Old May 15th, 2011, 15:41   #1
TNTDI
Fuel Economy: 52/48/52
Default Beetle engine won't turn over.
I have a 2000 Beetle with 82k. I did an intake clean, EGR/Cooler delete. I also replaced the VNT-15 actuator. Took the car out for a test drive. It finally has some power. Maybe went a mile and it shut down. I coasted to my driveway. It now won't even crank over. The dash lights and glow plug light comes on, but the starter won't crank. What did I do to my wifes Beetle??
TNTDI is offline   Reply With Quote
Old May 15th, 2011, 16:00   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Good question How's the oil level? can you turn the engine over by hand? If it's a manual you could jack up one of the drive wheels and put the car in 5th and try it that way. Was there any noise before it shut down? Have you checked all the fuses?
Seatman is offline   Reply With Quote
Old May 16th, 2011, 09:14   #3
jettawreck
jettawreck's Avatar
What's the TB history on the Beetle?? Please don't say it was the original!!
Don't try cranking it over any more until you determine what's wrong. Remove passenger front wheel and try to carefully rotate engine by the crankshaft pulley bolt. If you come to sudden resistance while turning clockwise-stop.
2004 Cadillac SLS (wife's)
Old May 17th, 2011, 04:48   #4
TNTDI
I checked the fuses visually and the oil level is fine. The belt appears to be intacked. I don't know the history prior to 65k. I'll try and move the crank today. It just shut down. No loud bang or nasty noises. Just heard the turbo winding down. The turbo seemed to be working for the first time in along time. The VNT was froze.
Old May 17th, 2011, 06:34   #5
jettawreck
jettawreck's Avatar
So you don't know if its the original TB, or if it was changed before 65K??
If you don't/didn't know for sure-it gets changed for sure. Push down real firmly on the belt. Should not deflect at all.
Old May 17th, 2011, 07:18   #6
TNTDI
Belt deflects and has some crazing. It needs to be changed. Just put a socket on the crank. It does not turn under enough pressure to move the engine in the mounts. How can this be locked up??
Old May 17th, 2011, 07:31   #7
jettawreck
jettawreck's Avatar
It needed to be changed before now.
Piston is touching a valve. If the belt has deflection, tensioner probably failed and timing has slipped. Head needs to come off and repaired.
Old May 17th, 2011, 08:43   #8
TNTDI
Thanks Jettawreck. The timing belt as far as I can see hass all it's teeth. The other thought was I loosened up apiece of carbon/soot when I cleaned the intake. When I got on the highway and shifted at higher rpms. The turbo finaly working blew it in deeper.
Old May 17th, 2011, 08:58   #9
paramedick
paramedick's Avatar
Bingo!! Valve hanging open due to carbon blockage is first guess.
Old May 17th, 2011, 09:27   #10
Ski in NC
Fuel Economy: 48-52 typical
That's got to be a mighty tough chunk of carbon to stop a spinning engine.
have you tried rotating the engine in both directions from the crank bolt? No motion?
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old May 17th, 2011, 10:47   #11
TNTDI
Was told clockwise only on the crank. I think the belt jumped a tooth or 2. Being a little loose and a good turbo pulled it. I will pull the valve cover next. Hopefully it was a soft landing.
Old May 17th, 2011, 12:05   #12
thesearcherman
You know, this is like the third person this week who ran their timing belt to long, even if that is not the problem here. What the Government should do is require anyone who buys/owns a car with a timing belt, be required to take random drug tests as long as they own the car. It is beyond stupid to drive a car after the recommended TB change time/milege. One of the reasons we don't get the 65 mpg cars here that are in Europe, we are to stupid to own them. HA-HA
thesearcherman is offline   Reply With Quote
Old May 17th, 2011, 12:22   #13
jettawreck
jettawreck's Avatar
If you cann't turn it over it cann't be that "soft".
Whenever there is valve contact, the head comes off and gets some (depends on how many) new valves and a set of lifters-maybe a cam.
Old May 17th, 2011, 13:48   #14
TNTDI
Searcherman(TDI's none) likes to hear himself talk I guess. No constructive info from him. I was told belt was done before 60k. so much for trust. I will be taking off the head tonight.
Old May 17th, 2011, 14:16   #15
jettawreck
jettawreck's Avatar
Searcherman likes to hear himself talk I guess. No constructive info from him. I was told belt was done before 60k. so much for trust. I will be taking off the head tonight.
Unfortunately, its one of those things that if you don't have 100% proof, you have it done/re-done so you do know. Trusting ends up costing.
'02 Jetta.... won't start, won't even turn over... timirving TDI 101 14 February 16th, 2015 05:59
Engine won't turn off...help please DorkusMalorcusTDI TDI 101 9 August 24th, 2010 10:04
Mk5 engine won't turn over SilverGhost VW MKV-A5 Golf/Jettas 5 January 28th, 2007 08:00
Engine won't turn over, has lights and power Big Red VW MKIII-A3/B4 TDIs 2 May 5th, 2004 05:06
engine won't turn off texbik VW MKIV-A4 TDIs (VE and PD) 14 August 26th, 2002 19:19
Page generated in 0.20580 seconds with 10 queries
[Output: 132.39 Kb. compressed to 111.20 Kb. by saving 21.19 Kb. (16.01%)]
