Old May 25th, 2011, 05:02   #1
Winkowitsch2011
TDI(s): 98.5 Jetta
Default Rear axle beam bushing
I just bought a 1999 Jetta w/ a WVO kit on it. I'm excited about the fuel savings, etc. New to TDI & forums.
I have a bad rattle. Sure it is the rear axle beam bushing. From what I am reading, there are different axles used & bushings. What is the best way to know which one I've got. Is there a number stamped on the axle? VIN number do any good? Are there upgrade bushings? Any help is appreciated.
Thanks,
Dave
Winkowitsch2011 is offline   Reply With Quote
Old May 25th, 2011, 05:35   #2
davebugs
Thanks,
Dave
Lots of info here.
But forst 99 was a cutoff year.
You need to know if you have a MKIII or a MKIV to start with.
Regardless the dealer should be able to provide the correct bushings with the vin#.
davebugs is offline   Reply With Quote
Old June 11th, 2011, 16:55   #3
NHgranite
NHgranite's Avatar
What are some upgrade options for rear axle bushings?
Links appreciated !!
'12 Passat SE. 6MT.
H&R springs, FrostHeater.
NHgranite is offline   Reply With Quote
Rear Axle Beam Bushing - Need Help DVF2001 TDI 101 61 June 20th, 2015 07:19
Seat Leon Cupra R rear axle beam bushing? Nico3d3 Upgrades (non TDI Engine related) 15 September 12th, 2013 19:17
Axle beam bushing replacement willjayc TDI 101 17 September 8th, 2010 09:02
Rear Axle beam bushing 2ManyKMfor1Tank Ontario 5 May 23rd, 2010 18:39
Rear Axle Beam Bushing. What's the deal with this? POWERSTROKE VW MKIV-A4 TDIs (VE and PD) 8 January 16th, 2005 21:19
Page generated in 0.12609 seconds with 10 queries
[Output: 57.76 Kb. compressed to 52.46 Kb. by saving 5.30 Kb. (9.18%)]
