, in the neighborhood of $980. I will check out the list on the site for trusted TDI mechanics.
Thank you very much everyone!
Zook
Old June 7th, 2011, 17:06   #8
CopaMundial
If I lived as close as you do to Dennis Marquette (aka Metal Man on the forums... aka www.metalmanparts.com), then I know I wouldn't go anywhere else for stuff that's over my head.
Get the kit from IDParts, or get it from Metal Man (or another of the vendors on here), but either way I'd take it to Metal Man to do the work if I lived up that way.
Old June 8th, 2011, 09:17   #9
tdmsurfguy
tdmsurfguy's Avatar
Fuel Economy: ~50
You could also this link for Bora Parts http://shopping.boraparts.com/produc...products_id=30 I used this kit and had Oldpoopie install it for me in Portland. Great price and Aaron (from runs Bora Parts) doesn't sell the cheap stuff. Another option for you. Good Luck
tdmsurfguy is offline   Reply With Quote
A5 JETTA TDI TIMING BELT KIT BRM $175 and Timing Belt+ alternater pulleyTools $65 kstef Private TDI Items for Sale/Wanted 1 August 29th, 2010 05:05
Timing belt kit oquatanzinwan TDI 101 13 April 4th, 2009 12:35
Which Timing Belt Kit? Savageman69 Ontario 46 May 31st, 2008 10:13
2001 Golf Timing belt question re: 100K belt kit brandtmeister VW MKIV-A4 TDIs (VE and PD) 6 May 14th, 2006 20:58
wtb a timing belt kit, set of rims, and body kit eagleneck Private TDI Items for Sale/Wanted 10 November 5th, 2004 20:54
Page generated in 0.12304 seconds with 10 queries
[Output: 92.05 Kb. compressed to 78.93 Kb. by saving 13.12 Kb. (14.25%)]
