TDIFest 2013 Registration is now open!
View Poll Results: What oil are you using in your PD TDI?
Amsoil 2 1.80%
Castrol TXT 4 3.60%
Elf Excellium 5 4.50%
Lubro Moly 6 5.41%
Mobile 1 TDT 35 31.53%
Pentosin 16 14.41%
Shell Rotella T6 16 14.41%
Valvoline SynPower Euro formulation 3 2.70%
Other... 24 21.62%
Voters: 111. You may not vote on this poll
Old May 12th, 2011, 10:15   #1
NC TDIpilot
Fuel Economy: Fuelly
Default Poll: What oil are you using in your PD TDI?
I have read, and read, and read all of the posts about recommended oils, oils that are good to use, great to use, not approved oils that are still great, etc. The bottom line is this, what oil are you using right now in your PD TDI?
NC TDIpilot is offline   Reply With Quote
Old May 12th, 2011, 10:26   #2
Zambee500
Recently switched to M1 TDT, and already stocked up for next 2 oil changes with TDT too. Most likely stick with that going forward.
Switched to TDT after using Pento HP2 5w40.
2005 Passat GLS TDI (sedan)
Zambee500 is offline   Reply With Quote
Old May 12th, 2011, 12:02   #3
Beefcake
Motul Specific 5-40.
Beefcake is offline   Reply With Quote
Old May 12th, 2011, 17:18   #4
SignHere
SignHere's Avatar
Fuchs Titan G1 5w-40
SignHere is offline   Reply With Quote
Old May 12th, 2011, 17:29   #5
volkswheels
volkswheels's Avatar
Fuel Economy: 46mpg Winter/57mpg Summer w/Lucas Fuel Additive
Total MC3 5w30
volkswheels is offline   Reply With Quote
Old May 12th, 2011, 17:39   #6
pleopard
pleopard's Avatar
Pentosin SP III 5W30
EDIT: Whoops, not a PD, sorry.
'10 Jetta 2.0 TDI, DSG
pleopard is offline   Reply With Quote
Old May 12th, 2011, 18:07   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Rotella T6
99.5 Jetta TDI; DLC1019 nozzles, G60/VR6, Malone Econo tune, EGR delete, ASR/EDL, bilstein TCs/VR6 wagon springs(1.5in lift),rally armor mud flaps. 305K miles and climbing.
04 Jetta TDI . MFA cluster, e-codes, reverse light mod, LED trunk light. 157K miles(still a baby).
turbocharged798 is online now   Reply With Quote
Old May 12th, 2011, 18:33   #8
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: Which VW diesel? There have been Twelve of them!
Ooops!
I voted "Lubro moly" when in fact I'm using "Liqui Moly".
Svante Arrhenius 1896
Old May 12th, 2011, 18:39   #9
NB_TDi
NB_TDi's Avatar
TDI(s): 2000 Jetta
Fuel Economy: Best 56MPG
Elf/Total.
I usually top-up with Rotella T.
2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TSI 4Motion
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old May 12th, 2011, 18:50   #10
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Ooops!
Same oil, different location.
2003 TDI Mafia Member, modified with 17/22. Amsoil 15w40
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old May 12th, 2011, 19:19   #11
DonCT
Fuel Economy: 43.5
Mobil1 ESP 5w-30
2000 Beetle GLS TDI (AlienBug)
Mobil 1 ESP 5w-30
DonCT is offline   Reply With Quote
Old May 12th, 2011, 19:25   #12
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
Pentosin HP2 5w40 505.01 Been using it since 57k (balance shaft conversion) and I currently have 95k on mine. Before that my car had a fairly long diet of the old Castrol TXT 5w40 and a couple of changes on the 5w30 Castrol Professional OE. In fact I just changed my oil this past weekend. Took a sample but have yet to send it in. I went 9200 miles this time. Most of the time I change at 8000 miles.
2005 Passat GLS TDI, 143k miles, Now a daily driver Chainless and Gear Driven via the procedure by Oilhammer 06/17/2009, ngk hybrid glowplugs, Chainless and proud of it! Mileage?....adequate
leicaman is offline   Reply With Quote
Old May 12th, 2011, 21:21   #13
truman
50/50 Valvoline 5w40 and 20w50. Next OCI will be 20w50 for the hottest months. The 5w40 has 505.01 approval and 20w50 states meets the requirements of 505.01- FWIW.
truman is online now   Reply With Quote
Old May 13th, 2011, 01:56   #14
nate379
nate379's Avatar
TDI(s): 05 Jetta
Schaeffer 9000 5w40. Run it in all my stuff.
05 Jetta 4th Gen.
nate379 is offline   Reply With Quote
Old May 13th, 2011, 02:26   #15
WEDEL.1
WEDEL.1's Avatar
Fuel Economy: 4.1 L/100 Kms
This is what I use at the minute;
SLX PROFESSIONAL LLIII POWERFLOW
PRODUCT DESCRIPTION
Castrol SLX Professional LLIII Powerflow has been developed with “Clean Performance
Technology” in co-operation with the VW Group which sets new standards in the industry.
Castrol SLX Professional LLIII Powerflow has been specifically co engineered with VW to ensure
cleanliness of the engine, thereby reducing harmful emissions which damage the environment.
Through “Clean Performance Technology”
Castrol SLX Professional LLIII Powerflow reduces long
term blocking of particulate filters thereby prolonging the life of the diesel particulate filter.
PRODUCT APPLICATION
is a SAE 5W-30 engine oil and is equally suitable for
gasoline and diesel vehicles where performance specifications VW 504 00 or 507 00 are demanded.
The lubricant also meets the requirements of most of the previous VW oil specifications making it
suitable for most older gasoline and diesel engines.
employs synthetic base oils in combination with a new
antiwear technology which offers strong protection for today’s sophisticated FSI, TDI and
turbocharged engines.
PRODUCT FEATURES & BENEFITS
A cleaner particulate filter maintains engine performance.
Protects the engine from wear all year round.
Optimises engine performance.
Maintains fuel economy.
Reduces environmental impact through lower emissions.
2011 VW Golf VI BlueMotion, 5 Speed Manual.
WEDEL.1 is online now   Reply With Quote
PD Engine Oil Preference Poll. What are you using? 505,506,507? justpaddlek1 Fuels & Lubricants 91 May 21st, 2007 16:42
Poll.. Running Bio Diesel Your TDI PD myke_w Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 28 August 20th, 2005 10:19
PD oil consumption poll... Shomegrown VW MKIV-A4 TDIs (VE and PD) 55 June 12th, 2005 18:27
POLL: Crude Oil Price (Poll close $50/barrel hit) RichC Fuels & Lubricants 56 January 25th, 2005 13:57
Poll 506.01 Oil in Your PD TDI? phaser Fuels & Lubricants 29 December 20th, 2004 10:04
Page generated in 0.18335 seconds with 11 queries
[Output: 137.84 Kb. compressed to 116.12 Kb. by saving 21.72 Kb. (15.76%)]
