Old May 2nd, 2011, 07:43   #1
macintoshdaddy
Fuel Economy: 33.95 mpg :\
Default Door Lock Not Working
So, when I lock my car, I haven't noticed it honking to arm the ATA. But, I do see the red light come on, so I haven't worried about it. However, when someone was riding in the back seat yesterday, they noticed that the door wasn't locked. Called the dealer, said it would be a $300 fix. Is it? Can I do it myself?
On a 2009 CR Jetta sedan, rear left passenger.
2009 Jetta TDI DSG, Platinum Gray w/ Titan Black leather, sunroof
2006 Ram 2500 5.9L Cummins Auto
macintoshdaddy is offline   Reply With Quote
Old May 2nd, 2011, 09:05   #2
thirty3
TDI(s): 1.9tdi
How long is the warranty is it not 3yrs like europe.
thirty3 is offline   Reply With Quote
Old May 2nd, 2011, 09:11   #3
740GLE
yeah the mileage is only good for about one year of the average TDI driver thought. it only took me a year and half to blow through 36K.
Old May 2nd, 2011, 13:09   #4
macintoshdaddy
I've got 58000 miles on my '09, so no warranty.
Old May 4th, 2011, 15:37   #5
dingdong
dingdong's Avatar
I also had this problem on my 09 JSW. Mine started out periodically not unlocking and then it switched and did what yours is doing, not locking. It was intermittent and then became constant so I took it in. It was a door latch sensor but fortunately I'm only at 34,500 on my car so it was covered under warranty.
dingdong is offline   Reply With Quote
Old May 4th, 2011, 16:16   #6
ZiggyTheHamster
ZiggyTheHamster's Avatar
This recently happened to someone and they squirted WD-40 or something into the door latch to fix it. This also happens to me occasionally and I haven't fixed it for the same reason. Pull the codes with VCDS and see if you can go from there. It might just be a loose connection between that door and the car.
2009 VW Jetta TDI - Black w/ DSG Born: 5/2009
DSG Paddle Shift Steering Wheel
RCD-510 Stereo
9W2 Bluetooth
ZiggyTheHamster is offline   Reply With Quote
Old May 7th, 2011, 20:49   #7
rdubya
TDI(s): JSW 09 - 6M
Had the same issue too. There are a couple of threads on this also. I locked and unlocked the doors repeatedly ( seven or eight times in a row). Seems to have solved the problem so far. Knock on wood.
'09 JSW 6 speed Blue Graphite, fogs, mud flaps
rdubya is offline   Reply With Quote
Old May 8th, 2011, 22:33   #8
GTIDan
GTIDan's Avatar
Just had my 2010 in for the 20,000 service and they replaced the latch on the driver's door. Same problems as noted here. Working fine so far.
9/02/09 Build date.
GTIDan is offline   Reply With Quote
Old May 9th, 2011, 06:54   #9
attyjeff
attyjeff's Avatar
I had this happen to me, it was the rear door behind the Driver, I sprayed some gun oil all inside the lock area of the door and this fixed it, I havent had a problem since.
1977 Porsche 930 turbo silver, Powerhaus level 3 package,
1980 Porsche 930 euro RUF turbo white
attyjeff is offline   Reply With Quote
Old May 9th, 2011, 07:53   #10
straightliner
straightliner's Avatar
TDI(s): 09 TDI Jetta
Me Too. Passenger rear door acting up. I am going to try the WD40 trick.
Chris Rehtorik
straightliner is offline   Reply With Quote
Old June 9th, 2011, 04:37   #11
Plano Diesel
Same problem for me. Always the driver's rear door. Noticed the horn wasn't sounding when I locked the doors with the key fob. Happens intermittently. 2009 MKV with 52k miles.
______________________________________________
His: 2009 Jetta TDI Candy White, anthracite, manual
Hers: 2009 Jetta TDI Salsa Red, anthracite, DSG, Sunroof
Plano Diesel is offline   Reply With Quote
Old June 9th, 2011, 04:45   #12
MacBuckeye
MacBuckeye's Avatar
TDI(s): 2009 Jetta
Fuel Economy: 40 avrg, 46.5 best
Default rear door latch
Right-rear passenger door latch replaced at 30K miles. It does throw a code, but can't recall what it was. Dealer was able to see it. The problem was intermittent and hard to replicate. The only way to prove to the dealer it was bad (needed replaced) was for them to scan it and get the fault code.
Sounds to me like a cheap part!!!
OH!!! Be careful or check the dealer workmanship after they fix it. They put a small dent in my door and the door does not close shut as good and easy as it did before.
2009 Jetta TDi, 191,800 miles later.... off to the crusher!
Enjoying my 2017 Honda Accord Sport SE....
MacBuckeye is offline   Reply With Quote
Old June 9th, 2011, 06:41   #13
tdiatlast
My passenger rear latch was replaced under warranty a year ago (26k miles?)
I should think, with a thread this long, that VWoA must know about this as a weakness, and should be covering this as a warranty/recall/TSB (I know of no TSB on it...I'm just suggesting) item.
I'm in for 40k DSG service on Monday. I'll ask some questions.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2014 Cadillac ELR, purchased 3/18
tdiatlast is online now   Reply With Quote
Old June 12th, 2011, 16:11   #14
Plano Diesel
I took my door apart today to try lubricating everything I could get to. For me, this didn't seem to help so I'm hoping someone has another idea.
With the outer panel removed on drivers rear door, you could see an orange piece move towards the front to lock and move towards the rear to unlock. The key fob could get the piece to move towards the rear (unlocked) but then it would be stuck in that position. The alarm would activate, but this door would not be locked. I could easily move it to the locked position by hand but the electronic lock would not.
I did learn how to mechanically lock these doors. On the side of the door, there is a black rubber grommet that you can remove. You can stick your key in that hole and push the orange piece towards the front of the car and then the door will be locked when you close it. I hope that helps one or two of you.
Old June 12th, 2011, 17:40   #15
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
I just replaced my latch assembly on my left rear door on Friday. Same symptoms. The passenger front door did it as well (under warranty) but this one was on my dime (about $130 for parts). Wasn't too difficult other than getting the door skin back on straight to match the body lines.
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Door lock not working properly PoliPino VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 June 26th, 2011 09:45
driver side door lock not working with remote adam_10 TDI 101 2 April 6th, 2011 05:43
Door lock not working properly oquatanzinwan TDI 101 7 November 15th, 2010 18:45
Pwr Window&Lock not working on 1 door only navmutt TDI 101 2 December 5th, 2009 07:07
Drivers Door Auto Lock Quit Working? bjmarler TDI 101 4 November 26th, 2005 11:56
Page generated in 0.16705 seconds with 10 queries
[Output: 124.43 Kb. compressed to 103.30 Kb. by saving 21.13 Kb. (16.98%)]
