Old April 22nd, 2011, 07:17   #1
Comiclown
TDI(s): 2001
Default Valet Key Programming
I have a 2000 Jetta TDI and I just ordered a regular valet key from a local dealer for $59.00. Have anyone tried the following steps ( I found them on ehow.com) to program a valet key (no fob)?
Get into your vehicle. Insert your valet key into the ignition and turn the key as far as you can in the "On" position without cranking the engine.
Get out of the car and close the door behind you, leaving the valet key in the ignition. Place your regular car key in the driver's door and turn the key to lock the car manually.
Remove the key from the driver's door. Push the "Unlock" button on your key fob twice.
Enter your car, turn the valet key to the "Off" position and remove it from the ignition. Your valet key is now programmed.
thanks!
Comiclown is offline   Reply With Quote
Old April 22nd, 2011, 20:19   #2
COcyclist
COcyclist's Avatar
Fuel Economy: 52 mpg lifetime ave.
Are you going to let us know if it works? I was quoted hundreds more for this at the stealership.
04 Golf- Panzer plate, GTI rims, Short Shift, Hidden Hitch, Euro switch, LED DRLs, Scanguage II, ventectomy, mufflerectomy
COcyclist is offline   Reply With Quote
Old April 22nd, 2011, 22:27   #3
snakeye
snakeye's Avatar
This worked for resetting a remote key that I thought was FUBAR. I doubt it will make the car recognize the immobilizer chip in the valet key.
snakeye is offline   Reply With Quote
Old April 23rd, 2011, 08:24   #4
tomiegunn77
I second the above.. the technique you refer to is for programming a new fob using an already working valet key. It does work though..
tomiegunn77 is offline   Reply With Quote
Old April 23rd, 2011, 19:59   #5
Hakcobra
Fuel Economy: Getting Better!
I have two key fobs but no Valet key. One fob works and the other does not (red light lights up but will not unlock doors or trunk). Will the above technique reprogram my dumb remote?
2003 Jetta Wagon TDI -- 5 Speed Swap-DLC 1019-DieselGeek Short Shifter-Ventectomy-Panzer FMJ-Scangauge II-Frost Heater
Hakcobra is offline   Reply With Quote
Old April 23rd, 2011, 21:17   #6
Hakcobra
Nevermind, just tried the other key fob and the red light doesnt come on, even after new batteries. Must be doa.
Old April 24th, 2011, 07:22   #7
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
thanks!
The procedure you post here is to reprogram remote . Valet key don't have remote.
What do you trying top reprogram, Remote on other key or Immobilizer?
If you want to reprogram immobilizer then info is here:
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_II_Key_Matching_%28Cluster%29
Important Note: Unless you ALREADY have the SKC information for your vehicle and components then you will NOT be able to do any of the Immobilizer functions.
Click this link for more information.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
any use or value for key fob and valet key gquenstedt TDI 101 3 July 7th, 2010 17:26
WTB: mk4 d/s key lock and valet key sawedoffgolf Private TDI Items for Sale/Wanted 0 April 25th, 2010 15:06
WTB: Key FOB or Valet Key (#HLO 1J0 959 753 F) olywafox Private TDI Items for Sale/Wanted 6 June 28th, 2007 14:32
Re; valet key cut from existing sidewinder remote key JELLYBEAN TDI 101 6 January 22nd, 2007 10:28
Valet Key? TURBO9 TDI 101 22 June 26th, 2005 13:25
Page generated in 0.14344 seconds with 10 queries
[Output: 81.73 Kb. compressed to 71.11 Kb. by saving 10.62 Kb. (13.00%)]
