Closed Thread
Old April 3rd, 2011, 21:14   #1
aai2on
TDI(s): 2006 Jetta
Default Boost Pressure Sensor Location
Does anyone have a diagram that can indicate where the boost pressure sensor is on the 2006 Jetta TDI engine?
If needed, I can post a picture.
aai2on is offline
Old April 3rd, 2011, 21:19   #2
aai2on
TDI(s): 2006 Jetta
I found this link. Not sure if it is the same for the 2006 Jetta, but will check it out and see if it works.
http://newbeetle.org/forums/1-8-lite...orks-fine.html
aai2on is offline
Old April 3rd, 2011, 21:20   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
Isn't it down the bottom of the boost pipe that goes from the intercooler to the inlet manifold? If not they're usually on that pipe somewhere on most tdi's.
Seatman is offline
Old April 4th, 2011, 07:59   #4
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
It's on the intercooler outlet, behind the radiator. It will be near the right headlight.
jcrews is offline
Old April 4th, 2011, 08:01   #5
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yep, right up top.
oilhammer
www.cardocautomotive.com
oilhammer is offline
Old April 4th, 2011, 12:48   #6
aai2on
TDI(s): 2006 Jetta
Wow, that will be totally easy to replace. VW dealership wanted over $300 to replace it.
In case anyone wonders what the symptoms are, when accelerating, the vehicle would feel like it was losing power. Could be the limbo thing, but it quickly goes away once you start accelerating. I will try cleaning it first then order a replacement.
aai2on is offline
Old April 4th, 2011, 13:02   #7
oilhammer
oilhammer's Avatar
So what makes you think it is the boost sensor?
oilhammer
Old April 4th, 2011, 13:59   #8
aai2on
TDI(s): 2006 Jetta
Default Well.... That is what the dealers mechanic said it was
Well.... That is what the dealers mechanic said it was.
So, hopefully that is the issue.
aai2on is offline
Old April 4th, 2011, 14:01   #9
MonsterTDI09
MonsterTDI09's Avatar
What are the odds they correct
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline
Old April 4th, 2011, 14:27   #10
aai2on
TDI(s): 2006 Jetta
That is why I am going to pull it and check to see if it is dirty. New Mexico is pretty dusty this time of year.
Do you have any experience with this sensor and what a dirt/failure might act like?
Is there a way to test the boost pressure sensor?
aai2on is offline
Old April 4th, 2011, 14:51   #11
oilhammer
oilhammer's Avatar
LOL... OK, so we really have no idea what is wrong then.
What are the symtoms of the engine's operation? Are there any DTCs stored?
oilhammer
Old April 4th, 2011, 14:59   #12
aai2on
TDI(s): 2006 Jetta
My mechanic said there were no codes. He said to take it to the dealer. Dealer did the diagnostics (hopefully ) on it and said it was the Boost Pressure Sensor. If it still doesn't work, I will have my mechanic take another shot at it.
aai2on is offline
Old April 4th, 2011, 15:02   #13
oilhammer
oilhammer's Avatar
OK, please stop right now. You are getting ready to take a shot gun approach to something, and you still have not answered a simple question: what symptom does your car have right now? All we know so far is the typical he-said/she-said nonsense. We can help you, you just have to help us help you.
oilhammer
Old April 4th, 2011, 15:54   #14
aai2on
TDI(s): 2006 Jetta
If you go back to my post at 1:48PM I said:
In case anyone wonders what the symptoms are:, when accelerating, the vehicle would feel like it was losing power. Could be the limbo thing, but it quickly goes away once you start accelerating. I will try cleaning it first then order a replacement.
Additional information: The symptom lasts for just a few seconds and then it is fine. It occurs within the first few minutes or driving. Low power (seems bogged down) then the issue clears and drives with full power. My mechanic buddy says the turbo surges. To me it feels more like it bogs down.
aai2on is offline
Old April 4th, 2011, 16:46   #15
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
You can test everything relevant with VCDS using run-up tests and basic settings mode. You should also test the vane actuator with a vacuum pump while visually watching it as well as having a helper watch VCDS for the reported position.
The MAP sender is solid state and is not affected by dirt, oil, etc. The only thing that can go wrong with it is if the transducer itself goes bad due to a defect.
jcrews is offline
Closed Thread
Altitude / Ambient Pressure Sensor Location? quigley VW MKV-A5 Golf/Jettas 12 April 16th, 2010 13:26
altitude sensor/boost pressure??? Silver Star Quebec 8 September 11th, 2009 17:55
intercooler boost pressure sensor paco TDI 101 0 July 14th, 2009 13:47
Differential pressure sensor location? Jimbo70 VW MKIV-A4 TDIs (VE and PD) 8 October 11th, 2008 07:37
Boost gauge pressure take off location TDiSi TDI Power Enhancements 5 February 11th, 2004 15:47
Page generated in 0.14452 seconds with 10 queries
[Output: 121.08 Kb. compressed to 100.57 Kb. by saving 20.51 Kb. (16.94%)]
