Old June 3rd, 2011, 17:19   #1
vmaxaholic
Default A/C blowing warm air on left side only
Ok, I've found a couple threads on here about this problem and I plan on using them as a guide, but nothing I've found involves the digital temp controls like those found in a package 2, which is my '06 Jetta with dual climate control. All the threads I've seen involve the cable controlled knobs/dials. The A/C is ice cold on the far right and right center vents, and only barely cool from the left center and far left vents. I'm sure this is a blend door problem, just unsure where exactly it's located and how much of a pain in the ass it is to get to and repair compared to the cable controlled kind, or if there is any difference. Any and all help will be greatly appreciated!!
vmaxaholic is offline   Reply With Quote
Old June 4th, 2011, 03:11   #2
nhdoc
Is the air on the left warm (heated) or just ambient? I ask this because I have had cars (not VW) which had this same condition caused by a low charge of refrigerant. The reason is the evaporator will get cold near the expansion valve but not anywhere else when it is low on refrigerant, and if that end of the evap is near the right side the right side vents will get cold while the left side won't. So, you might just make sure you don't have a leak by checking the system pressures using a manifold gauge on both the high and low sides. Just a thought.
nhdoc is offline   Reply With Quote
Old June 4th, 2011, 06:43   #3
vmaxaholic
That's exactly what it is. The air on the left side is not hot like from the heater, it's just no where near as cold as it is on the right. I'll definitely have to look into what you suggest. Thanks very much!
AC Blowing HOT, Not Just Warm CountryBoy VW MKIV-A4 TDIs (VE and PD) 1 July 25th, 2014 18:04
Blower Not Blowing Air CSL06TDI VW MKV-A5 Golf/Jettas 3 August 13th, 2009 17:58
B4 A/C blowing warm this season after 3 perfect seasons. Details of gauge readings... 2TDIguy VW MKIII-A3/B4 TDIs 8 June 26th, 2007 06:19
Help needed re; warm air intake valve setup (on air filter box) neimis Other VW Group TD(I)s 0 January 16th, 2007 21:09
AC Blowing HOT, Not Just Warm CountryBoy VW MKIV-A4 TDIs (VE and PD) 8 January 3rd, 2006 11:03
Page generated in 0.11916 seconds with 10 queries
[Output: 57.06 Kb. compressed to 51.95 Kb. by saving 5.12 Kb. (8.97%)]
