Old April 1st, 2011, 03:50   #1
suparag
suparag's Avatar
TDI(s): None now.
Default 2006 Jetta Ignition Switch Issue.
My Jetta started with the strange issue yesterday. I inserted the key, after the first click (for the radio) and the second click (for the GP relay) and the car immediately started. As soon as I reach the second click (without going any further) the car starts.
This might be a big issue when the car is cold, it does NOT give time for GP to heat up. This happened when the car is warm after I drove 45 miles from work, then at a stop for a errand. I am going to hookup VCDS today to see if it throws any code. Anyone else have come across this issue?
Suparag
06 Jetta TDI-DSG, Sold
14 Passat - Sold to VW Buyback.
Currently no VW.
suparag is offline   Reply With Quote
Old April 1st, 2011, 06:38   #2
suparag
suparag's Avatar
TDI(s): None now.
I just scanned with VCDS, and got errors from Central Electronics and Steering Wheel areas. Thanks in advance for your input.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000170177
Coding: 14018E234004180000140000001400000028770B5C
Shop #: WSC 24339 444 52551
VCID: 2B7BCFA8F383
Part No: 1K1 955 119 C
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 24339
1 Fault Found:
01049 - Supply Voltage Term 50
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 12
Reset counter: 166
Mileage: 270691 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.00 V
OFF
ON
ON
OFF
OFF
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0012021
Shop #: WSC 00066 000 00000
VCID: 7AD53AEC4C59
Part No: XXXXXXXXXXX
Component: E0221 007 0050
3 Faults Found:
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
00576 - Terminal 15
Suparag
Currently no VW.
Old April 1st, 2011, 21:30   #3
Perreault17
Perreault17's Avatar
You have a faulty ignition switch (electrical portion). Super easy to replace, may take about 20 minutes and the part isn't too pricey either.
2010 Volkswagen Jetta TDI
1998 Volkswagen Golf 2.0
Perreault17 is offline   Reply With Quote
Old April 2nd, 2011, 04:22   #4
suparag
suparag's Avatar
TDI(s): None now.
Perreault17, is there a DIY or some pictures? I can get the part from local dealer, they wanted $165 to install.
Suparag
Currently no VW.
Old April 2nd, 2011, 13:24   #5
MyAvocation
MyAvocation's Avatar
Try a search, I remember reading about this a couple times.
MyAvocation is offline   Reply With Quote
Old April 2nd, 2011, 16:51   #6
suparag
suparag's Avatar
TDI(s): None now.
I did do a search, but the only ones I found are for older models.
Suparag
Currently no VW.
Old June 1st, 2011, 21:08   #7
Plus 3 Golfer
Plus 3 Golfer's Avatar
I have the same three fault codes (S instead of X) on my 2009 for the ignition switch and my car cranks but won't start. Did you replace the ignition switch?
Plus 3 Golfer is offline   Reply With Quote
02 Jetta TDI Ignition Switch Replacement bstill1200 VW MKIV-A4 TDIs (VE and PD) 18 May 28th, 2014 17:57
Ignition switch housing issue Tom Servo TDI 101 2 April 13th, 2009 16:00
96 Jetta ignition switch will not turn Iltis TDI 101 8 September 3rd, 2007 14:00
Ignition switch same on 97 Passat/98 Jetta bigtom111 VW MKIII-A3/B4 TDIs 2 May 15th, 2007 06:21
98 NewBee TDi Ignition Switch Issue UFO_TDi VW MKIV-A4 TDIs (VE and PD) 5 February 3rd, 2007 16:35
Page generated in 0.12552 seconds with 10 queries
[Output: 81.92 Kb. compressed to 70.85 Kb. by saving 11.07 Kb. (13.52%)]
