Old February 22nd, 2018, 15:59   #466
My son's Golf with a 2" lift was not in factory specs for front camber. But it's only slightly out. He's driven the car close to 100K miles and we haven't seen any unusual tire wear.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old February 22nd, 2018, 19:42   #467
dhangejr's Avatar
TDI(s): mk4 Jetta
Fuel Economy: 49 high 44 mix average
I'd like to see a lifted only alignment spec sheet and issues thread.
dhangejr is offline   Reply With Quote
Old February 22nd, 2018, 19:46   #468
Fuel Economy: 44 Average
Originally Posted by Nevada_TDI View Post
So after reading this thread multiple times, I am at a loss of what to buy. I don't want to use spacers in the front if I can avoid it, so should I dish out the extra money for the Suplex VR6 front springs and the wagon rear springs? Granted the Suplex springs are almost three-times the cost of the "regular" VR6 front springs, but if I can get 1-1/2" without spacers and negatively affecting the alignment geometry, I can figure out the rear final height after the suspension settles, right? Thanks in advance.
I ran a while on the Moog cheap springs until they sagged down, then I got the Suplex. I'm in upstate New York with awful roads. I have the springs and spacers. You can adjust camber a bit with the 3 ball joint bolts.
Richptl is offline   Reply With Quote
Old February 23rd, 2018, 15:36   #469
I put 2” spacers with high mileage auto springs up front, moog wagon springs and Napa wagon shocks in rear. 1 1/4” rear spacers gave the rear end a slight rake. Shock travel and length were nearly the same as sedan. I believe I extended them 2”. I set the camber with a machinist square and had to slightly egg the ball joint mounting holes in the control arms to reach the spec. Spec was 1/4 degree I think. I haven’t driven it enough to make any claims on wear or settlement. Just found a pair of cheap 215/65/16’s to experiment with to see what it does to my gearing before buying tires and having it aligned. Curious at what speed it will idle in 2nd and 3rd gear. Hopefully some info someone can find useful. Also, when I had a friend spin up the rear spacers, I had him fit those little SS sacrificial spring seats on both ends of the spacers. Hoping that keeps the aluminum spacers from wearing.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Difference btw VR6 springs and jetta wagon springs Quanger Ontario 4 April 8th, 2014 07:35
Wtb: Mk4 Vr6 Wagon Springs EZC6083 Private TDI Items for Sale/Wanted 0 May 29th, 2010 09:56
WTB: VR6 Front Springs, Jetta Wagon Rear Springs OlyTDI Private TDI Items for Sale/Wanted 15 May 8th, 2010 08:35
WTB wagon or VR6 front springs cameron69 Private TDI Items for Sale/Wanted 9 August 21st, 2009 16:53
VR6 Springs in a TDI Jetta Wagon? adam_alexander Upgrades (non TDI Engine related) 1 July 29th, 2006 11:53
Page generated in 0.11819 seconds with 10 queries
[Output: 67.28 Kb. compressed to 60.64 Kb. by saving 6.65 Kb. (9.88%)]
