Closed Thread
Old April 5th, 2011, 04:22   #16
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Correct, you need to see what the MAP sensor is actually reading before you proceed to throw expensive parts at the car. That was what I was getting at. Sorry, did not notice your post before .
I have replaced a couple of these sensors, and the symptoms were NO power (at all), because the ECU places the engine in limp mode right away if it cannot see the MAP values, and they always had a DTC set.
Chances are you do not need a MAP sensor, like 99%. Cleaning it won't do anything, it is already always covered in oily mist anyways.
Grab an appropriate scan tool, and drive the car and monitor actual and requested boost... you'll know right away if the MAP is doing its job.
oilhammer
www.cardocautomotive.com
oilhammer is offline
Old June 15th, 2011, 13:08   #17
aai2on
TDI(s): 2006 Jetta
Default Update - Wasn't the boost pressure sensor
VW Dealership thought it was the boost pressure sensor. NOPE
Currently the vehicle is experiencing lag on acceleration then cuts out until you give it more acceleration. Then it will get going. I put in a new air filter and cleaned the MAF. Slightly better at first, but the problem seems to be getting worse. We are noticing that during driving, you can feel the vehicle with small lags but continues driving.
Latest development. Car seems to have gone into limp mode. Would only do about 15mph. We took it to a good friend (mechanic) He says the throttle position sensor is reading high all of the time. He isn't getting much for reading, etc. I really don't want to take it back to dealership. They are total idiots (Las Cruces, NM ) My wife loves her car and needs it fixed. (Note: I know very little mechanic wise)
Any help is appreciated.
aai2on is offline
Old June 15th, 2011, 13:28   #18
oilhammer
oilhammer's Avatar
Originally Posted by oilhammer View Post
.... [smart guy stuff] ....
Chances are you do not need a MAP sensor, like 99%. ....[more smart guy ramblings]....
I think this guy has a good suggestion.
oilhammer
Old June 15th, 2011, 17:26   #19
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Why is it when you give people advice, they ignore it, waste more money on parts, and then ask for more advice?
I don't get it.
turbocharged798 is offline
Old June 16th, 2011, 04:55   #20
oilhammer
oilhammer's Avatar
I don't get it.
Me neither. You can lead a horse to water, but can't make him drink.
oilhammer
Old June 22nd, 2011, 08:57   #21
aai2on
TDI(s): 2006 Jetta
Still not getting any codes out of the engine. Going to try the cage mod and see if there is any change in performance.
aai2on is offline
Old June 22nd, 2011, 09:35   #22
aai2on
TDI(s): 2006 Jetta
oilhammer - I didn't ignore what you recommended doing. My mechanic and his $10K scanner isn't getting any error codes. He is running it in generic mode as he doesn't have VW unlocked I asked him again about the MAP codes and he said he would try it again. I specifically asked him to check the requested versus actual boost readings. Sorry for the inconvenience.
Should I just go buy the vag-com for my car and do it myself? We tried the new diag at the chevy dealer, but didn't get anything new (1.5 hrs x $75 to my mechanic) Not sure why he hasn't or how much it would cost to unlock the VW codes to his system...
aai2on is offline
Old June 22nd, 2011, 09:47   #23
oilhammer
oilhammer's Avatar
Just because there are no DTCs, doesn't mean there could not be some issue, nor does it mean there is no useful data to be garnered from a proper scan tool.
I'd be willing to be VCDS can do more than his $10k scan tool on your Volkswagen.
oilhammer
Old July 6th, 2011, 20:32   #24
aai2on
TDI(s): 2006 Jetta
I don't know if this provides the information we're looking for. This was a quick try. Used 003, 011, and 115.
aai2on is offline
Old July 6th, 2011, 21:36   #25
Keith_J
Keith_J's Avatar
Fuel Economy: 38 MPG @ 80 MPH with 2 bikes on top. 52 MPG @ 60 MPH slick
IIRC, it is a 5 volt variable resistor. It COULD be tested outside IF you had a bench power supply, knew the connections and measured the output based on the pressure applied.
I've done this on GM MAP sensors. Used a PC power supply for the 5 volt source.
The VAG charge pressure sensor is similar, a 3 pin sensor which is a variable voltage "ladder". Meaning the voltage at terminal 2 is dependent on the pressure.
Since it measures the pressure over atmospheric, there is a vent on the outside. If this vent is clogged, there will be issues.
2k Jetta manual. PP520s. Ventectomy, Panzer Plate, DT hitch, 16"s w/ 205 55s. Short shifter. Boost gauge with blue LED backlight, same intensity as dash. Blistein struts and shocks. 0.658:1 5th gear swap and LOVING IT.
Keith_J is offline
Old July 7th, 2011, 07:47   #26
AndyUpNorth
Sounds like the Typical PD Lag that everyone seems to have and spends months of their lives trying to figure out. All while never accomplishing anything. It feels like it builds boost, a "valve" opens and the boost drops but the power takes off, and then it begins to build boost up again, in a smooth fashion. It even looks that way on a Boost Gauge.
Some seem to like to put zip ties on them, and it reduces it, but that's a band-aid at best. While thinking about all the theories that have flown around on here, I think it is better while cool, and worse while hot hot.
AndyUpNorth is offline
Old July 7th, 2011, 09:15   #27
aai2on
TDI(s): 2006 Jetta
Was the zip tie thing one of the hacks? At this point I am willing to try anything to get it to run better. The wife hates it, and when you take off, it seems to bog down. Driving in manual shift mode resolves the issues (into 2nd and 3rd gear)
aai2on is offline
Old July 7th, 2011, 09:20   #28
aai2on
TDI(s): 2006 Jetta
Originally Posted by jcrews View Post
You can test everything relevant with VCDS using run-up tests and basic settings mode. You should also test the vane actuator with a vacuum pump while visually watching it as well as having a helper watch VCDS for the reported position.
The MAP sender is solid state and is not affected by dirt, oil, etc. The only thing that can go wrong with it is if the transducer itself goes bad due to a defect.
I almost hate to ask, but where is the vane actuator located on a 2006 Jetta TDI? There is a component on top of the turbo that looks similar, but I don't see anyway of testing it without removing it.
There are other articles that seem to indicate you can see it from under the car... (I have the VCDS if you can tell me which is the appropriate test code to use)
aai2on is offline
Old July 7th, 2011, 21:22   #29
AndyUpNorth
I'm sure if you search zip tie mod in the a5 forum, you'll find all the info you need, if that is what your talking about.
Below is my interpretation of whats going on.
It essentially slows down the building of boost, and it seems the computer has more time to reduce the boost spike and add fueling. Once your past that spike the vnt vanes aren't trying to build boost so rapidly and can easier and more smoothly make minor adjustments to the amount of boost requested vs actual. On full throttle and most in between the turbo is not trying to make maximum boost, its trying to hold at a certain pressure. If it were to continue trying at maximum vane angles, it would seriously overboost. The zip tie seems to stop it from initially building so much boost, thus getting you past that lag... now why the computer initially wants so much boost without the fuel, I'm not sure.
I've had that lag for a long long time, but it doesnt bother me much at all. I've stared at the boost gauge and played with it for more time than I ever should have. That is the conclusion I have come up with.
Best way I can figure of getting rid of it, is a bigger turbo ! Haha
Old July 9th, 2011, 21:48   #30
aai2on
TDI(s): 2006 Jetta
Thanks AndyUpNorth. I will try the zip tie thing.
aai2on is offline
Closed Thread
Altitude / Ambient Pressure Sensor Location? quigley VW MKV-A5 Golf/Jettas 12 April 16th, 2010 13:26
altitude sensor/boost pressure??? Silver Star Quebec 8 September 11th, 2009 17:55
intercooler boost pressure sensor paco TDI 101 0 July 14th, 2009 13:47
Differential pressure sensor location? Jimbo70 VW MKIV-A4 TDIs (VE and PD) 8 October 11th, 2008 07:37
Boost gauge pressure take off location TDiSi TDI Power Enhancements 5 February 11th, 2004 15:47
Page generated in 0.17305 seconds with 10 queries
[Output: 126.33 Kb. compressed to 105.46 Kb. by saving 20.87 Kb. (16.52%)]
