Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old May 25th, 2011, 08:37   #1
vwnut20
Fuel Economy: Around 5L/100km
Default 2011 TDI Oil Consumption
Hey guys and gals,
How many of you out there have noticed your TDI's oil consumption. Had my first oil change done 3 months ago at it's recommended interval. I have currently 6500kms+ of oil life according to the MFD. I just happened to check the dipstick and I need to add a quart. Now I know it sounds paranoid but this is my first new car(ever). I'm unfamiliar if TDI's use any amount of oil in between oil changes. I'm use to the old TD which would use maybe a qt every 5 or 6(even more).
No evidence of a leak underneath the car. I have spoken with other TDi drivers which have told me that their car's barely use any oil. I don't drive my car like if I was in the TDI cup race.
Should I be worried or start approaching the dealership about this.
Cheers,
Simon
vwnut20 is offline   Reply With Quote
Old May 25th, 2011, 08:47   #2
jbright
My Jetta hasn't used any oil in 40,000 miles (my spare refill liter remains in the trunk, unopened). If it were me, I'd have the car checked. Doesn't sound right, especially for such a new car.
2009 Jetta TDI, black, tan interior with black dash, DSG, 16" Wheels, Build date 11/08. 'Fixed' 10/18.
47.8 mpg best tank, all interstate @ 70 mph ----- 159,000 miles on odometer.
2004 Toyota Solara SLE V6 (wife's), 1979 Diesel Rabbit (RIP), 1981 VW Diesel Pickup (RIP), 1986 Jetta gasser (gone).
jbright is offline   Reply With Quote
Old May 25th, 2011, 08:55   #3
JSWTDI09
JSWTDI09's Avatar
First, I hope you didn't add a quart of oil. All VW 507 approved oils come in containers measured in liters. Therefore I really hope you added a liter of oil.
Second, my Jetta didn't need any oil until over 25k miles, but every car is different. The most important thing to know is the correct method to check oil level. You want to shut off the engine and then wait at least 5 minutes before checking the oil level. This gives the oil a chance to drain back down into the oil pan before you measure it. Looking at the dipstick immediately after turning off the engine can result in over filling the engine. If there are no signs of leaking oil, I wouldn't be too worried unless it gets worse. Sometimes new engines will burn some oil until they are properly broken-in.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old May 25th, 2011, 09:16   #4
TDI_Timmy
TDI_Timmy's Avatar
Not saying you should be driving like a racer all the time but perhaps drive more aggressively at times with the right foot. When the engine is warmed up try to get the trans to shift as close to 3000RPM as possible and when getting up to 60MPH or whatever highway speed put your foot down (don't want to slam foot down under 2K RPM) and build the revs close to redline. Do this occasionally. I don't have an exact number of times, but you want to build boost so that the piston rings are well seated. This could help limit oil consumption.
Also, to add o JSWTDI09's comment you are checking the oil with a warm engine? The oil expands quite a bit.
2012 JSW DSG sunroof - white - "Wally"
2004 Chevrolet Aveo - red - "Lil' Red"
1967 Ford Fairlane 500 convertible - converted to 5 speed manual - red - "Betsy"
TDI_Timmy is offline   Reply With Quote
Old May 25th, 2011, 09:17   #5
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Your oil usage does not sound excessive. What is normal depends on you and your specific car. I would watch it, but not worry about it. Watch it means checking the oil level and adding as needed. Needed. Don't overfill it. It would better be a little under than a little over.
It appears that you are not in the habit of checking your oil. I suggest doing it very often to start. Then after a month or two, you may cut back a little. Get to know your car.
Yes, it could have a leak, but the apparent amount of oil that is being used, is within the normal range. Also you may find that you car may end up using less oil as it is broken in.
Also as JSW suggested, make sure you are using the recommended measuring technique.
Don't forget that if the car had not been parked with the engine off for a few minutes or if it is parked on a hill, the dip stick may be inaccurate.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old May 25th, 2011, 09:25   #6
TDI_Timmy
TDI_Timmy's Avatar
Good points.
Old May 25th, 2011, 09:58   #7
NickBeek
I check my oil at every fuel fill up (around 500 miles) after completing the fueling. This gives the oil a chance to drain back into the pan. The factory fill was up to the top groove in the dipstick and never moved over the first 10k miles. The dealer did my 10k service and filled the oil to the mid way point on the cross hatch area of the dipstick. So far (1200 miles since change) the level hasn't changed noticeably.
I did and still do use some spirited driving to ensure proper break in.
2013 Passat TDI SE with Sunroof DSG Platinum Grey.
Traded - 2011 Jetta TDI Sedan Manual 6 Speed Silver.
NickBeek is offline   Reply With Quote
Old May 25th, 2011, 10:09   #8
vwnut20
Thanks everyone. I actually spoke with one of the techs at my dealership and then verified my findings afterwards. With these TDI's it is better to check the oil when engine is cold. If checked when hot they will always read lower. Also, it is quite possible that the last time the oil change was done the, not enough oil was added. According to the tech there is some confusion in between the 06-09'(take only 4.0L) and 10'+(take 4.2L) at there shop. I can believe this, because the now oil level in my car is at 3/4 of the way up the marked on the dipstick and engine is cold.
Old May 25th, 2011, 10:41   #9
TDI_Timmy
TDI_Timmy's Avatar
Not true!!!
I checked my oil before a drive, just below top groove, then after my drive with a warm engine and letting it sit for 5 minutes or so the oil was up at correct level. Oil expands with heat. I know the manual has errors, but it also says check with warm engine and letting it sit a bit - that is NOT an error in the manual.
Now if you check your oil while engine is running or right after you shut it off of course it will be low and is not the correct procedure.
Old May 26th, 2011, 19:08   #10
tdi90hp
sounds like a high consumption.....you cant say for sure till you measure exactly time and distance with accurate measurements for different timelines. check and report back...doubt it chews that much....just drove mine 15,000kms before 1st oil change and dipstick never moved....
tdi90hp is offline   Reply With Quote
Old May 26th, 2011, 19:17   #11
TDI_Timmy
TDI_Timmy's Avatar
If you are worried I think you can ask dealer to perform consumption test. (not sure if dealers do this or not.) I just remember that MB dealer did it for my dad's car...
Old May 27th, 2011, 03:10   #12
PaulGiz
A single occurrence is not an indicator. You may have measured incorrectly, oil may have been underfilled, plenty of possible reasons you measured low once.
Keep an eye on the oil level (yes you should check oil often, I do almost every time I fuel up).
If you see a trend, then you can take action. New cars sometimes start out with some oil consumption, then settle down. It could be as simple as that.
P.
Stock Golf Gasser, Paul is no longer TDI
PaulGiz is offline   Reply With Quote
Old May 27th, 2011, 04:53   #13
gergg
I've got 12,000 miles on mine and it hasn't used any oil.....I do drive spirited quite often
gergg is offline   Reply With Quote
Old May 27th, 2011, 08:30   #14
Karlman
2011 jetta 2490 miles driven.... used 3.5 quarts of motor oil. Please do not reply with the liter and quart or don't know how to check oil level lectures.This engine burns oil.
No leaks or drips anywhere. Sucking oil like a camel water. The oil consumption is less now (than early on) but still very alarming. My maintanance log is reflecting miles driven, motor oil used, month and day. I have had four TDIs, a 2006, two 2009's (sold) and one 2011.
None of the older TDIs used any motor oil. Otherwise, the car is flawless.
Karlman is offline   Reply With Quote
Old May 27th, 2011, 12:38   #15
marc77777
If I drove 2490 miles and went through 3.5 quarts, my car would be sitting in the dealers garage as we speak.
marc77777 is offline   Reply With Quote
Oil consumption TDI vs. Beetle? misoless Fuels & Lubricants 4 April 6th, 2010 06:44
2.0 TDI 140 oil consumption?? Mat VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 December 12th, 2009 17:13
TDI Oil Consumption purduetdi TDI 101 1 February 15th, 2008 12:51
TDI oil consumption sail538 TDI 101 24 December 6th, 2003 21:32
TDI Oil consumption Toronto TDI 2002 TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 0 January 15th, 2003 20:14
Page generated in 0.14902 seconds with 10 queries
[Output: 127.54 Kb. compressed to 106.38 Kb. by saving 21.17 Kb. (16.60%)]
