Old March 30th, 2011, 02:29   #1
ordep
Default Timing belt change - noise
Hello everyone,
Yesterday the mechanic changed the timing belt on my Golf IV 110hp ASV engine.
Around 1500rpm the car makes a strange hissing (like the sound of a turbo failure), but is not the turbo because the turbo comes around 1700rpm and the whistle is normal.
I asked the mechanic if it was the belt too tight, and he said no because there is only a position to adjustment. He also said that the noise it's because the belt is new???
The belt is not touching any side or tube and water pump was also changed.
Can anyone help me?
Thanks.
Regards,
ordep
ordep is offline   Reply With Quote
Old March 30th, 2011, 04:51   #2
dogdots
dogdots's Avatar
TDI(s): None
Look for a boost leak.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old April 1st, 2011, 15:06   #3
ordep
Hi,
I checked and the turbo it's ok.
Any other sugestion?
Regards
Old April 3rd, 2011, 07:35   #4
SoKYTDi
SoKYTDi's Avatar
Fuel Economy: See my signature!
Do you notice power dropping off when the hissing starts? That mechanic is probably full of crap -- if it was the new belt, the sound would rise & fall with your RPMs. I'd check to make sure the intake/EGR piping is properly installed -- no pinched hoses, bolts tight on EGR valve, clamps tightened.
Just a Geek, trying to make his way in this world.
2003 Golf GL TDi -- Lots o' mods and a whole list of dreams..... now in 6 gears!
SoKYTDi is offline   Reply With Quote
Old April 3rd, 2011, 07:38   #5
Dimitri16V
Dimitri16V's Avatar
is it hissing or whinning noise ?
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old April 4th, 2011, 04:49   #6
Shenandoah
Check all the intercooler piping and make sure it's connected. The first time I did the timing belt on the Jetta wagon the intercooler tube popped out because I didn't have the clip pushed in to hold it.
Eric
Seven TDIs: 2005 Jetta Wagon; 2005 New Beetle; 2004 Jetta; 2002 Golf; 2002 Jetta Wagon; 2000 Audi TT; 1999 New Beetle
Three Gas: 2000 Golf; 2002 Jetta; 2003 Jetta
Four "parts" cars: 2000 Jetta; 2000 Beetle; 2002 Golf (two of them)
Shenandoah is offline   Reply With Quote
Old April 4th, 2011, 06:23   #7
jettawreck
jettawreck's Avatar
Check to make sure the TB isn't routed w/toothed side running on one of the small rollers/idlers. Makes a pretty good noise, but its more of a whirrrrrrrring sound.
2004 Cadillac SLS (wife's)
Old April 20th, 2011, 13:41   #8
ordep
Hi all,
The noise of the timing belt is similar the one on this video, but not too loud.
http://www.youtube.com/watch?v=XUV27YtDCUM (see from 5 seconds). When the engine is idle, doesn't make the noise. it only happen when I accelerate, and is between 1500 and 1750 rpm, then it stop doing the noise or at least i no longer hear.
Kind regards,
Engine Noise after Timing Belt Change broncorox TDI 101 15 July 18th, 2011 16:20
wierd noise after timing belt change rim36 TDI 101 8 March 26th, 2009 21:17
Swooshing noise after timing belt change mcwig VW MKIV-A4 TDIs (VE and PD) 2 July 22nd, 2008 05:21
Grinding Noise and Timing Belt change vw2fan TDI 101 4 December 24th, 2007 18:51
Noise after timing belt change tdibeetler TDI 101 4 April 20th, 2006 08:52
Page generated in 0.13745 seconds with 10 queries
[Output: 85.72 Kb. compressed to 73.61 Kb. by saving 12.11 Kb. (14.13%)]
