Yes, I'm very happy that I don't have to deal with the salt that you northern guys do.In the south you are lucky. Try getting a 12yr old set off that has 200K miles on them. You can slit them lengthwise with a cutting tool in a pinch to get them free.
If you just torch within reason you'll be fine, from my experience, it does NOT need to get cherry red hot, just good and hot.Of all the methods listed here... Torching is the best idea. Metal will return to normal... Your engine expands also under heat, starts up each time after it cooled off.
Fabulous for you. There are plenty of us here that make a living turning wrenches as well.Of all the methods listed here... Torching is the best idea. Metal will return to normal... Your engine expands also under heat, starts up each time after it cooled off.
You try doing an alignment on a 10+ year old E36 BMW and get er done in book time allowance. I make a living off beating flat rate time, I can't spend days on doing just an alignment on a car and tell the customer he will need new parts because I have to slice the tie rods to make em move.
This is true. I've had a couple B5 Passats like this. Trying to do an alignment and the tie rods are completely seized, and you can't torch them too much because the threaded rod of the outer is held in place by a rubber bushing. Hell, I've managed to unbond the rod from the bushing just by brute force with a wrench before (Snap-on Flank Drive Plus wrenches are the best thing ever!)Fabulous for you. There are plenty of us here that make a living turning wrenches as well.
We were discussing replacement of the parts not the alignment. Torching does not always work. Period.
Usually you jack up the a arm to create presssure on the conical flange ergo holding it by friction while you ease the nut off...Ok so after applying some heat to the nut i was able to remove it while holding the back of the nut with a wrench.
Do I need to replace the whole tie rod and end ?
