Old May 9th, 2011, 15:23   #1
cgi2099
TDI(s): Jetta 1999.5
Fuel Economy: 45
Default RPM going up and down at constant speed HELP!!
Just got my other TDI up and going (2002 Jetta). My problem is at about 1500 to 3000 RPM's while driving at a constant speed (not slowing down or accelerating) my RPM's will go up and down about a 100 or so, causing the car to what i would say rock. I have VCDS and the only code i have is: "Anti-Shudder Valve + or - ground Intermittent" I've looked at all the write ups on this code, i have replaced all my vacuum lines and checked/cleaned the connector to the anti-shudder valve but still the code doesn't go away or the RPM problem. Car runs and drives great with the exception of this problem, anyone have any ideas?
Josh
cgi2099 is offline   Reply With Quote
Old May 9th, 2011, 15:25   #2
alphaseinor
Try unplugging your electrical connector to the antishutter valve control, it's the little black box on the back of the intake manifold... kinda hidden.
alphaseinor is offline   Reply With Quote
Old May 9th, 2011, 15:37   #3
cgi2099
Fuel Economy: 45
Do i leave it unplugged?
Old May 9th, 2011, 15:39   #4
alphaseinor
sure, just for the test...
on a 99.5 it should be a squeeze on the two wires, then pull.
Old May 9th, 2011, 15:52   #5
cgi2099
Fuel Economy: 45
okay thanks ill give that a try.
Old May 10th, 2011, 08:53   #6
cgi2099
Fuel Economy: 45
I unplugged the sensor and it didn't help, still the same problem.
Old May 10th, 2011, 08:59   #7
99vdub
TDI(s): 99 mk4 jetta
I have that same problem on my 99.5 as well, it just started this past weak. It all started with a permanent CEL and blinking GPL for a whole day than the next morning it went away. All of a sudden speedometer and RPM started bouncing freely and I get this shudder in second gear at about 20-25 miles per hour, I can hear a noise near the dashboard Im not sure if its related to my problem.
99vdub is offline   Reply With Quote
Old May 10th, 2011, 09:04   #8
cgi2099
Fuel Economy: 45
My speedo doesn't move around its just the RPM's going up and down at a constant speed, i also don't have any noise from the dashboard.
Old May 10th, 2011, 11:03   #9
procupine14
Well, you say it is a 2002 are you perhaps running with an automatic I didn't see where you said either way on that.
procupine14 is offline   Reply With Quote
Old May 10th, 2011, 13:01   #10
cgi2099
Fuel Economy: 45
I'm sorry i didn't include that in my first post, but yes it is an automatic?
Old May 10th, 2011, 13:22   #11
procupine14
If it is an automatic I'm thinking your surging is coming from the valve body. I would recommend talking to CoolAirVW on this site about diagnosing this thing for sure and, if it is what I think it is, replacing the valve body with a rebuild one before it wrecks the rest of your tranny.
http://kansascitytdi.com/
there is a link to his site and also there is a 01M FAQ on there where you might find extra help with your issue.
Old May 10th, 2011, 15:27   #12
cgi2099
Fuel Economy: 45
okay i just sent him a pm
Old September 3rd, 2011, 00:27   #13
fakhan
TDI(s): Jetta
Hello,
Some one help my jetta 2002 tdI starting normal but when I put in gear and try to drive rpm goes up and down and some back fire kind think happened also black smog coming out if I take out the air senssor car start drive normal no black smog but some funny sound come from engin I already clean intake egr valve still same....
fakhan is offline   Reply With Quote
Old September 3rd, 2011, 03:46   #14
RECCE-17
RECCE-17's Avatar
Originally Posted by fakhan View Post
Hello,
Try getting a new MAF. Also try not to hijack anyone's thread again. Sorry but if you have a problem start your own thread.
As for the OP problem sounds like the transmission to me as well. The ASV code may just be a coincidence. Your sure the ASV arm is still working not broken?
Through the mud and the blood to the green fields beyond. RCAC.
RC2, VNT 17, 11mm IP, Koni Red's, EGR cooler delete, TT bushings, Hidden hitch, 5 light mod, Evolution skid plate (with oil drain).
RECCE-17 is offline   Reply With Quote
2000 jetta stuttering at constant speed volksman1950 VW MKIV-A4 TDIs (VE and PD) 10 April 7th, 2011 22:12
SGII Constant speed MPG dremd TDI Fuel Economy 20 October 11th, 2007 09:28
small rpm changes while driving at constant speed truav8r VW MKIV-A4 TDIs (VE and PD) 10 July 10th, 2007 23:18
Constant speed, best MPG guidelines Andrei Rinea TDI Fuel Economy 10 January 14th, 2003 09:29
constant speed DieselDrinker TDI 101 5 November 21st, 2001 04:07
Đ 1996 - 2017, All Rights Reserved
Page generated in 0.15654 seconds with 10 queries
[Output: 114.96 Kb. compressed to 95.91 Kb. by saving 19.05 Kb. (16.57%)]
