TDIFest 2013 Registration is now open!
Old April 4th, 2011, 03:05   #1
c8dyj
TDI(s): mk5 golf 05
Default Throttle actuator fault
Can anyone help me please? I have a mk5 golf 2.0 140, been having problems with over boost for some time, this got worse and worse until I gave the waste gate actuator a bit of a wiggle, it did make a difference! The only problems I then had was at high speed it would go into limp mode with a fault code of 16618 showing. I guess ive just ignored this problem until my car went away for some bodywork and when it returned I had hesitation and stalling at low speed, could barely get to the end of the road! Had a chap round and found a new code for throttle sensor, now I got a new throttle assembly from vw but this made no difference! Had the AA out last night and they found a code of 5523055 ( throttle actuator ) , he thinks it may be a faulty ECU?
Im really at a loss " help please"
c8dyj is offline   Reply With Quote
Old April 4th, 2011, 04:33   #2
Tom W.
Tom W.'s Avatar
Fuel Economy: TDI 49MPG IDI 60MPG
Limp mode. Follow the link in my signature to properly diagnose.
Chemically cleaning your turbo: http://forums.tdiclub.com/showpost.p...8&postcount=48
canadiangrizzly's Diagnosing limp mode: http://forums.tdiclub.com/showthread.php?t=179589
GoFaster on loss of power:
http://forums.tdiclub.com/showthread.php?t=75959
Tom W. is offline   Reply With Quote
Old April 4th, 2011, 04:43   #3
c8dyj
TDI(s): mk5 golf 05
Thanks , Will take a look
got a throttle actuator fault going on, I have some questions. please help! r.etheridge VW MKV-A5 Golf/Jettas 11 May 20th, 2013 12:23
Throttle Body Actuator - P0638 seabumb VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010+) 15 February 9th, 2013 14:45
throttle pedal fault richyhall TDI 101 14 January 9th, 2013 15:48
Turbo actuator sensor fault code. turbocharged798 VW MKIV-A4 TDIs (VE and PD) 9 March 14th, 2011 18:41
Throttle Actuator Control Valve - Source of busted boost? Nitrowolf TDI 101 2 August 1st, 2008 14:01
Page generated in 0.15169 seconds with 10 queries
[Output: 56.69 Kb. compressed to 51.43 Kb. by saving 5.25 Kb. (9.27%)]
