Old October 24th, 2002, 11:12   #1
natescape
natescape's Avatar
Default Passat cold weather starting issues
Alright, my starter problems are back (it's been replaced about 5 times in the 1.5 years I've owned the car).
When it's cold in the morning, the starter will sometimes start, make noise, then immediately fzzzzzzzzzzzzz and stop. I then crank it again once or twice and it starts. Any ideas?
And this isn't a biodiesel issue. I had this problem last winter before using bio.
natescape is offline   Reply With Quote
Old October 24th, 2002, 13:53   #2
TDIBill
Fuel Economy: 55, 45, 40
Default Re: Passat cold weather starting issues
Maybe it's not the starter? Check my ignition sw post.
Passat Ignition Switch Recall
TDIBill is offline   Reply With Quote
Old October 24th, 2002, 14:20   #3
lrpavlo
Nate don't know if you've had the starter out butttt....the rubber coated wire connection between the starter bod and the solenoid is notorious for turning to dust!!! It looks OK but pull on that sucker and you might be surprised!
That fixed my problem anyway.
lrpavlo is offline   Reply With Quote
Old October 25th, 2002, 04:33   #4
tdipoet
tdipoet's Avatar
Fuel Economy: 1 Hojillion MPG
crap!!! nate, weren't we just saying on saturday that whenever i get NEAR your car something happens to it?
and now your starter and radio don't work.
tdipoet is offline   Reply With Quote
Old October 25th, 2002, 07:36   #5
natescape
natescape's Avatar
Hey Derek, send me an email. The "dgelinas@hunnr.org" address you have in your profile doesn't work, nor does your old cell phone number.
Page generated in 0.15455 seconds with 9 queries
[Output: 63.36 Kb. compressed to 55.66 Kb. by saving 7.70 Kb. (12.16%)]
