Old June 13th, 2011, 16:39   #31
52172
Fuel Economy: 45 mpgs
Thanks for answering all my questions. I'm getting ready to install my springs along with bilsteins tc sports and would you recommend one set of 10mm spacers or two? I don't mind the rear being 1/2 inch higher as that is normal?
01 Golf TDI Stage 4 Custom Malone tune, eurojet smic pancake pipe mod. 405k on the clock runs like new. 215/50/17's. Pd 150 intake and tip. 17/49VC Hybrid
52172 is offline   Reply With Quote
Old June 13th, 2011, 16:45   #32
52172
Do you have a set of 10mm spacers you would sell?
Old June 13th, 2011, 18:31   #33
miketoth1979
miketoth1979's Avatar
Fuel Economy: 32/46/60.5 (towing, avg., best)
52172, sent you a PM.
'01 Golf 5spd TDI 130K - Defender Steel Skidplate, Curt Towing Hitch, Independently-Powered Trailer Light Converter, DG 100k TB kit, Metra Aux ipod input added, MOOG VR6/wagon springs, Blausport shocks and struts, engine and trans stock
miketoth1979 is offline   Reply With Quote
Old June 14th, 2011, 13:48   #34
DSL HED
Fuel Economy: Better than a gas engine
52172, I'll update this thread when I get my Golf done. Should be done with it this weekend. Waiting for new LCAs to come in (tomorrow) and then will be doing the driver's side strut on the weekend. Then I'll be done.
2014 Tempest Blue Jetta SE 1.8TSI, dual note horn mod (aka Bluebell)
2012 Candy White Golf wagon mit DSG und aspherical mirrors (aka Waggy)
DSL HED is offline   Reply With Quote
Old June 14th, 2011, 14:34   #35
52172
Cool, I appreciate it!
Old June 14th, 2011, 15:22   #36
mech644
To the OP and anyone altering their ride height to any appreciable degree.
The rear axle is supposed to bolted to its attachment points such that at a level ride height NO preload is imposed on the axle bushings.
IF you are raising (or lowering) the ride height it may be worth considering loosening the axle bolts and then retorquing them with the car sitting level, .5 tank of fuel. VW directs one to do this when replacing the bushings as well, so makes sense to check/change as needed when raising lowering car. IMHO in the examples shown above if this is not done the wear rate of the axle bushings will be accelerated.
2012 Platinum S-line A3 DSG- bought back by VW
2000 Golf 5spd, 301k, the usual mods, sits forlornly in the backyard.
2006 Jetta DSG- gone
2015 GHB SEL 1.8 tsi
2014 Touareg
mech644 is offline   Reply With Quote
Old June 14th, 2011, 18:42   #37
miketoth1979
Thank you for the input, mech644, that isn't something that I even thought to consider.
Is there anything special I would need to do before loosening and retorquing those bolts, or is it pretty straightforward?
Old June 14th, 2011, 19:47   #38
mech644
Basically it's that simple. The bolt may be a torque to yield type in which case many would advise you to replace it, or it may not, I didn't replace mine and didn't loose a minutes sleep over it.
When I tightened mine after replacing the bushings I drove all 4 wheels up on top of 2 pieces of 2X6 per wheel (needed the extra clearance to swing wrenches), got out, jounced the car up and down a few times, and then laid down and tightened the bolt and nut.
2014 Touareg
Old June 26th, 2011, 13:11   #39
52172
dsl hed how did it come out? Thanks also sent you a pm.
Old June 26th, 2011, 17:44   #40
mech644
I just installed new struts/mounts front and rear (Koni FSD's) along with the Moog 81134 front coils. The Moogs replaced stock 2pink/2green coils(140 lb'ish I think). I've yet to make a choice on new rear coils. The lift in the rear demonstrated by the OP would not work well in my application.
Regardless I'm very happy with the FSD/Moog combo; rides great, takes craters and cracks equally well, handling limits far exceed the previous Koni Reds/stock springs. Before starting front fender crest was at 25", now at 27.5". The Reds are still usable, as are the mounts; suspension wasn't totally trashed, slinky stock springs just basically suck.
Surprisingly car still feels fairly balanced in spite of present front/rear spring combo. I'm still going to go with a heavier rear spring. At present the new rear struts are providing what the springs lack, rear lifted 1" with just the struts (rear mounts are fine, would've used them again if I didn't have new on hand).
Whatever one chooses for struts these Moogs, for the price from Rock Auto, are very hard to pass up, less then $60 delivered to my door.
2014 Touareg
Old June 30th, 2011, 21:49   #41
52172
I'm installing all four moogs with a set of 10mm spacers next Friday. Along with full TT bushings. Car will sit higher but have more travel and corner much flatter. Can't wait.
Old July 1st, 2011, 07:11   #42
GardRail
Given the type of write-up, and all the good information in this thread - any chance I can nominate it to be a sticky?
2k2 Golf TDI alh/01m -- 162k miles -- TDIHeater
GardRail is offline   Reply With Quote
Old July 1st, 2011, 08:31   #43
What struts and shocks?
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old July 1st, 2011, 22:22   #44
52172
Bilstein tc sports.
Old July 7th, 2011, 18:44   #45
jayb79
Great info here thanks for staring this thread mike.
01Golf(385k), 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost.
jayb79 is offline   Reply With Quote
Difference btw VR6 springs and jetta wagon springs Quanger Ontario 4 April 8th, 2014 07:35
Wtb: Mk4 Vr6 Wagon Springs EZC6083 Private TDI Items for Sale/Wanted 0 May 29th, 2010 09:56
WTB: VR6 Front Springs, Jetta Wagon Rear Springs OlyTDI Private TDI Items for Sale/Wanted 15 May 8th, 2010 08:35
WTB wagon or VR6 front springs cameron69 Private TDI Items for Sale/Wanted 9 August 21st, 2009 16:53
VR6 Springs in a TDI Jetta Wagon? adam_alexander Upgrades (non TDI Engine related) 1 July 29th, 2006 11:53
Page generated in 0.19006 seconds with 10 queries
[Output: 126.73 Kb. compressed to 105.56 Kb. by saving 21.17 Kb. (16.71%)]
