Old May 26th, 2011, 16:35   #1
plyyyy
Fuel Economy: 43.2 so far
Default Is there a difference between diesel fuels in CA
I just bought a 2000 Jetta TDI 5 spped. The car is awesome and I have driven over 300 miles on less than a half a tank of gas. I was looking at the Gas Buddy app on my phone and was noticing that the 2 gas stations that are closest to my house differ in price about 35 cents a gallon for diesel. One station is an Arco and the more expensive is a 76. Is the Arco diesel ok to use in our TDI's? I would never run Arco in my other vehicles because it has always been known as "cheap gas". I appreciate your feedback. Hopefully this info. is not right in front of me and I am just not seeing it.
PLYYYY
plyyyy is offline   Reply With Quote
Old May 28th, 2011, 13:55   #2
tdiatlast
Is there a penalty for double-posting? I suppose not, but try to remove one of your threads, or ask a moderator to do so...
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old May 28th, 2011, 14:41   #3
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
I think you might want to make the measurement a tad bit finer, as in mpg 49.75, and over one two three tank fulls. Then you can see if there are gradation differences (.25,.5 .75, 1 mpg). What you are trying to do here is to even out or compensate just for measurement error over several tank fulls. So for example, if you had filled with Arco and got 50 mpg (on your half a tank) and re TOPPED with 76, you just mucked the variable/s.
If you do notice a difference, then the next question: is it worth the premium????? I have normally bought on price (cheapest) and secondarily on convenience. I have done this over 184,000 miles.
Here is an illustration:
a. 50 mpg /$4.33 per gal ULSD = .0866 per mile driven.
b. 55 mpg / $4.33+.35 (premium)=$4.86 per gal ULSD = .085 per mile driven. In this example, 5 mpg better is SLIGHTLY better (1.9%) @ .35 per gal more (premium).
c. now @ the same prices, the one that gets better mpg is better.
ruking is offline   Reply With Quote
Old May 28th, 2011, 15:19   #4
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
California isn't any different than anywhere else. (At least in this regard.) Buy your fuel from the place that has the most turnover. That way you know that it hasn't been sitting in the tank forever. Fresher is better.
-George Bernard Shaw
Diesel Fuels TDINooby Fuels & Lubricants 8 August 20th, 2010 10:11
Which Diesel fuels to use ... retrogo TDI Fuel Economy 7 May 6th, 2006 22:17
Diesel fuels Russ46 West Coast Canada/USA 1 February 8th, 2003 15:49
High Quality Diesel Fuel FUELS Diesel Buying Boom in the UK SkyPup Fuels & Lubricants 0 October 15th, 2002 17:16
CA Study Defies Conventional Thinking About `Clean` Fuels: Diesel Tops Natural Gas as RED TDI (Diesel) Emissions 4 April 22nd, 2002 07:54
Page generated in 0.14148 seconds with 10 queries
[Output: 64.46 Kb. compressed to 57.72 Kb. by saving 6.74 Kb. (10.46%)]
