Old April 26th, 2011, 06:40   #1
ricaroo
Default engine cut out while driving
Hi All,
I started my 2011 jsw this morning, and it started up fine and idled fine after a 3 or 4 min I put it in drive (dsg) and took off for work. After apx 3 miles the engine cut out twice so I pulled over and put it in park when I did the engine was idling real ruff like it was not firing on all cylinders. I was afriad to shut it off so I made a u turn to head back home it ran fine and when I pulled in the driveway and put it in park again it idled perfect.
I thought I would chance heading out again and go to work (70 miles one way) the car ran fine and I did not have any problems. I called the dealer and they said it might be bad fuel... They suggested I chang stations and see if that changes anything. I asked them to put a note in my file regarding this
What would cause something like this? Any thoughts?
2007 NBC 2.5L automatic
2011 Jetta Sportwagen 2.0L DSG TDI
ricaroo is offline   Reply With Quote
Old April 26th, 2011, 08:57   #2
740GLE
Where in NH are you? Any lights on the dash? were you honking you're horn when it died? ;-)
Other than having a mil light or code stored the dealer isn't going to really know where to look (battery terminal loose wiring issue?). Unless the problem can repeat itself and be peged down to something, it might be gremlins that will live up to VW's history.
Old April 26th, 2011, 09:17   #3
ricaroo
Hi,
I live in Barrington
Any lights on the dash? were you honking you're horn when it died (NO)
battery terminal loose wiring issue (NO)
I was traveling apx 40 mph it felt like when you have water in you gas on a gasoline motor
Old April 26th, 2011, 09:37   #4
IMAAaron
Does it still have oil?
IMAAaron is offline   Reply With Quote
Old April 26th, 2011, 10:11   #5
meowguy
meowguy's Avatar
Wish I could help with your problem. It could be fuel, but for some reason I don't think so. If you really thought it was fuel you would want to have the tank emptied and have the filters changed. At the very least inspect the filter housing for water in the bottom.
As far as fuel is concerned, if you travel near Portsmouth on your way to or from work, Buzzy's Bypass Truck Stop on Rt.1 N in Portsmouth has a B5 pump. Neither I, nor anyone else on this forum has had any problems with fuel from Buzzy's.
meowguy is offline   Reply With Quote
Old April 26th, 2011, 18:18   #6
jtelford
What was the rpm? At about 2K rpm, there is sometimes a stumble (it's normal). I can't really say it feels like bad gas, though- just a small, momentary hesitation.
jtelford is offline   Reply With Quote
Old April 26th, 2011, 19:27   #7
CopaMundial
When you say the engine "cut out twice", do you mean the engine stopped or just stumbled?
Also did it run rough on the entire ride home or just long enough to get you to turn around?
If it stumbled and ran rough for a little while, but not the whole ride home, then my money is on a DPF regen, which is perfectly normal.
CopaMundial is offline   Reply With Quote
Old April 26th, 2011, 19:56   #8
glennco
TDI(s): 2010 JSW DSG
Sounds like the water in the intercooler issue to me.
I'm only a rookie though, these vets would know way better than me
glennco is offline   Reply With Quote
Old April 26th, 2011, 19:57   #9
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
Bad GAS will do it every time. Maybe try DIESEL instead of GAS?
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
Old April 26th, 2011, 20:12   #10
n1das
n1das's Avatar
Exclamation
The problem with this is the dealer can use the note as a reason to deny warranty coverage if you in fact do have a problem developing. Damage caused by bad fuel isn't covered under warranty.
I'm seriously hoping it's not a problem with the HPFP. It could have been a regen operation starting and the brief shudder is normal when a DPF regen operation starts up.
Good luck.
Member SSBMWO
Old April 27th, 2011, 00:47   #11
fastalan
The OP did mention that the engine idle was rough. Sounded like IF there were some bad fuel, it was all burned up as there were no problem on the 70 miles to work afterward.
2k10 Golf TDI Wagon 6-sp manual
2k06 Mini Cooper CVT
1994 Aerostar cargo
fastalan is offline   Reply With Quote
Old April 27th, 2011, 01:52   #12
ksing44
I'm with you. Rough idle during regen is common. Stumble from de-fueling when hill cresting or whatever also seems to be normal for these TDI engines.
2010 Golf TDI - Blue (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP!
Flickr slideshow
ksing44 is offline   Reply With Quote
Old April 27th, 2011, 10:13   #13
ricaroo
rpm (1400)
just a small, momentary hesitation (yes twice a couple of min apart)
(Stumbled)
(once I put it back in D and gave it fuel it was ok from that point on)
Old April 27th, 2011, 18:46   #14
jtelford
Yeah, yeah. I was tired.
Old April 29th, 2011, 07:07   #15
Carphuntin_god
sounds like you are in this boat http://forums.tdiclub.com/showthread...=270973&page=6
Uber Polluter
Carphuntin_god is offline   Reply With Quote
Engine cut out question Erney TDI 101 7 June 29th, 2010 20:41
Engine cut out while driving, stranded. tnteggroll TDI 101 46 September 9th, 2009 18:45
engine cut off whilst driving maybe fuel pump? ebma1 VW MKIV-A4 TDIs (VE and PD) 9 September 12th, 2008 07:28
Engine Cut Off While Driving ninedee_golf_tdi VW MKIII-A3/B4 TDIs 1 February 24th, 2007 10:14
engine cut out at 4100rpm ??? garrettp VW MKIV-A4 TDIs (VE and PD) 0 May 23rd, 2001 15:28
Page generated in 0.18802 seconds with 10 queries
[Output: 128.28 Kb. compressed to 107.03 Kb. by saving 21.25 Kb. (16.57%)]
