Old May 3rd, 2011, 23:25   #1
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Default Remote window operation with VDS Pro, now featuring 98 NB!
OK, I've been doing a lot of remote window mods lately and printed out a post from the Passat World Forums. It contains a nearly complete list of CCM part numbers and what addresses should be changed and to what. It can be a little tricky since there appears to be a number of CCMs with the same part number but with different values at the addresses you make changes at. General rule of thumb seems to be to subtract 8 from the values for 1C0 CCMs. So for example, if the 3 values you are changing read 138, change them to 130. Earlier 1J0 CCMs aren't as straightforward. This post will help greatly with those!
Anyway, I will copy the post from Passat World here since it appears to be the most complete list available and has been invaluable to me. I also experimented with JetPuf's '98 New Beetle at one of Andrew's epic Bay Area GTGs and found the values that work for those cars. I recently discovered that this also works for the '98 NBs with the banjo remote and not just those who've upgraded to the switch blade key, ala JetPuf.
Anyway, if you haven't read the entire procedure in other posts, I will repost it here.
Once you've got VDS Pro running and your cable connected to the car and computer, follow these instructions to login to the CCM:
Enter "46"
Enter "11" (login)
Login code is 19283
use 26 to read the values at a specific address (depends on what part number CCM you're working with).
For example, most 1C0 CCMs you need to read the values at the following addresses:
04361
04362
04363
You only need to write down the very first value.
Once you know what the CCM is set to currently, you can then proceed to change the values.
Enter "27" and that will get you to the screen to change an individual value.
So let's say you read a value of 138 at address 04361, look up the part number of the CCM you're working with here and also match it up with the original value you recorded and see what you're supposed to change it to.
If you read 138 at address 04361, once you've entered "27" to write a new value, enter the adress 04361, I use the down arrow to get to the field to change the value, enter 130, hit enter. Then you'll have to hit 27 again to write to the next address.
Anyway, here's the list!
1J0 959 799 S 03B
Memory Address | old value | new value
04283 | 8 | 2
04289 | 8 | 2
08628 | 242 | 246 driver side front window
12724 | 250 | 254 passenger side front window
16820 | 250 | 254 driver side rear window
20916 | 242 | 246 passenger side rear window
1J0 959 799 J 00E
04286 | 8 | 2
04291 | 8 | 2
04296 | 8 | 2
1J0 959 799 AH 046 Sedan
04295*** | 138 | 64
04283 | 138 | 64
04289 | 138 | 2
08628 | 242 | 246
12724 | 250 | 254
16820 | 242 | 246
20916 | 250 | 254
1J0 959 799 AH 06Q Sedan
04295*** | 72 | 64
04283 | 72 | 64
04289 | 72 | 2
08628 | 242 | 244
12724 | 250 | 252
16820 | 242 | 244
20916 | 250 | 252
***This memory address added to keep the rear trunk handle from locking the car
1c0
________________________________________
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Wagon
04361 | 75 | 67
04362 | 75 | 67
04363 | 75 | 67
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Sedan
04361 | 74 | 66
04362 | 74 | 66
04363 | 74 | 66
1C0 959 799 C (2002 Golf)
04361 | 138 | 66
04362 | 138 | 66
04363 | 138 | 66
1C0 959 799 C (2004 Golf GLS TDI)
04361 | 138 | 130
04362 | 138 | 130
04363 | 138 | n/c
1C0 959 799 F or 1C0 959 799 G
04361 | 202 | 194
04362 | 202 | 194
04363 | 202 | 194
B5 Passat
1J0 959 799AJ
04283 | 138 | 2
04289 | 138 | 2
16820 | 242 | 246 driver side rear window
20916 | 250 | 254 passenger side rear window
1J0 959 799 S 03B
04283 | 8 | 2
04289 | 8 | 2
1J0 959 799 J 00E
04286 | 8 | 2
04291 | 8 | 2
04296 | 8 | 2
B5.5 Passat
1C0 959 799 A (Wagon)
04361 | 75 | 67
04362 | 75 | 67
04363 | 75 | 67
1C0 959 799 B (Wagon)
04361 | 75 | 67
04362 | 75 | 67
04363 | 75 | 67
04361 | 74 | 66
04362 | 74 | 66
04363 | 74 | 66
1C0 959 799 B (Sedan)
04361 | 74 | 66
04362 | 74 | 66
04363 | 74 | 66
1C0 959 799 C (Wagon)
04361 | 203 | 195
04362 | 203 | 195
04363 | 203 | 195
1C0 959 799 C (Sedan)
04361 | 202 | 194
04362 | 202 | 194
04363 | 202 | 194
New Beetle
1J0 959 799AJ
Memory Address / old value / new value
04283 / 138 / 2
04289 / 138 / 2
08628 / 242 / 246 driver side front window
12724 / 250 / 254 passenger side front window
1C0 959 799 F
04361 / 202 / 194
04362 / 202 / 194
04363 / 202 / 194
1C0 959 799 G
04361 / 202 / 194
04362 / 202 / 194
04363 / 202 / 194
Gti
1J0 959 799AJ
04283 | 138 | 2
04289 | 138 | 2
Jetta Wagon
1C0 959 799 C (2003 Jetta Wagon TDI)
04361 | 202 | 194
04362 | 202 | 194
04363 | 202 | 194
Polo
6N0 959 799 B 07F
04283 | 10 | 2
04289 | 10 | 2
4295 | 10 | 2
1998 New Beetle Owners
This is my own addition, I figured this out after a little trial and error on JetPuf's car. I also confirmed it works no matter if you have the switchblade remote or the original banjo remote!
1J0 959 799 K
04286 | 154 | 2
04291 | 154 | 2
04296 | 154 | 2
08628 | 242 | 246 driver side window
12724 | 250 | 254 passenger side window
Hope you find this resource as handy as I did.
And '98 New Beetle owners: you're welcome
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old June 9th, 2015, 10:45   #2
rhinopower
I tried this on a golf tonight, having done my old Passat years ago no problem, but it will login, says "login ok", but I never get option 26 available. Any ideas?
rhinopower is offline   Reply With Quote
Old June 16th, 2015, 07:30   #3
tongsli
Matt, thanks for the post, but that info is from here and was posted in 2006, a year before it was re-posted on the Passat Forums
http://forums.tdiclub.com/showthread.php?t=161339
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old June 17th, 2015, 12:37   #4
romad
romad's Avatar
You are aware that you replied to a 4 years 1 month old post?
The fleet:
romad is offline   Reply With Quote
Old June 17th, 2015, 13:27   #5
tongsli
Yeah, but it doesn't change the facts. The original thread is still older than his post so I've got that beat by 4 years.
window operation with remote buttons? bentwrench OBD Scanners 20 November 14th, 2010 16:41
Can you increase the range for remote window operation? D-Cell_Mekanick VW MKV-A5 Golf/Jettas 16 May 30th, 2010 11:51
VDS Pro & 2004 MkIV GTi Aus. Window Mod SashET Upgrades (non TDI Engine related) 4 August 13th, 2009 09:32
using vds pro to enabel auto window roll up Grantson OBD Scanners 2 May 16th, 2009 05:48
PANIC BUTTON TO REMOTE START YOUR TDI :) using VDS Pro etc. djeuroalex Upgrades (non TDI Engine related) 25 December 18th, 2006 23:31
Page generated in 0.16465 seconds with 10 queries
[Output: 81.02 Kb. compressed to 72.70 Kb. by saving 8.32 Kb. (10.27%)]
