Old April 18th, 2011, 22:10   #1
cajunspice
Default 05 passat tdi timing belt kit?? need help
I am new to the tdi motor. Should i get a timing belt kit off the net? What company on this site should i buy my kit from ??Should i go to the dealer? should i do a oil pump gear kit??? my tdi has 126,300 what should i do?
cajunspice is offline   Reply With Quote
Old April 19th, 2011, 03:29   #2
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
If the timing belt has not been replaced at the suggested maintenance interval (originally 100,000 miles, now 80,000) and you are currently at 126,300, you need to have it replaced as soon as possible. While performing this job it is highly recommend you replace the roller, timing belt tensioner and waterpump. I would also recommend replacing the serpentine belt at the same time. As for the oil pump gear kit, better known as the balance shaft module (BSM), it should be converted from the chain driven BSM to the gear driven BSM at the same time to save on labor. The original chain driven BSM is a ticking time bomb you cannot afford to have go off.
Where to buy a timing belt replacement kit - there are several vendors that frequent this site. In no particular order ( I apologize if miss someone):
Selling kits
www.dieselgeek.com
www.idparts.com
www.worldimpex.com
www.boraparts.com
VW dealers that sell the individual pieces
www.gunthervw.net (search for this site for code for discount)
www.1stvwparts.com
The question that accompanies this, who are you going have perform this work or are you going to attempt yourself? ...most [assume] VW dealers don't even know the problem exists.
Read the stickies at the top of this forum for more information BSM info:
http://forums.tdiclub.com/showthread.php?t=233651
http://forums.tdiclub.com/showthread.php?t=293773
Other things to check at the same time (cuz you are there):
- Alternator pulley
- Engine mounts
- Check to make sure the ground cable isn't rubbing on the intake charge hose on the front passenger side
- Electric cooling fan at radiator is functioning
- mechanical cooling fan bearing and hub or in good working condition
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
A5 JETTA TDI TIMING BELT KIT BRM $175 and Timing Belt+ alternater pulleyTools $65 kstef Private TDI Items for Sale/Wanted 1 August 29th, 2010 05:05
'06 Jetta TDI timing belt kit? JD's 06 tdi TDI 101 2 February 22nd, 2010 16:53
outer cv boot kit for 04-05 tdi Passat motorinar Private TDI Items for Sale/Wanted 0 July 1st, 2009 21:20
05 Passat Timing belt chg. gt VW B5 Passat TDIs 17 February 8th, 2007 22:07
wtb a timing belt kit, set of rims, and body kit eagleneck Private TDI Items for Sale/Wanted 10 November 5th, 2004 20:54
Page generated in 0.12338 seconds with 10 queries
[Output: 54.39 Kb. compressed to 50.34 Kb. by saving 4.04 Kb. (7.44%)]
