Old April 7th, 2011, 08:14   #1
texcl
Default change 01M fluid without vag-com?
Can I change the oil without the VAG-COM, my laptop died and really dont have the money to buy another can I change the oil with out it?
texcl is offline   Reply With Quote
Old April 7th, 2011, 08:41   #2
usarmyharley
TDI(s): 2003 jetta
glad you posted this question...sorry i cant help you but im thinking about doing this also because the closest tdi trusted mechanic is 250 miles from me. Id magine it can be done jus not recommended
usarmyharley is offline   Reply With Quote
Old April 7th, 2011, 09:24   #3
Geomorph
If you measure what comes out and put the same amount back in you should be very close. I have done this and did not need to add any fluid after checking the level with the proper method. If you are changing the filter also, then it is harder to gauge exactly how much to put in as the filter will be holding some fluid as well. Other options to VCDS are to use an infrared thermometer or Scangauge can also read transmission fluid temperature.
To the OP, if you can get a desktop computer close enough to the car, then you could use that as you already have the VCDS cable.
Geomorph is offline   Reply With Quote
Old April 7th, 2011, 09:34   #4
bluesmoker
bluesmoker's Avatar
Fuel Economy: 57 highway mpg
here is a good post at vortex
http://forums.vwvortex.com/showthread.php?1064342
2004 pd 5 speed tip,malone tuning stage 1.5 with egr delete
former:1998 red jetta 5 speed man, malone tuning stage 1 with egr delete (it still lives in Maple Ridge)
new gas guzzler: 2001 Mercedes Benz Ml 320
bluesmoker is offline   Reply With Quote
Old April 7th, 2011, 15:26   #5
AARodriguez Corp.
AARodriguez Corp.'s Avatar
just buy a usb extension, I have a 30' usb extension cable
I think i bought it at compusa/tigerdirect.com
AARodriguez Corp. is offline   Reply With Quote
Old April 8th, 2011, 06:08   #6
texcl
I'm actually considering getting a cheap refurbed IBM think pad 600? from ebay for $100 to run it. That should be adequit to run the software right?
Old April 9th, 2011, 14:23   #7
MrSafety
Newbie at Heart
Fuel Economy: ~35 mpg "as was" when purchased TDI
Attach a string really well to a cooking thermometer and lower it down the fill tube once you have the enging warmed up some !
I believe there is ~a5 deg. range that's OK!?
And personally I would do the "top-off" procedure as the last check... adding just enough to get the fluid to spill over into/down the overflow tube!
Sam
Son's 2002 Jetta TDI 01M / My '81 Rabbit "Caddy" project / My '80 240D MB...
Other Projects
: Safe Intake Cleanout / IP-QA Craniotomy /
Working on way for DIYers to more fully FLUSH 01M trans as well as check/"top-off" the O1M Fluid Level.
Perform diesel purge without ingesting troublesome air !
Last edited by MrSafety; April 9th, 2011 at 14:25. Reason: Added last sentence/thought!
MrSafety is offline   Reply With Quote
Old January 10th, 2015, 13:56   #8
sjdiesel
Sam
Bringing this back up. I am in this same situation except I don't own a VAGCOM.
Sam, what is the "top offf" method?
I followed the precedure on kansiscitytdi.com. Once fluid started to "glug" out i plugged it. But I put my hand on the pan to measure temp. I know not the most accurate but I bet I was close to the magic 86-95* called for. Going to borrow an IR thermometer from a friend just to double check.
Thoughts?
sjdiesel is offline   Reply With Quote
Old December 8th, 2017, 23:44   #9
indysoto
indysoto's Avatar
I did this today on a 2003 Jetta and learned a couple things.
Vw atf restores headlight shine! And it really did..
Turns out this tranny was low on fluid, I drained 2 liters almost exactly. Followed Drivebywire's .pdf and it seems a couple things have changed or I just suck with a vagcom.
I could not get the temp function to work in drivetrain/auto trans/trans temp or whatever the first tab is/auto trans/trans temp when I clicked the box it said "you suck at using a vagcom" ha.. No really it said Blah bla not compatible with this ECU.
Figured It was maybe because I had not cleared the codes? I also went to a function that had the three vertical columns with 7 or 8 values and the 5th value was 0, #1 was 80 I was hoping that was temp but since I could not be sure I just went with feel instead of computer.
Anyway I put on a new filter then put about 2.9L in there total after the red plug drain overflow and then warm up / replug bottom and fill from weep hole and called it good for now.
Opened up the old filter(looked clean on outside just dingy brown and in the middle of the filter(its like a quesadilla clamped by metal sides) was to my horror chunks. But they just ended up being crumbly chunks of a coal/burnt oil? whatever it was to my pleasure it turned to gritty / dust upon grinding between thumb and forefinger. No sign of any metal or plastic chunks where it should have been, on both exposed sides of the filter just the middle?! Activated carbon filter??
Seemed to drive fine afterwords and that German atf is slicker than bat snot.
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
need 01M fluid change advice. lubdemdubs TDI 101 5 July 28th, 2010 13:06
01M Fluid Change Questions TDI_Matt TDI 101 5 February 4th, 2010 09:42
01m fluid change interval fruitcakesa TDI 101 6 November 8th, 2009 09:45
01M fluid capacity/change sdeck TDI 101 13 October 7th, 2009 19:56
01M Auto...fluid change? TDICADDGUY VW MKIV-A4 TDIs (VE and PD) 2 March 17th, 2008 18:31
Page generated in 0.16953 seconds with 10 queries
[Output: 93.62 Kb. compressed to 80.33 Kb. by saving 13.29 Kb. (14.20%)]
