Old May 9th, 2011, 08:33   #1
kcs
Fuel Economy: 50+ HWY & 40 town
Default 2005 Passat 2.0 TDI idle vibration problem
Greetings: New to the posting thing so here goes. Have the above TDI and have recently replaced (@ 85000 mi) timing belt, wtr pump, thermostat, serp belt, and all tensioners, pulleys including the alt clutched pulley (bad). Had a vibration at idle before all of this work and still have it. The engine appears to idle smoothly and vibration will go away with any addition of rpms. Looked at the motor mounts and don't see any sign of leakage (could they still be bad?) Vibration is felt throughout car when parked and in gear. I know some vibration is normal but this seems excessive. Appreciate any advice.
kcs is offline   Reply With Quote
Old May 9th, 2011, 09:12   #2
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 47 now (2010)
This should move to the B5 section...
With vag-com, if you check the torsion value (measuring blocks-group 4-last block on the right), it should say 0-2.5. If not, this can cause the engine to run a little off, even if it has been set with the timing tools.
-Rich
521,500 miles...and counting!
2000 Jetta, M1TDT since 20K, RC2, PP520s, W8 panel, front/rear fogs, Pseat w/mem. Other cars: 1972 Plymouth Satellite Sebring 2dr HT (my FIRST car!), 1968 Chrysler 300 2dr HT
Nutsnbolts is offline   Reply With Quote
Old May 9th, 2011, 10:00   #3
truman
Ever replaced an axle?
truman is online now   Reply With Quote
Old May 9th, 2011, 10:23   #4
chittychittybangbang
If you shift into neutral when parked and engine running, does the vibration go away? If so, it's most likely the CV joints. Here's a video explaining some more on my site: http://www.myturbodiesel.com/1000q/b...eplacement.htm
chittychittybangbang is offline   Reply With Quote
Old May 9th, 2011, 10:33   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Has the BSM fix been done?
99.5 Jetta TDI; DLC1019 nozzles, G60/VR6, Malone Econo tune, EGR delete, ASR/EDL, bilstein TCs/VR6 wagon springs(1.5in lift),rally armor mud flaps. 305K miles and climbing.
04 Jetta TDI . MFA cluster, e-codes, reverse light mod, LED trunk light. 157K miles(still a baby).
turbocharged798 is offline   Reply With Quote
Old May 9th, 2011, 12:11   #6
Nutsnbolts
Nutsnbolts's Avatar
^X2 with the balance shaft module, although this doesn't usually manifest itself as a bad vibration, but rather more of a rattling sound at idle.
I don't think that an axle is to blame here, since the OP stated that it happens at idle.
-Rich
Old May 9th, 2011, 18:45   #7
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: Which VW diesel? There have been Twelve of them!
Yeah, that's the weird part: It SHOULDN'T have a vibration at idle with bad C/V joints, but multiple respondents have replied that theirs did exactly that, and replacing the cheap C.R.A.P. axles with VW original or Raxles has eliminated the problem.
I know the axles should have nothing to do with the shake when the car is at a standstill, and I don't have first hand experience, but when a dozen Fred's members all say the same about their own car and their own remedy, I have to give them the benefit of the doubt.
Svante Arrhenius 1896
Old May 10th, 2011, 06:36   #8
Nutsnbolts
Nutsnbolts's Avatar
Fascinating! I've always considered "idle" to be stopped, in neutral or park, with the engine running. A misunderstanding on my part.
Still interesting that it would happen in drive with the vehicle stopped!
-Rich
2005 TDI Passat excessive drive train vibration redmax VW B5 Passat TDIs 130 September 20th, 2012 11:25
2005 Passat TDI - Rough Idle Problem gtalum VW B5 Passat TDIs 31 August 1st, 2012 04:25
2005 Passat TDI Engine Vibration QZone TDI 101 3 October 20th, 2008 17:11
2005 TDI Passat excessive drive train vibration redmax TDI 101 5 May 6th, 2006 10:35
Vibration at idle on '96 Passat TDI Metalnerd VW MKIV-A4 TDIs (VE and PD) 0 December 18th, 2000 20:37
Page generated in 0.15102 seconds with 10 queries
[Output: 87.92 Kb. compressed to 75.86 Kb. by saving 12.06 Kb. (13.72%)]
