Old April 2nd, 2011, 14:14   #1
Bzillins8806
Default Tricks to remove oil pan?
I have every bolt removed (including the 4 on the transmission side) and I can not for the life of me even get a screwdriver pried in between the pan and block. Does anyone have any advice to get this silicone unstuck?
02 5sp Jettagon
Dieselgeek Skid plate, EGR Delete W/ Stealth Race Pipe, Elephant Hose, Turbo Back, FMIC, DC Stg 1, PP520,
Bzillins8806 is offline   Reply With Quote
Old April 2nd, 2011, 14:47   #2
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
I usually use a large prybar between the trans bellhousing and the oil pan, making sure to pry the pan downward, and it pops right out...
-Rich
575,500 miles now and counting...24,500 until cluster swap! Stay tuned for engine update...
'00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old April 2nd, 2011, 14:48   #3
flatlanded
TDI(s): 2002 Jetta
Fuel Economy: 55ish US MPG
Did you remove all three of the larger bolts that tie the engine oil pan and transmission together?
I usually just give it a wack or two with a rubber mallet. Double check on your bolts, there should be 20 little ones and 3 big ones.
'02 Jetta TDI - 400,000 kms: Frostheater, boost/egt/oil-temp gauges, evolution skidplate, 5 brake light mod, 17/22, PP520, Malone Stage 5, 2.5" side-pipe, SBC Stage 2 Endurance
**Have VCDS**
flatlanded is offline   Reply With Quote
Old April 2nd, 2011, 16:51   #4
paramedick
paramedick's Avatar
Yup, my normal practice.....
Old April 3rd, 2011, 06:35   #5
SoKYTDi
SoKYTDi's Avatar
Fuel Economy: See my signature!
Thumbs up Just whack it!
This method worked well for me also!
Just a Geek, trying to make his way in this world.
2003 Golf GL TDi -- Lots o' mods and a whole list of dreams..... now in 6 gears!
SoKYTDi is offline   Reply With Quote
Old April 3rd, 2011, 07:38   #6
PoochiePD
PoochiePD's Avatar
As stated, make sure you get the 3 big ones out. What I do is take a normal combination wrench and pry that way. If you look at the pan where it meets the block, you will see 4 notches. 2 in front, 2 in back. They are just kind of indents or spaces, and they don't actually seal the pan to the block, so you don't have to worry about damaging the sealing surface. I just put a combination wrench in there, normally one "fork" of the open end, and use that to pry. If you're putting pretty good pressure on it and it doesn't even start to separate, you missed a bolt somewhere.
2013 Jetta:
PoochiePD is offline   Reply With Quote
Old April 3rd, 2011, 11:06   #7
Bzillins8806
I am counting 20 small bolts and three large ones and it does not want to budge.
This may be a reason in the future to tell people to not use Permatex black silicone sealant. The spec sheet says 430psi and that oil pan has at least 20 square inches of sealing area.
02 5sp Jettagon
Old April 3rd, 2011, 11:19   #8
Ski in NC
Fuel Economy: 48-52 typical
You need to find a pry-spot where you can get some leverage, preferably in a corner. It may take alot of force to break the glue bond. A corner is best as pan will flex a little and break the bond in a small area. Then it will peel off easier in the rest of the mating surface.
Pry HARDER!!!
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old April 3rd, 2011, 11:28   #9
Nutsnbolts
Nutsnbolts's Avatar
See post #2. Again.
-Rich
Old April 3rd, 2011, 19:06   #10
Bzillins8806
I sheared off a 1/4 in wide by 3/8 in deep chunk of the pan as I was hammering in a chisel to try and break it loose. Gonna borrow a heat gun next week.
02 5sp Jettagon
Old April 3rd, 2011, 23:39   #11
oldpoopie
oldpoopie's Avatar
Give it to your teenage son for a few weeks. Thats enough time for him to lower it to stupid low, tear off the factory skid plate, and rip the oil pan off on a speed bump....
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
How Do I Remove 2000 Jetta Oil Pan ???? Huntingfor1 TDI 101 6 May 30th, 2009 03:19
howto remove Tough-to-reach oil pan bolts Teedy Eye TDI 101 8 June 5th, 2008 19:15
oil pan remove, do i have to lift the engine off the car? joy123 TDI 101 6 May 3rd, 2008 14:35
can't seem to remove oil pan kack TDI 101 7 April 7th, 2008 06:00
how to remove Passat 1.8T oil pan? Ted_Grozier General VW Discussion 2 November 8th, 2003 13:30
Page generated in 0.14602 seconds with 10 queries
[Output: 103.94 Kb. compressed to 87.74 Kb. by saving 16.20 Kb. (15.58%)]
