Old April 26th, 2011, 10:26   #1
fij
Default 17978 p1570 engine start immobiliser problem?
hi pls cud sum1 help i hav a s reg 99 golf gt tdi an it wont start due to factory immobiliser (car+key light kps on flashing) it starts for few seconds then cuts off!. the problm startd wen i cudnt take the after market toad immobiliser off, bt by pulling the wires i managed to knock off the the toad immobiliser bt now the factory original immobiliser wont disarm.
can sum1 help me pls.
the local garage guy found the code-
"17978 (P1570) Engine Start Blocked by Immobilizer"
can sum1 plssssss help?hw can i fix this problem???? thanku
fij is offline   Reply With Quote
17978 (P1570) Engine Start Blocked by Immobilizer ymz OBD Scanners 36 October 11th, 2016 14:01
Engine only runs for 2 secs. Error Code 17978 awmw TDI 101 13 March 17th, 2010 12:43
Engine Start Blocked By Immobilizer P1570 maniek OBD Scanners 2 November 17th, 2008 17:02
Fault Code 17978...P1570 kona99 OBD Scanners 4 September 20th, 2008 12:15
Immobiliser Problem k1cka55 TDI 101 11 October 2nd, 2006 20:33
Page generated in 0.11389 seconds with 10 queries
[Output: 46.26 Kb. compressed to 43.58 Kb. by saving 2.67 Kb. (5.78%)]
