Old April 18th, 2011, 14:53   #1
DNOSILLE
TDI(s): vw, bettle
Default No power to ac clutch
Im not getting power to my ac clutch, have checked pressure sensor, fuse block, fan module, etc, im currently looking for the ac relay under the dash? Or any other thing i might check
DNOSILLE is offline   Reply With Quote
Old April 18th, 2011, 14:56   #2
gquenstedt
with the key in the on position (engine running or not) and the a/c on, do the cooling fans come on?
If yes, then you most likely have a bad fan control module.
If no, then it's probably the pressure sensor.
Where in Texas are you?
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
Old April 18th, 2011, 15:18   #3
DNOSILLE
TDI(s): vw, bettle
We,ve tried a new module, and pressure sensor, not sur if both fans come on, im in ft worth texas
Old April 18th, 2011, 15:27   #4
gquenstedt
What was the source of the new module and sensor?
I ask because I helped someone here in San Antonio who had replaced the pressure sensor, fan control module, fuse block, and finally the computer and still had no a/c. It turned out that the pressure sensor he had purchased from ebay was defective, and was the root cause.
DanG144 has an excellent guide on how to troubleshoot these systems where he gives procedures to actually measure with a volt or digital multimeter to pinpoint the problem instead of guess. I would consult that.
Old April 19th, 2011, 06:20   #5
DNOSILLE
TDI(s): vw, bettle
Not sure, is there a way to bypass the module to see if the clutch will respond.
Old April 19th, 2011, 06:23   #6
DNOSILLE
TDI(s): vw, bettle
Where can i find a good wiring diagram, for the ac system?
AC Clutch is gone!! ???? diesel&dust VW MKIV-A4 TDIs (VE and PD) 18 April 17th, 2011 12:58
WTB MK IV AC clutch or blown or used AC compressor with good clutch. Ironforger Private TDI Items for Sale/Wanted 10 June 9th, 2008 08:40
WTB: AC Clutch or Compressor w/clutch Kombifahrer Private TDI Items for Sale/Wanted 0 May 5th, 2008 11:46
AC Clutch CurtisW TDI 101 15 January 14th, 2008 17:54
WTB MkIV AC Compressor clutch or trashed ac compressor (with good clutch) Ironforger Private TDI Items for Sale/Wanted 0 December 1st, 2007 17:24
Page generated in 0.15083 seconds with 10 queries
[Output: 71.38 Kb. compressed to 62.42 Kb. by saving 8.96 Kb. (12.56%)]
