Old May 24th, 2011, 07:49   #1
ALVWTDI
TDI(s): 2005 Passat
Default Oil for 2005 Passat TDI
I just bought a used 2005 Passat 2.0L TDI. I will soon need to change the oil. I looked for the oil types listed in the TDI forum, but can's seem to find the exact match. I found an oil from Mobil, (synthetic), called Turbo-Diesel, but it seems like it is meant more for trucks. It is rated CH-4. I went out to Mobil's website and looked up this product and found where someone had asked if this oil met VW 502.00 standards and the reply was no. Should I use this oil in my car?
Also, I found an oil called Mobil Delvac 1300, (synthetic), but the weight is 15w-40, not the 5w-40 recommended in the forum. This oil also had a rating of CH-4. I live in Alabama so I wonder if it is ok to use this weight oil since it never really gets that cold here? If both oils will work for my car, which would be the better choice?
ALVWTDI is offline   Reply With Quote
Old May 24th, 2011, 07:55   #2
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Use an oil rated for VW 505.01 service as noted in the owners manual. M1 TDT 5W 40 is very good, and many here use it, but it has no VW certification, which doesn't mean it is not good.
There is a Fuels and Lubricants section here (you are in it) that has 2,456,789 threads on "which oil". Check it out.
Also, all the recommended vendors here sell oil change kits that come with oil and filters for these cars. Look at idparts.com and boraparts.com for some help.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old May 24th, 2011, 07:57   #3
dieseldorf
top post dawg
dieseldorf's Avatar
Yes, people appear to be having good success with this oil even though it does not meet the spec for the car. (I'm assuming your warranty is long gone). Oil can be found at many Walmarts in gallon size containers. I think it's around $26 now. It's 5W40, Turbodiesel truck. The newest bottle looks a bit different compared to this one:
Old May 25th, 2011, 09:36   #4
T_D_I_POWER
T_D_I_POWER's Avatar
No guessing game simply the best for any Diesel - VE, PD, CR- or any gas
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old May 25th, 2011, 15:06   #5
Clayslayer
Fuel Economy: 56/39/45 hi/low/avg for the Jetta, the F-150 gets 20-21mpg give or take
I like the Mobil 1 stuff too. I also use Shell Rotella T6. I've always used synthetic 5w-40 oil in my car. 300,000 miles and counting.
Clayslayer is offline   Reply With Quote
Old May 28th, 2011, 13:11   #6
TSP-MIAMI-TORONTO
Just hit 1,000 kms with my first use of T6. Find engine running quieter, smoother than with the TOTAL I was using last summer.
T
TSP-MIAMI-TORONTO is offline   Reply With Quote
2005 passat tdi oil capacity chucky TDI 101 3 August 5th, 2007 17:39
Do I have the right oil in 2005 passat tdi? mastoidbone Fuels & Lubricants 21 November 22nd, 2005 22:56
Oil Change- HELP!!!- 2005 Passat TDI BlingDiesel TDI 101 14 November 17th, 2005 09:23
First oil change with 2005 Passat TDI EYE2 VW B5 Passat TDIs 52 May 5th, 2005 18:54
2005 Passat TDI using some oil??? 2nd_tdi_4me Fuels & Lubricants 6 February 26th, 2005 10:23
Page generated in 0.12475 seconds with 10 queries
[Output: 78.12 Kb. compressed to 68.50 Kb. by saving 9.61 Kb. (12.31%)]
