Old June 4th, 2011, 17:26   #1
lowNslow
lowNslow's Avatar
Default MK4 Jetta fuel door will not open
Fuel door switch is good, if you switch it with the trunk switch, the trunk still opens up.
Fuel door actuator is good, put a hot battery to it and it moves.
No voltage at fuel door actuator plug.
No blown fuses, can not find a specific relay for the fuel door.
Any ideas, I am stumped.
lowNslow is offline   Reply With Quote
Old June 6th, 2011, 06:38   #2
lowNslow
lowNslow's Avatar
No one? This is more a inconvenience than a necessity. But I like my cars to all work properly.
Old June 6th, 2011, 07:08   #3
AARodriguez Corp.
AARodriguez Corp.'s Avatar
The fuse is a green 30 amp, you may have a bad switch.
There is no relay for that.
power from car to fuse-to switch-to actuator
I have some helpful videos on my website
look in the installation instructions
http://www.aarodriguezcorp.com/fuel-...mote-kit1.html
http://www.aarodriguezcorp.com/insta...tructions.html
any other questions I'll try to help
AARodriguez Corp. is offline   Reply With Quote
Open fuel door w/VCDS 2006 Jetta? 40X40 OBD Scanners 2 March 7th, 2011 20:18
wtb: fuel filler door, Mk4 Jetta tornado red kpboh Private TDI Items for Sale/Wanted 0 December 22nd, 2010 05:24
Jetta Trunk/Gas Door Interior switches only work with driver's door open Daveinater VW MKV-A5 Golf/Jettas 11 September 7th, 2010 19:22
mayday fuel door will not open hfd95847 Jetta/Bora/Vento TDI Picture Gallery 5 June 7th, 2009 02:28
Helop! 1999 NB Fuel Door wont open. Manual release?? Need fuel! can't open fuel door. Ironforger TDI 101 5 January 16th, 2006 20:27
Page generated in 0.12720 seconds with 10 queries
[Output: 58.12 Kb. compressed to 52.72 Kb. by saving 5.41 Kb. (9.30%)]
