Old April 27th, 2011, 13:57   #1
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
Default New Thermostat running a lot hotter
I've had this car for 4 years now and the temp gauge always ran about 180 ish. When I had the new exhaust put on last year it seemed to cool down to just under 180. Lately it started fluctuating more between 160 going down hills to 200 when in light traffic.
I had my son replace the thermostat yesterday and now its at about 195 and seems to be holding steady. The thermostat that was installed was a Stant 13378 which is a 180 degree temp rated thermostate. The one that came out was a 87 degree Celcius rated (184 degree) thermostat.
Is this normal that a 180 t-stat will run the enging at 195?
JJCSNLYNN
96 Passat TDI
00 Passat Wagon 1.8T
04 2500 HD Duramax Diesel 4x4
jjcsnlynn is offline   Reply With Quote
Old April 27th, 2011, 15:12   #2
dieseljunkie
It's widely been reported that the cluster coolant temp gauge is not to be trusted. It is filtered by software and likes to park itself at 195F, even if the actual coolant temp is different. What does VCDS say the coolant temp is? I'd trust that reading more.
96 Passat TDI wagon ~145k SOLD!
92 Ecodiesel 205k
dieseljunkie is offline   Reply With Quote
Old April 27th, 2011, 16:51   #3
rdkern
Fuel Economy: B4 = 48/40/36 A4 = wife drives it, don't know
I've heard that on the A4's, but not the prior ones. It might be worth seeing VCDS info, but I suspect the t-stat is opening hotter than it should.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is online now   Reply With Quote
Old April 27th, 2011, 17:45   #4
G60ING
G60ING's Avatar
I've been seeing more and more thermostat issues. I think I had an issue with one and mine was less than 1 year old and was purchased new from VW. I've opted for the 92*C thermostat and fan switch from www.germanautoparts.com to help out with the mpg.
Thinking about a TDI swap? Review the TDI swap directory
G60ING is online now   Reply With Quote
Old April 27th, 2011, 18:31   #5
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
I'll check with the VCDS tomorrow and let you know.
JJCSNLYNN
96 Passat TDI
Old April 28th, 2011, 13:16   #6
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
I put the VCDS on and in Group 1 my coolant temp is about 82 (around 180). That's good, but why all of a sudden does my gauge read 195? where does VCDS take the reading from?
Also, I found out injector #4 does not read in Group 13, idle speed . Is this a problem? It seams to be running OK.
Lastly, I have a code 00575 for intermitant MAP. What's the cause of this? Should I clean my MAF?
JJCSNLYNN
96 Passat TDI
Old April 28th, 2011, 13:30   #7
rdkern
I thought the gauge got the data from the same place as the ecu gets it. But don't take that as a real knowledge, just a belief currently that will change as others with real knowledge chime in.
MAP is not MAF. Map is the sensor inside of the ecu - you know the spot that the "little hose" goes to? Might swap out that hose, or look at the longer one that goes from the pressure tubing to the ecu.
Three injectors is all you'll read in group 13. I've been told it's actually 1,2 and 4 being compared with 3 - can't confirm that. However, readings for only 3 is normal.
Read all about it!
Old April 28th, 2011, 15:42   #8
dieseljunkie
The ECU gets the signal from the same sensor as VCDS but the ECU applies a smoothing algorithm before display it on the gauge to make it "rock steady" in order to calm those who are bothered by fluctuating coolant temps.
Go here and search for 00575 to trouble shoot MAP issues.
http://forums.tdiclub.com/showthread...ighlight=00575
92 Ecodiesel 205k
Old April 30th, 2011, 07:27   #9
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
I just boiled my old thermostat and used my trusty Harbour Freight infrared thermometer. I don't know the error using this method, but the old t-stat started to open about 155 and was fully open at 168. I shut off the heat and it was still open when I got tired of watching at 147.
This tells me I have error in the dash gauge and the new T-stat is working fine. Agree?
Two questions: How does VCDS read 180 and the gauge read 195? ( I know some have already answered).
And is this better for my fuel mileage or worse (the higher temp)?
JJCSNLYNN
96 Passat TDI
Old May 1st, 2011, 06:52   #10
TonyJetta
Fuel Economy: A5: 35mpg Avg / B4: 41mpg Avg
Sounds like your old thermostat was BAD. I would expect the t-stat to start opening about 170 and be fully open by 190.
Infrared temp sensors won't be too accurate on shiny parts like a pan of boiling water, but the error would be closer to ~5f
Yup!
1) There are 2 independent temp sensors in the temp sensor assembly, hence the 4 wires. One sensor could be starting to fail, which is why you see the 180 Vs. 195 temps.
2) One sensor is for the dash gauge and the other sensor is for the ECM.
I don't think you will see too much difference in fuel economy. If it was 100F vs. 190F operating temp, you might see an improvement when returning to the normal operating temp.
Tony
Diesel fleet: 2006 Jetta, TDI, DSG, 35MPG avg; 2006 DC Cummins, CC/LB/DRW, Jake, 15.5MPG avg, 47kmiles; 1996 Passat TDI, 5sp, Project car! 204k miles, Avg 42mpg / best 48.9mpg, Troubleshooting Links: Whitedog's No Start Trusted TDI Mechanics A4 Limp Mode IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is online now   Reply With Quote
Old May 1st, 2011, 15:44   #11
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
Great. Thanks Tony. Always a pleasure to get help on this forum.
JJCSNLYNN
96 Passat TDI
Old May 2nd, 2011, 04:45   #12
dieseljunkie
Before condeming and replacing the sensor, I'd suggest testing it with an ohmmeter first. On mine, they were very close to each other at a given temp. Mine was 29k and 29.1K ohms at around 50F as I recall.
92 Ecodiesel 205k
Old May 2nd, 2011, 05:04   #13
TonyJetta
Glad to help!
Tony
Old May 3rd, 2011, 13:37   #14
jjcsnlynn
jjcsnlynn's Avatar
Fuel Economy: 45+
I measured mine today after work. The gauge read 160 degrees and the sensors read 529 ohms and 260 ohms. I'll try to read them when it's cold, but I may have a bad sensor.
Is it worth changing the sensor or just let her ride?
JJCSNLYNN
96 Passat TDI
Old May 3rd, 2011, 17:26   #15
TonyJetta
If you can afford the $15 and ~1qt of coolant, replace the sensor.
Tony
JSW seems to be running a lot smoother on B5? mickeyyeety VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) 20 July 29th, 2010 18:52
hotter thermostat? keith102 TDI 101 13 December 13th, 2008 19:48
Thermostat replaced but now running too hot? Davies87 VW MKIII-A3/B4 TDIs 1 November 28th, 2008 06:20
Hotter Thermostat for 02 golf ELLY TDI 101 9 November 4th, 2008 18:07
Temp Sensor Replaced - now running a little hotter than normal?? N_D_v_22101 TDI 101 1 June 25th, 2008 04:56
Page generated in 0.17214 seconds with 10 queries
[Output: 136.43 Kb. compressed to 114.38 Kb. by saving 22.05 Kb. (16.16%)]
