Old April 26th, 2011, 14:54   #1
el fuego
el fuego's Avatar
Default need: "how to replace ac compressor"
i have a 2003 new beetle tdi, and for the life of me i cant seem to find a how to for this, other than spending $130 for a Bentley repair manual.
pls help.
el fuego is offline   Reply With Quote
Old April 26th, 2011, 18:01   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
Have you been through the how to's? I don't know if it's covered but might be worth a look through.
http://forums.tdiclub.com/showthread.php?p=569892
Seatman is offline   Reply With Quote
Old April 27th, 2011, 17:43   #3
el fuego
el fuego's Avatar
no ac write up i checked
Old April 27th, 2011, 18:17   #4
Seatman
Seatman's Avatar
Part of the problem is that the info will deffinitely be in here but it's trying to find it lol. I pressume you've tried the search? It doesn't always get you what you're looking for but sometimes with a bit of tweeking of the wording it can work. Have a look through these results and see if it might be in there.
http://forums.tdiclub.com/search.php?searchid=7397087
Old April 28th, 2011, 13:39   #5
el fuego
el fuego's Avatar
That link doesn't work.
Old April 28th, 2011, 14:35   #6
sasnydley
Fuel Economy: Dunno yet
1st what are you replacing/ Is it the clutch or compressor? I am no expert right off. technically if you replace AC on these car you are "supposed to do Compressor, Condensor and Dryer, And Expansion block. I have done 2 cars by just having someone vac out system, Then replace Compressor and dryer, Then have system recharged. The is no need for a book to do that if you can Undo sepr belt- Unbolt AC and pullit out.
2000 Jetta TDI 5sp. 1990 Mitsubishi Montero LS, 1995 Montero SR. 1990 TW200 "ratbike"
sasnydley is offline   Reply With Quote
Old April 28th, 2011, 15:12   #7
el fuego
el fuego's Avatar
Im doing the compressor and dryer. And Well my tool collection it's still small, i dont want want to start the job and find out I don't have a special/rare German/vw bull**** tool/s for the job and be stuck half way through, my mechanic said it was all Allens or somewhat underneath. and I have a shop that will vac the system out for me and refill it when im done.
The 2 that you did, were they tdi's? What kind of tools did you use?
Old April 28th, 2011, 17:55   #8
Seatman
Seatman's Avatar
Neither it does, wonder what happened there, I found the info too.
Old April 30th, 2011, 20:41   #9
sasnydley
You'll need some Allen wrenchs, And some metric wrenches. thats about it- You should get system vac'd to recover Freon. then when done get it vac'd again- To test if leaks then get it recharged.
Old May 4th, 2011, 09:18   #10
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
ElFuego,
You may want to do the expansion valve, and all other system O rings you can physically get to while you are in there. Cost of these items is minimal, and it would be a shame to finish the job just to have something leak, or not work properly. I did this on mine, and have been very pleased with the results. Make sure to get a good quality reputable part for the expansion valve though.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread.php?t=306799&page=4
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
2006 Jetta ""AC Problem"" YODAUSA VW MKIV-A4 TDIs (VE and PD) 0 July 1st, 2009 21:46
Is there such a thing as a "Honest AC Tech." In Maryland? Baldy_54 VW MKIV-A4 TDIs (VE and PD) 6 June 19th, 2008 17:33
Dealer removes "bumper and heater" to replace glow plug? st50maint VW MKV-A5 Golf/Jettas 16 November 9th, 2007 09:36
Replace "Join Date:" with "TDI:" on forum posts vwestlife TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 4 April 1st, 2006 11:26
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 07:06
Page generated in 0.14939 seconds with 10 queries
[Output: 96.75 Kb. compressed to 82.28 Kb. by saving 14.47 Kb. (14.96%)]
