Old May 15th, 2011, 07:20   #1
Snosport
TDI(s): 2004 Passat
Fuel Economy: 35 to 42
Default Removing air from cooling system
I just replaced the radiator on my 2004 Jetta TDI following a deer collision. All of the coolant out of the block may have been lost when the lower hose was removed. When I refilled it I was able to add only about 1/2 gallon of the coolant water mix.
My concern is that there is almost certainly air in the cooling passages in the block. I need to know if there is a good way to bleed off the air so that the coolant fills the passages in the block before I start the engine.
Any help would be appreciated.
Snosport is offline   Reply With Quote
Old May 15th, 2011, 08:20   #2
cyrus #1
What I usually do is remove the upper rad hose and fill as much as I possibly can on both the rad and engine side. Then I will fill the coolant overflow tank to max capacity and "burp" all the major coolant lines for a while. After this I fill the overflow again and start the engine. While the engine is slowly warming up I will continue to burp the system as the coolant circulates.
All that is left at this point is to monitor the coolant level for a couple of days. This procedure has served me well on all of my VW's. I never seem to use quite as much coolant as I think I should though. You are making sure to use the G12 coolant, correct?
1982 Vanagon TDI
2002 Jetta TDI
cyrus #1 is offline   Reply With Quote
Old May 15th, 2011, 15:49   #3
Snosport
TDI(s): 2004 Passat
I started it up and ran it for about 15 minutes and almost none of the coolant from the reservoir worked its way down.
When I started burping the hoses, I noticed that I have a leak where the top fitting that the top radiator hose attaches to goes onto the radiator fitting and is held in place with spring clip. If I squeeze the hose, it leaks around the the plastic fitting between the fitting and the radiator.
I am using the VW G-12 coolant, but I cheaped out and bought an aftermarket radiator. If I don't find any other cause, I will probably take it apart and replace the cheap aftermarket radiator with a genuine VW.
Old May 17th, 2011, 11:24   #4
Powder Hound
Powder Hound's Avatar
Originally Posted by Snosport View Post
... I cheaped out and bought an aftermarket radiator. If I don't find any other cause, I will probably take it apart and replace the cheap aftermarket radiator with a genuine VW.
This is probably what you'll have to do, unfortunately. Looks like you may be a C.R.A.P. victim.
Old May 18th, 2011, 01:29   #5
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
Recently with great success post cooling system maintenance I have added as much coolant to the coolant reservoir as I possibly could(approx 1/2 gallon), put cap back on, remove small upper hose from reservoir, attach a small hose to reservoir nipple that is now vacant, and gently blow(w/ regulated compressor air or by mouth). This puts air pressure on the coolant that is in the reservoir and forces it into the lowest coolant passages until it is pretty much 90% full. Repeat process as necessary until coolant comes out of small tube disconnected from reservoir. Worked like a champ for me
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread.php?t=306799&page=4
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
Old May 18th, 2011, 01:37   #6
josh8loop
josh8loop's Avatar
I hope no damage was done to the engine from running 15 min with hardly any coolant circulating. Also, you may have to replace the internal 32x4 mm O ring in the upper coolant hose that attaches to the radiator. This is the O ring that seals the plastic quick connect to the upper radiator nipple, and often times leaks due to age( flattens out). Order two and do the lower hose while your at it!
Cooling system Money Pit VW MKIV-A4 TDIs (VE and PD) 2 December 25th, 2010 03:33
Saving weight by removing cooling fan shroud / assembly mad_despot General VW Discussion 21 June 23rd, 2008 08:16
Air In Cooling System ** NEED HELP** $al TDI 101 8 April 10th, 2008 14:21
Major air lock in cooling system( Help:() Greaseburger TDI 101 2 May 22nd, 2006 15:20
air pockets in cooling system faucho VW MKIV-A4 TDIs (VE and PD) 2 November 9th, 2003 21:29
Page generated in 0.13943 seconds with 10 queries
[Output: 79.77 Kb. compressed to 70.36 Kb. by saving 9.41 Kb. (11.79%)]
