Old April 15th, 2011, 16:04   #1
snakeye
snakeye's Avatar
Default A/C compressor clutch doesn't engage
I went to an auto ac repair shop, and they diagnosed and filled the system. They said the compressor needs to be replaced and said everything else works fine.
Now, I checked it out by turning the AC on/off, and nothing happens. The clutch doesn't engage at all. This leads me to believe that the compressor is fine, it's the clutch that needs repair.
Is there a way to test or remove the clutch without removing the entire compressor?
Btw I want to measure the voltage of the wire going to the compressor, but I'm a bit retarded when it comes to electricity. What do I measure, AC or DC?
snakeye is offline   Reply With Quote
Old April 16th, 2011, 07:29   #2
Dave_D
AC clutch wiring is 12V DC. If you don't see voltage across the terminals with the A/C button in and the engine and fans running see if you show voltage to ground from one of the terminals. If you do you have a broken ground wire somewhere between the terminal and the ground connection. If you show no voltage at all start by checking for breaks in the wires or connectors from the clutch to the fan control module. Mine was broken at an intermediate connector.
Dave
1999.5 (A4) Tornado Red Jetta GL TDI,5 speed,4 door, RC 2+, Old Navy CCV mod, ventectomy, CAT filter
Dave_D is offline   Reply With Quote
Old April 16th, 2011, 08:55   #3
snakeye
snakeye's Avatar
Thanks for the reply. I checked for 12 volts, and I got 9.21 when the car was off, running, and with the AC on, except that when the AC was on, it kept jumping to around 12v every 5-10 seconds. Is that what it's supposed to do?
Old April 16th, 2011, 09:04   #4
TOBarber
Yes, it wants to start but doesn't see the proper pressure so shuts off for a bit, then tries to start again.
On my '00 Golf TDI automatic, the clutch was shot. You can take out 2 bolts and drop down the compressor without breaking open the AC. There is 1 connector for the wiring. I bought a replacement clutch on eBay and replaced my clutch... still working fine. The only catch is that there is a C-clip that is just too deep for my standard pliers to reach, so I had to take apart the pliers and use needle nose pliers on the C-clip head to remove and install the C-clip. Maybe you can find a better (narrower) C-clip pliers. I vaguely recall some pictures over on the Vortex site.
When I tested the clutch coil wiring, it was open circuit.
TOBarber is offline   Reply With Quote
Old April 16th, 2011, 09:08   #5
snakeye
snakeye's Avatar
Oh god... c-clips are good for ruining perfectly good days. Let's hope it's not that hard to remove. Thanks!
Mechanic friend replaced AC Compressor clutch wont engage Abishop TDI 101 18 June 28th, 2010 13:20
clutch won't engage, sometimes WB5A TDI 101 8 December 22nd, 2007 15:00
WTB MkIV AC Compressor clutch or trashed ac compressor (with good clutch) Ironforger Private TDI Items for Sale/Wanted 0 December 1st, 2007 17:24
When does your clutch engage? Aggie05 VW MKIV-A4 TDIs (VE and PD) 7 August 20th, 2006 17:07
A/C compressor won't engage highhilltdi VW MKIV-A4 TDIs (VE and PD) 5 June 16th, 2006 07:38
Page generated in 0.11779 seconds with 10 queries
[Output: 70.96 Kb. compressed to 62.43 Kb. by saving 8.52 Kb. (12.01%)]
