Old May 19th, 2011, 06:05   #1
DaGentooBoy
Default Brand new battery dead after 2 days
I put an 80Ah Gel Cell battery in my 2002 Jetta and it started and ran great. Drove it around a bunch and then I parked it and it hasn't moved for a couple days. When I went to get something out of it last night it was totally dead.... as in no odometer... no electric locks... no trunk opening.... nothing. So I jumped it with the Passat and drove it for about 30min last night and I came out this morning and it was totally dead again. In order for an 80Ah battery to go dead in 2 days it must have been drawing almost 2A continuous for 2 days. Once I jumped it everything was working and there weren't any lights on or anything.
Anyone have any ideas what to check?
DaGentooBoy is offline   Reply With Quote
Old May 19th, 2011, 06:14   #2
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
Borrow a good battery, install it, and see if it drains down in 2 days. If if does then you have to start looking for what is causing the drain. If not then you know the gell-cell battery is bad.
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old May 19th, 2011, 06:29   #3
DaGentooBoy
The gel-cell is brand new... do they typically have problems with selling a lot of bad ones?
Old May 19th, 2011, 06:55   #4
KLXD
Or disconnect it overnight.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old May 19th, 2011, 07:06   #5
LiLredTDI
LiLredTDI's Avatar
Fuel Economy: ohh...I'd say bout 42mpg
Check the main fuses atop the battery. The metal strip fuses to be specific. Check them all by removing nuts holding them, remove, ohm and insure the contacts are clean. Same thing happened to me and it was a loose fuse.
2004 Jetta PD-RC race, 17/22,stg.IIcoltcam PD150 Inj.,Rosten Rods, Ported head,PP DP, cat delete/2 1/2" piping/Magnaflo muffler, R32 airbox/snorkle,PD150 TIP, SB stg 3 ,NSboost/egt gauges, BBS RS II's, Koni FSD/Eibach Kit, M3 side skirts/ rearwindow spoiler,GLI F/R lips FK bumper scoops
LiLredTDI is offline   Reply With Quote
Old May 19th, 2011, 07:15   #6
DaGentooBoy
I will try that tonight.... I might also take the battery to autozone and get another one and see if that fixes it.... the battery is literally <5days old
Old May 19th, 2011, 07:19   #7
nate379
nate379's Avatar
TDI(s): 05 Jetta
"ohm"
I think he means check the resistance. Ohm is a noun not a verb.
05 Jetta 4th Gen.
nate379 is offline   Reply With Quote
Old May 19th, 2011, 07:25   #8
DaGentooBoy
Originally Posted by nate379 View Post
"ohm"
yes... I am an Computer Engineer so I am VERY aware of the difference... but I am pretty sure I know what he meant thanks for making it clear though
Old May 19th, 2011, 08:00   #9
LiLredTDI
LiLredTDI's Avatar
2^^^^^^^^^^^^^^^^^^^^
Pompous ass
Old May 19th, 2011, 08:04   #10
puter
Fuel Economy: 57 mpg
Also track down any current leaks using an ammeter.
First test across the neg terminal on the battery, if you see a higher than expected draw there then test across each fuse to identify where it is coming from.
btw, CE here as well, nice to know I'm not the only one on here
puter is offline   Reply With Quote
Old May 19th, 2011, 08:25   #11
DaGentooBoy
I was hoping that someone had seen this.... I will check the current and other factors tonight.
Old May 19th, 2011, 13:40   #12
JB05
Fuel Economy: 43/41/40
Is this an AGM battery, and if so what brand?
JB05 is offline   Reply With Quote
Old May 19th, 2011, 13:47   #13
DaGentooBoy
It is the new autozone gel-cell battery...
Old May 19th, 2011, 13:56   #14
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I'd immediately suspect a defective storage battery (or it's not hooked up right).
It happens. AZ can check it for you, right in the car.
Old May 19th, 2011, 14:22   #15
DaGentooBoy
Right now it takes longer to jump the car than to just pull the battery and take it over there.
battery light with brand new dealer battery jester69 VW MKIV-A4 TDIs (VE and PD) 10 November 25th, 2008 11:00
Battery going dead in 4-5 days Graphic Man Ontario 12 November 4th, 2008 02:06
Mystery: Dead Radio, ... 2 week pass, dead battery? GdB VW MKIV-A4 TDIs (VE and PD) 22 May 1st, 2008 13:48
2004 Jetta goes dead after 5 days mvtdiowner TDI 101 9 July 12th, 2006 03:14
Dead battery after ten days???!!! sootwagen VW MKIV-A4 TDIs (VE and PD) 9 March 4th, 2004 06:55
Page generated in 0.18070 seconds with 10 queries
[Output: 128.79 Kb. compressed to 107.58 Kb. by saving 21.21 Kb. (16.47%)]
